There was an unexpected error loading the Program Guide and more errors
@jpringle03 said:
I also noticed that it shows "1 Recording Now` on the DVR page but nothing is recording or being streamed.
It is possible that the issue may be to do with the message size / number of channels as it has only been seen when channels are about 600
Could you see if you can get me the lineup json using curl
The logs showed your tuner to be on local IP 192.168.7.96 - if that changed, please amend the curl command
curl http://192.168.7.96/lineup.json > lineup.json
Hey @sa2000,
I changed it to a TXT file format because it wouldn’t let me upload with the extension .JSON.
Thank you @jpringle03
I have been running Plex Media server on a Synology 416Play DSM 6.1.5. I have an HDHome Run Extend (latest firmware). The system has been quite stable and useful for 14+ months. Since March 30, 2018, DVR/EPG have been not working.
I have restarted my NAS twice. Stopped and restarted the Plex Media Server several times. I had been running 1.12.1. Deleted and tried to re-add my tuner but this does not work. It seems the EPG guide will NOT load. I un-installed PMS ver 1.12.1 and installed 1.11.3. This did NOT fix the issue. It seems like the EPG suppliers or the code for getting the EPG is changed or broken. Restarted HDHomeRun Extend tuner several times.
I have been through the “Add Tuner” process 4-6 times today. EPG loading feels very “brittle” and does not appear to be stable. Please note I am in Ontario, Canada using an off-air antenna. The total number of channels is 35.
Any help or advice would be appreciated. Thank you.!
There is a Cloudflare issue for Ontario, Canada affecting many users - see
http://forums.plex.tv/discussion/299084/epg-fails-to-update
@jpringle03 said:
Hey @sa2000,
The evidence shows a malformed json sent by Gracenote. This has been referred to Gracenote
@sa2000 said:
@jpringle03 said:
Hey @sa2000,
Sorry - I updated the wrong post. This February 2018 JSON error issue has already been resolved by Gracenote
@winding_river
Cloudflare had issues with certificates after some doman changes. It has now been routed to new IP addresses. Please try and report back.
Hopefully the problem for Ontario Canada users is now resolved.
This is happening to me now. I tried restarting the PC. I’m not in Canada, I’m near Minneapolis. What info do you need to troubleshoot?
Additional info:
It’s stuck at Refreshing EPG (10%)
Status is Opened connection to Plex , listening for events.
Plex version Version 1.12.3.4973
Homerun Prime details:
10.0.0.64:80
3 tuners
551 channels—371 enabled
Additional info:
10.0.0.64:80
3 tuners
To start with to investigate, ensure debug logging enabled on the server (settings - server - general - show advanced) , restart server to get fresh logs created. When refresh guide gets stuck, take a screenshot And download logs zip and attach both
For logs: settings - server - help - download logs
Thanks! I wasn’t sure which screen to get the screenshot from so I got the two I thought most likely needed. And here are the logs as well.
I’ll let @sa2000 handle this but wanted to throw in what I noticed in your logs right after the 10% EPG at 6:26 this morning:
112012 May 05, 2018 06:26:47.308 [16668] DEBUG - Network change.
112013 May 05, 2018 06:26:47.308 [16668] DEBUG - NetworkInterface: Notified of network changed (force=0)
112014 May 05, 2018 06:26:47.382 [16668] DEBUG - Network change notification but nothing changed.
112015 May 05, 2018 06:26:47.384 [16668] DEBUG - Network change.
112016 May 05, 2018 06:26:47.384 [16668] DEBUG - NetworkInterface: Notified of network changed (force=0)
112017 May 05, 2018 06:26:47.453 [16668] DEBUG - Network change notification but nothing changed.
When I search for all Network Interface messages in the log I see:
31002 May 02, 2018 02:23:57.042 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
33586 May 02, 2018 04:05:16.093 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
33589 May 02, 2018 04:05:16.120 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69726 May 03, 2018 02:53:35.715 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69729 May 03, 2018 02:53:35.823 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69732 May 03, 2018 02:53:35.959 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69841 May 03, 2018 02:53:45.351 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69847 May 03, 2018 02:53:57.745 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69850 May 03, 2018 02:53:57.847 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69853 May 03, 2018 02:53:57.966 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69860 May 03, 2018 02:54:08.434 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69863 May 03, 2018 02:54:15.717 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69866 May 03, 2018 02:54:15.817 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69869 May 03, 2018 02:54:15.874 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
69872 May 03, 2018 02:54:15.966 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
71079 May 03, 2018 04:05:41.331 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
71096 May 03, 2018 04:05:41.373 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
74269 May 03, 2018 07:45:34.614 [41348] DEBUG - NetworkInterface: Notified of network changed (force=0)
74627 May 05, 2018 03:49:28.425 [110724] DEBUG - NetworkInterface: Notified of network changed (force=0)
74629 May 05, 2018 03:49:28.437 [110724] DEBUG - NetworkInterface: ignoring adapter 'PIA' (fe80::746d:869:e2e2:ca73%16,10.11.12.6) because it has no gateway
74630 May 05, 2018 03:49:28.437 [110724] DEBUG - NetworkInterface: ignoring adapter 'Ethernet 3' (fe80::9c2d:abbe:6075:334a%4,169.254.51.74) because it has no gateway
74631 May 05, 2018 03:49:28.441 [110724] DEBUG - NetworkInterface: ignoring adapter 'Loopback Pseudo-Interface 1' (::1,127.0.0.1) because it has no gateway
108207 May 05, 2018 06:11:40.613 [110352] DEBUG - NetworkInterface: Notified of network changed (force=0)
108209 May 05, 2018 06:11:40.624 [110352] DEBUG - NetworkInterface: ignoring adapter 'PIA' (fe80::746d:869:e2e2:ca73%16,10.11.12.6) because it has no gateway
108210 May 05, 2018 06:11:40.624 [110352] DEBUG - NetworkInterface: ignoring adapter 'Ethernet 3' (fe80::9c2d:abbe:6075:334a%4,169.254.51.74) because it has no gateway
108211 May 05, 2018 06:11:40.631 [110352] DEBUG - NetworkInterface: ignoring adapter 'Loopback Pseudo-Interface 1' (::1,127.0.0.1) because it has no gateway
110885 May 05, 2018 06:26:22.306 [17388] DEBUG - NetworkInterface: Notified of network changed (force=0)
110887 May 05, 2018 06:26:22.312 [17388] DEBUG - NetworkInterface: ignoring adapter 'PIA' (fe80::746d:869:e2e2:ca73%16,169.254.202.115) because it has no gateway
110888 May 05, 2018 06:26:22.313 [17388] DEBUG - NetworkInterface: ignoring adapter 'Ethernet 3' (fe80::9c2d:abbe:6075:334a%4,169.254.51.74) because it has no gateway
110889 May 05, 2018 06:26:22.317 [17388] DEBUG - NetworkInterface: ignoring adapter 'Loopback Pseudo-Interface 1' (::1,127.0.0.1) because it has no gateway
116000 May 05, 2018 09:01:45.213 [5100] DEBUG - NetworkInterface: Notified of network changed (force=0)
116002 May 05, 2018 09:01:45.225 [5100] DEBUG - NetworkInterface: ignoring adapter 'PIA' (fe80::746d:869:e2e2:ca73%16,169.254.202.115) because it has no gateway
116003 May 05, 2018 09:01:45.226 [5100] DEBUG - NetworkInterface: ignoring adapter 'Ethernet 3' (fe80::9c2d:abbe:6075:334a%4,169.254.51.74) because it has no gateway
116004 May 05, 2018 09:01:45.231 [5100] DEBUG - NetworkInterface: ignoring adapter 'Loopback Pseudo-Interface 1' (::1,127.0.0.1) because it has no gateway
Looks like you might have some sort of networking issue but I’ll defer to @sa2000.
@johnm_ColaSC If you mean me (how do you reply to a post so at least part of it is quoted, BTW?) I use a VPN on occasion, that could be what the network changes are about. But I’m not on one today when I collected the info after restarting Plex Server.
The first part of the logs was right after the EPG refresh got to 10% this morning at 6:26. So something caused the network change this morning.
To quote part of a post click the quote link and then delete the parts you don’t want quoted.
In two hours, it progressed from 3% to 4%. Here’s the new logset. FYI I just checked my download speed, and it’s 174.0 Mbps.
Now it’s at 10%! So it’s not stuck. It’s just taking a long time. Is the progress normal?
It is doing all the updates for the Enhanced Program Guide
May 05, 2018 09:01:56.022 [16412] DEBUG - Activity: updated activity 7dcec86d-6f04-41b2-becf-fea9bff69a8e - completed 3% - Refreshing EPG
May 05, 2018 09:01:56.095 [16412] DEBUG - EPG[onconnect]: Enhanced 'Martha Bakes' show with universal details
May 05, 2018 09:01:56.114 [16412] DEBUG - EPG[onconnect]: Enhanced 'Lidia's Kitchen' show with universal details
May 05, 2018 09:01:56.126 [16412] DEBUG - EPG[onconnect]: Enhanced 'Sara's Weeknight Meals' show with universal details
May 05, 2018 09:01:56.132 [16412] DEBUG - EPG[onconnect]: Enhanced 'Cook's Country From America's Test Kitchen' show with universal details
May 05, 2018 09:01:56.139 [16412] DEBUG - EPG[onconnect]: Enhanced 'America's Test Kitchen' show with universal details
May 05, 2018 09:01:56.177 [16412] DEBUG - EPG[onconnect]: Enhanced 'Great American Railroad Journeys' show with universal details
etc
etc
May 05, 2018 09:30:46.136 [16412] DEBUG - EPG[onconnect]: Enhanced 'Mysteries at the Museum' show with universal details
May 05, 2018 09:30:46.152 [16412] DEBUG - EPG[onconnect]: Enhanced 'Bizarre Foods: Delicious Destinations' show with universal details
May 05, 2018 09:31:21.529 [16412] DEBUG - Activity: updated activity 7dcec86d-6f04-41b2-becf-fea9bff69a8e - completed 4% - Refreshing EPG
May 05, 2018 09:31:21.627 [16412] DEBUG - EPG[onconnect]: Enhanced 'Botched' show with universal details
May 05, 2018 09:31:21.647 [16412] DEBUG - EPG[onconnect]: Enhanced 'Sex and the City 2' movie with universal details
Can you try with the Enhanced Program Guide option disabled to see if it makes a big difference
Nailed it! I forgot I checked that, and had no idea it would produce such a dramatic slowdown.
