Theme Music Won't Play Anymore for Custom Theme Mp3's
For some reason, none of my custom theme.mp3 files play anymore for my TV shows. They used to work flawlessly, which was great, but no longer do.
Server Version: 4.76.1
They don’t work no matter what device I use, whether that’s my Apple TV or in the browser.
Some shows work, but these are ones without custom themes, grabbing the metadata from TVDB.
Did you enable Local Media Assets?
I did yes.
Sorry, I meant to mention that.
It works for me. Can you try navigating to a show with a custom theme, then grab me the server logs?
I sent you a direct message with server logs attached.
The show I attempted to go into was Sailor Moon.
Thank you so much.
Your logs don’t show the custom theme being requested. Can you refresh the show and get me a new log?
Messaged you the new logs.
I also screen captured my process so you can see what I was doing, if you would want that.
It’s in video form though, so couldn’t send it here.
Oh wait. Are you using the Plex TV Series agent? If so, the setting to use local assets is in the library setting itself. Check that this is on. This setting is also available on a show-by-show basis, so check there too.
By making that change and refreshing metadata, one of the shows now plays their theme song. I will keep digging around, as you gave me a good starting point here.
Thank you.
