I’m using latest plexpass version
I noticed (but i’m pretty sure isn’t a new thing) that when Plex is looking for a serie in thetvdb, it removes the “-” charater from the serie name, with the result of not finding the show. You can check that going to manual match, letting it look for the serie, then looking at the search string. There you will se there is no “-” character. If you put it back and so a manual search, the serie will be found.
Example:
Folder named “Jashin-chan Dropkick” with an anime serie inside
Plex will not match it automatically
Going to manual match, it will search “Jashin chan Dropkick”, and wont find it
putting back the “-” will result in a match
