This week I have migrated from TVDB agent to The Movie DB agent and
I detected a problem with The movie database agent I try to explain it:
For the same files I create two libraries the first one the TVDB agent and the second one with The movie DB agent.
In TVDB order the episodes correctly but with The movie DB agent in The Big Bang Theory>Season 8 change the order like that: 11,1,12,2,3,4,13,5,14,6,7,15,8,16,9,17,10,18,19,20,21,22,23,24
I attached capture!
(/uploads/default/original/3X/e/0/e0b37fb50406c7fcdf73e4f7ec1391b0ddaed401.jpg “”)
It’s happen only in 8 season. I check the order on the web https://www.themoviedb.org/tv/1418-the-big-bang-theory/season/8
But it’s OK.
- I think that it’s only for order the episodes all the metadata it’s OK.
- For the same archives Plex show deferent order for the same episodes.
- I only detect that in season 8 of The Big Bang Theory, the other seasons shows OK
- I use the Spanish metadata information.
- I use 1.2.0.2765 server version on Synology NAS
Any ideas?
