TV Shows - Matching of Title with TheTVDB.Com
Server Version#: 1.14.1.5488
Player Version#: 3.77.4
I came across two TV shows which I cannot match neither automatically nor manually. The TV shows are “Formel 1 - Drive To Success” and “M - Eine Stadt sucht einen Mörder”.
Whatever I name the shows, PLEX just doesn’t find them in TVDB. If I try to match them manually, PLEX doesn’t come up with any matches either.
Any thoughts?
Btw … why is there no such feature to just search for the TVDB series ID and link to that? That would simplify things extremely.
Folder Name:Formula 1. Drive to Survive (2019)
I had no issues matching this show. Plex scrappers match automatically without issue.
Folder name:M - A City Hunts a Murderer (2019)
The scrappers did not match this automatically. I had to do a manual search. It matched afterwards.
Folder name:M – Eine Stadt sucht einen Mörder (2019)
The scrappers did not match this automatically. I suppose this is due to my library being English and not German. I had to do a manual search. It matched afterwards.
Good luck.
You just edited your post. I don’t remember what it said many hours ago so I have nothing to compare with. You might what to reply in this thread instead of doing edits.
You still having problems?
Thank you for your response.
The edit did not change the content. I just added the last sentence.
With the folder name “Formula 1. Drive to Survive (2019)” Plex could automatically match the folder. How did you find out about the correct folder name? In both the english and german version of THETVDB it is written with a “-” instead of a “.”.
I could also solve “M - Eine Stadt sucht einen Mörder”. The issue was the “ö”. When replacing the “ö” by “oe” in both the folder and the filenames it worked out. Same here. How do you know what the correct folder name is?
stick that in the Title field when doing a fix match ( Search Options)
I always use the title name listed on thetvdb whenever possible. There are some that can’t be helped, particularly with anime and the famous show M*A*S*H. Just omit the “invalid” characters or replace with a “space” in cases like that.
Fate/Zero (2011)
M*A*S*H (1972)
Becomes
Fate Zero (2011)
M A S H (1972)
Many may argue the exact way and you will need to find the best method from all this.
What I can tell you is I name the folder as close to what’s on thetvdb to achieve an automatic match. And I’ll do The Plex Dance ™ to a series 10 time if needed to get plex to recognize the series automatically. I used to manual match stuff but after a few meltdowns and rebuilding plex and going through all the unmatch/incorrect matched stuff. No way, I’m done with that. I do not like to edit plex and would rather have everything just work without manual intervention.
