The recording was aborted
I am running Plex Media Server v1.13.4.5271-200287a06 - ubuntu PC x86_64 - build: linux-ubuntu-x86_64 ubuntu
My DVR is an HDHomeRun CONNECT Quatro 192.168.116.243:80
Scheduled recordings of NBC Nightly News and the local news on the same channel are no longer recording. I have deleted and re-created the scheduled recordings, re-scanned channels and updated the guide.
I see where recording is failing, I’m just not sure why. Any suggestions?
Sep 03, 2018 17:30:00.444 [0x7f403c3fe700] DEBUG - DVR:Grabber: Starting operation for ‘NBC Nightly News - Episode 09-03’.
Sep 03, 2018 17:30:00.448 [0x7f403c3fe700] DEBUG - Activity: registered new activity 499f9228-eb48-4417-a83b-b4d61b43b7b9 - Recording
Sep 03, 2018 17:30:00.448 [0x7f403c3fe700] DEBUG - DVR:Grabber: HDHomerun starting a media grab on device device://tv.plex.grabbers.hdhomerun/10706A2A (Silicondust HDHomeRun CONNECT Quatro, supported) tuner 0.
Sep 03, 2018 17:30:00.451 [0x7f403c3fe700] DEBUG - DVR:Subscription: Resolved subscription to library item ‘NBC Nightly News’ (165)
Sep 03, 2018 17:30:00.453 [0x7f403c3fe700] DEBUG - There were 1 top-level paths for NBC Nightly News.
Sep 03, 2018 17:30:00.453 [0x7f403c3fe700] DEBUG - DVR:Grabber: Saving recording to “/var/lib/plexmediaserver/TVShows/.grab/32329f590909409b6226b160ad3222210a39f952”
Sep 03, 2018 17:30:00.454 [0x7f403c3fe700] DEBUG - HTTP requesting GET http://192.168.116.243:80/lineup.json
Sep 03, 2018 17:30:00.467 [0x7f403c3fe700] DEBUG - HTTP 200 response from GET http://192.168.116.243:80/lineup.json
Sep 03, 2018 17:30:00.468 [0x7f403c3fe700] DEBUG - DVR:Grabber: Going to record for 1800 seconds, final URL is http://192.168.116.243:5004/auto/v2.1
Sep 03, 2018 17:30:00.472 [0x7f403c3fe700] DEBUG - DVR:Grabber: Setting timer to stop grab of ‘NBC Nightly News - Episode 09-03’ in 1800 seconds.
Sep 03, 2018 17:30:00.472 [0x7f403c3fe700] DEBUG - DVR:Grabber: Waiting for a tuner (4 available).
Sep 03, 2018 17:30:00.472 [0x7f403c3fe700] DEBUG - DVR:Grabber: Allocated a tuner (3 left)
Sep 03, 2018 17:30:00.472 [0x7f403c3fe700] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Sep 03, 2018 17:30:00.472 [0x7f403c3fe700] DEBUG - MediaRecorderVirtual: setting stop time to 1536013800
Sep 03, 2018 17:30:00.472 [0x7f403c3fe700] DEBUG - DVR:Grabber: Freed a tuner (now 4 available)
Sep 03, 2018 17:30:00.473 [0x7f403c3fe700] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Sep 03, 2018 17:30:00.473 [0x7f403c3fe700] DEBUG - MediaRecorderVirtual: setting stop time to 1536013800
Sep 03, 2018 17:30:00.473 [0x7f403c3fe700] DEBUG - DVR:Grabber: Operation for NBC Nightly News - Episode 09-03 completed with status error (The recording was aborted)
Sep 03, 2018 17:30:00.473 [0x7f403c3fe700] DEBUG - Activity: Ended activity 499f9228-eb48-4417-a83b-b4d61b43b7b9.
Sep 03, 2018 17:30:00.473 [0x7f403c3fe700] ERROR - DVR:Grabber: Starting media grab failed.
Sep 03, 2018 17:30:01.487 [0x7f403b3ff700] DEBUG - EPG[onconnect]: Next thing to start/end is at 2018-09-03 23:00:00 (in 1800 seconds)
Hey - did you ever figure this out? I am also getting this error. Here is my log:
Nov 07, 2018 21:00:00.708 [9048] DEBUG - DVR:Grabber: Starting operation for 'Chicago Fire - E7 - What Will Define You'.
Nov 07, 2018 21:00:00.710 [9048] DEBUG - Activity: registered new activity f62568bf-7299-4b43-a787-5b81b7bd3888 - Recording
Nov 07, 2018 21:00:00.711 [9048] DEBUG - DVR:Grabber: HDHomerun starting a media grab on device device://tv.plex.grabbers.hdhomerun/10569657 (Silicondust HDHomeRun EXTEND, supported) tuner 0.
Nov 07, 2018 21:00:00.714 [9048] DEBUG - DVR:Subscription: Resolved subscription to library item 'Chicago Fire' (8418)
Nov 07, 2018 21:00:00.717 [9048] DEBUG - There were 1 top-level paths for Chicago Fire.
Nov 07, 2018 21:00:00.719 [9048] DEBUG - DVR:Grabber: Saving recording to "C:\Users\Charlie\Videos\TV Shows\.grab\e270e91ead11693388631db4883dbfeaec9f3474"
Nov 07, 2018 21:00:00.721 [9048] DEBUG - HTTP requesting GET http://192.168.1.156:80/lineup.json
Nov 07, 2018 21:00:00.747 [9048] DEBUG - HTTP 200 response from GET http://192.168.1.156:80/lineup.json
Nov 07, 2018 21:00:00.749 [9048] DEBUG - DVR:Grabber: Going to record for 3600 seconds, final URL is http://192.168.1.156:5004/auto/v2.1?transcode=heavy
Nov 07, 2018 21:00:00.751 [9048] DEBUG - MediaRecorderVirtual: setting stop time to 2018-11-07 22:00:00
Nov 07, 2018 21:00:00.752 [9048] DEBUG - DVR:Grabber: Waiting for a tuner (2 available).
Nov 07, 2018 21:00:00.752 [9048] DEBUG - DVR:Grabber: Allocated a tuner (1 left)
Nov 07, 2018 21:00:00.752 [9048] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Nov 07, 2018 21:00:00.753 [9048] DEBUG - MediaRecorderVirtual: setting stop time to 2018-11-07 21:00:00
Nov 07, 2018 21:00:00.753 [9048] DEBUG - DVR:Grabber: Freed a tuner (now 2 available)
Nov 07, 2018 21:00:00.754 [9048] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Nov 07, 2018 21:00:00.754 [9048] DEBUG - MediaRecorderVirtual: setting stop time to 2018-11-07 21:00:00
Nov 07, 2018 21:00:00.754 [9048] DEBUG - DVR:Grabber: Operation for Chicago Fire - E7 - What Will Define You completed with status error (The recording was aborted)
Nov 07, 2018 21:00:00.755 [9048] DEBUG - Activity: Ended activity f62568bf-7299-4b43-a787-5b81b7bd3888.
Nov 07, 2018 21:00:00.755 [9048] ERROR - DVR:Grabber: Starting media grab failed.
Nov 07, 2018 21:00:01.324 [7580] DEBUG - EPG[onconnect]: Next thing to start/end is at 2018-11-08 02:01:00 GMT (in 60 seconds)
I did not. I had Plex running on a Virtualbox VM and updated Ubuntu, Virtualbox, and the restarts helped but I was still having intermittent distorted video and audio. I now have Cox and will continue to test Plex.
David Gibson
dg@davidgibson.com
Tidying up loose ends
This specific error was addressed in version 1.14.0 onwards
If there are still problems when using the current version 1.14.1.5488 or later, please raise a new forum topic with debug server logs
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
