Server Version#:1.15.1.710
Player Version#:3.83.1
Installed on an Unraid Server in a docker
CPU: Intel® Xeon® CPU E5-2670 0 @ 2.60GHz
Memory: 64 GiB DDR3 Multi-bit ECC (max. installable capacity 192 GiB)
I have been getting this error over and over again when I access my Plex server via web browser. I have tried to optimize the database as well as perform a database cleanup on several occasions, which only temporarily makes things better.
I have even totally deleted the database and started fresh, which did solve the problem for a longer time but eventually resulted in the same result. I’m hoping someone can help me out here as I have not been able to figure this out. Attached our my logs.
I should add that I am able to play media from my devices on the network, but it does seem sluggish at times when loading the libraries. Also, this only happens on the dashboard, if I refresh my browser two or three times the dashboard will eventually show up.
