"There was a problem emptying the trash." just started happening
Server Version#: 1.23.2.4625
I’m running two identical Plex Servers, both on the same version of Windows 10 and both pointed at the same media. Up until recently there were no problems at all on either server.
On one of them (not both), it just started reporting the error “There was a problem emptying the trash.” I do it frequently when I add new media, or replace or rename existing media. I don’t know what media it’s having a problem with. It doesn’t seem like a permissions issue as one of the two servers is fine.
Has anybody else had this happen before, or is there a good way to determine what is happening?
The server has 5 libraries, if I go to each one of them an try to ‘Empty Trash’ for the specific libraries, two of them report the error. (Movies & TV Shows).
Thank you for the help, I appreciate it.
I’m having the same problem after a fairly significant data re-org / clean up. Not sure what to do either.
