The desktop application does not display on Wayland
Server Version#: N/A
Player Version#: 1.109.0.329
The desktop app seems to appear invisible; I can’t click through it and windows behind it don’t update, but it doesn’t appear to display anything of its own.
Output:
qt.scenegraph.general: Using QRhi with backend OpenGL
Graphics API debug/validation layers: 0
QRhi profiling and debug markeqt.scenegraph.general: Using QRhi with backend OpenGL
QRhi profiling and debug markers: 0
Shader/pipeline cache collection: 0
rs: 0
[63693:63752:0515/012416.263068:ERROR:gl_context_egl.cc(277)] eglCreateContext failed with error EGL_BAD_CONTEXT
[63693:63752:0515/012416.263085:ERROR:gpu_channel_manager.cc(771)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[63693:63752:0515/012416.263088:ERROR:shared_image_stub.cc(470)] SharedImageStub: unable to create context
[63693:63752:0515/012416.263094:ERROR:gpu_channel.cc(449)] GpuChannel: Failed to create SharedImageStub
[63693:63752:0515/012416.401394:ERROR:gl_context_egl.cc(277)] eglCreateContext failed with error EGL_BAD_CONTEXT
[63693:63752:0515/012416.401412:ERROR:gpu_channel_manager.cc(771)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[63693:63752:0515/012416.401417:ERROR:shared_image_stub.cc(470)] SharedImageStub: unable to create context
[63693:63752:0515/012416.401423:ERROR:gpu_channel.cc(449)] GpuChannel: Failed to create SharedImageStub
[63693:63752:0515/012416.439920:ERROR:gl_context_egl.cc(277)] eglCreateContext failed with error EGL_BAD_CONTEXT
[63693:63752:0515/012416.439932:ERROR:gpu_channel_manager.cc(771)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[63693:63752:0515/012416.439934:ERROR:shared_image_stub.cc(470)] SharedImageStub: unable to create context
[63693:63752:0515/012416.439938:ERROR:gpu_channel.cc(449)] GpuChannel: Failed to create SharedImageStub
[63693:63752:0515/012416.580149:ERROR:gl_context_egl.cc(277)] eglCreateContext failed with error EGL_BAD_CONTEXT
[63693:63752:0515/012416.580167:ERROR:gpu_channel_manager.cc(771)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[63693:63752:0515/012416.580173:ERROR:shared_image_stub.cc(470)] SharedImageStub: unable to create context
[63693:63752:0515/012416.580182:ERROR:gpu_channel.cc(449)] GpuChannel: Failed to create SharedImageStub
[63693:63752:0515/012416.580576:ERROR:gl_context_egl.cc(277)] eglCreateContext failed with error EGL_BAD_CONTEXT
[63693:63752:0515/012416.580587:ERROR:gpu_channel_manager.cc(771)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[63693:63752:0515/012416.580591:ERROR:shared_image_stub.cc(470)] SharedImageStub: unable to create context
[63693:63752:0515/012416.580597:ERROR:gpu_channel.cc(449)] GpuChannel: Failed to create SharedImageStub
[63693:63752:0515/012416.847289:ERROR:gl_context_egl.cc(277)] eglCreateContext failed with error EGL_BAD_CONTEXT
[63693:63752:0515/012416.847305:ERROR:gpu_channel_manager.cc(771)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[63693:63752:0515/012416.847310:ERROR:shared_image_stub.cc(470)] SharedImageStub: unable to create context
[63693:63752:0515/012416.847316:ERROR:gpu_channel.cc(449)] GpuChannel: Failed to create SharedImageStub
Running QT_QPA_PLATFORM=xcb Plex does launch the application, but doesn’t support HDR and attempting to open the login page errors with:
kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9' not found (required by kde-open) kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9’ not found (required by /usr/lib/libKF6KIOGui.so.6)
kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9' not found (required by /usr/lib/libKF6KIOCore.so.6) kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9’ not found (required by /usr/lib/libKF6CoreAddons.so.6)
kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9' not found (required by /usr/lib/libKF6I18n.so.6) kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9’ not found (required by /usr/lib/libKF6Service.so.6)
kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9' not found (required by /usr/lib/libKF6Solid.so.6) kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9’ not found (required by /usr/lib/libKF6WindowSystem.so.6)
kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9' not found (required by /usr/lib/libKF6ConfigCore.so.6) kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9’ not found (required by /usr/lib/libKF6Crash.so.6)
kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9' not found (required by /usr/lib/libKF6AuthCore.so.6) kde-open: /opt/plex-desktop/lib/libQt6Core.so.6: version Qt_6.9’ not found (required by /usr/lib/libQt6Xml.so.6)
It should be noted that kde-open google.com works perfectly fine.
The Flatpak release works, but HDR content seems to be displayed as SDR.
