Two weeks in a row, 9AM Sunday morning, Fox News Sunday shows the error, Meet the Press, starting at the same time, does not.
This doesn’t happen on any other recordings during the week.
Snippet of log and screenshots attached.
PS, also some amount of time after getting this error, the system fixes itself (see pic). But when I go watch the show, the first 27 minutes have not been recorded.
Log is attached in first post. I also did a later recording, two shows at the same time at 11:30AM, to see if it was a two shows at the same time thing, and those recorded fine.
FYI, starting Fox News Sunday 1 minute earlier, 8:59 and Meet the Press at 9:00 seems to keep this transcoder error from happening and both are currently recording fine.
I have been having the same issues although it doesn’t happen everytime 2 recordings are starting at the same time.
Found the following common entries on failed recordings in my logs:
Plex Media Server.2.log:Feb 26, 2018 12:37:37.291 [0x7fc953bff700] ERROR - [Transcoder] [stream_segment,ssegment @ 0x24c0720] sample rate not set
Plex Media Server.2.log-Feb 26, 2018 12:37:37.293 [0x7fc957ffe700] ERROR - [Transcoder] Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Plex Media Server.2.log-Feb 26, 2018 12:37:37.294 [0x7fc953bff700] ERROR - [Transcoder]
Plex Media Server.2.log-Feb 26, 2018 12:37:37.298 [0x7fc9717ff700] ERROR - JobManager: child process returned: 1 (Operation not permitted)
Plex Media Server.4.log:Feb 25, 2018 19:56:18.008 [0x7fe7667f3700] ERROR - [Transcoder] [mpegts @ 0x208d4c0] sample rate not set
Plex Media Server.4.log-Feb 25, 2018 19:56:18.010 [0x7fe76efff700] ERROR - [Transcoder] Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Plex Media Server.4.log-Feb 25, 2018 19:56:18.011 [0x7fe76dffd700] ERROR - [Transcoder]
Plex Media Server.4.log-Feb 25, 2018 19:56:18.015 [0x7fe7917ff700] ERROR - JobManager: child process returned: 1 (Operation not permitted)
Plex Media Server.log:Mar 04, 2018 15:41:19.742 [0x7f181d7f6700] ERROR - [Transcoder] [mpegts @ 0x1d03b20] sample rate not set
Plex Media Server.log-Mar 04, 2018 15:41:19.743 [0x7f18153f2700] ERROR - [Transcoder] Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Plex Media Server.log-Mar 04, 2018 15:41:19.745 [0x7f18409e4700] ERROR - [Transcoder]
Plex Media Server.log-Mar 04, 2018 15:41:19.748 [0x7f183fbff700] ERROR - JobManager: child process returned: 1 (Operation not permitted)
