open the registry editor regedit.exe
go to the branch HKEY_CURRENT_USER\Software\Plex, Inc.\Plex Media Server
and create a new key (right-click) (“String Value”) and name it LocalAppDataPath
To provide some context:
The quote you found is outdated. This feature has been removed from the frontend due to security concerns.
From the related PMS release announcement (version 1.19.3.2831):
Plex Media Server 1.19.3.2831 is now available in the Beta update channel
FIXES:
(Security) Remove the Windows AppData path preference from the web app (#11355)
Thanks, I just got frustrated. Sometimes they change things that work great and then they screw it up (generally speaking). I was having an issue where I needed to move the Server off the Data Drive - both on H drive and I couldn’t find the setting in the webpage/settings. Now they are separated. Server on C (SSD) and Data on H (a 500 GB, 7200rpm). Thanks for your help.
