Thoughts on best way to proceed; erase or migrate
General request for advice.
Apologies in advance for my naivety, new to Plex, and I want to get this right.
Discovered PLEX a while ago, took the plunge and installed a few weeks ago to my iMac, which is currently the media server.
Following more research, I have purchased a NVIDIA Shield Pro 500gb, and I have a 10tb external hard drive to be attached.
Is it best / cleaner to erase the data (content, libraries etc) on my iMac, install and if in on the Shield, and start again with that as the server…?
Or… look to migrate from the iMac to the Shield…?
There is a lot of advice and different methods for each, and I’m unsure what is best, then the best way to action.
Also, on the shield, I understand I can set the 10tb external drive to remain as external, or allow it to think it’s an internal drive.
Thanks in advance for your help. Any links in your reply, would be great, and I can follow those for step-by-step guidance.
Cross-platform migrations are not impossible but can be tricky – especially on devices like the Shield where you don’t have immediate/easy access to the server data directory.
In theory you can setup your new server on the Shield and configure it to move the server data directory to your external drive. Once this is done, stop the server and copy the old data directory over.
e.g. like this:
Here’s a bunch of guides for the Shield
https://support.plex.tv/articles/categories/plex-media-server/nvidia-shield/
Hi tom80H.
Thanks so much. I’m really grateful for your advice.
I’m a bit of a planner, wanting to make sure any setup is as future-proof for my requirements as I can, and can foresee… I jumped a bit quick with the excitement of what PLEX offers… lesson learned.
I’ll give these links a read, and discard the prior ones I’ve bookmarked, often too much information is worse then none… and I think I had started to confuse myself and probably mixing processes… which wouldn’t be great on any level.
Thanks again. :+1::+1::+1:
I’ll add my opinion which I’m sure others may disagree with. I’d suggest using your devices with what they are primarily designed for.
The Shield is an amazing streaming device but depending on your use case, how large you grow your plex library etc… overtime plex as a server on the shield may just not cut it.
There has been so many threads over the years of folks with problems with plex on shield and usually its due to folks expecting it work as good as a PC, it won’t.
I’d always recommend MAC/Windows/Linux (whatever your PC preference is) to run plex media server on. This is server software so best to run on something it will run well on. If you have a dedicated GPU all the better :slight_smile:
Then use a good stream device, like the shield you have. Store your media NAS or directly plugged in external drivers to whatever is running plex.
Anyhow, something to consider.
Hey. Thanks dokuro.
It is like everything, the more you canvass opinion, the ,ore opinions you get.
I had read about this community though, as a resource of great tips and tricks… lots to be learned.
My library at present is 3tb. But the ā€˜need’ to actually have the item has faded. Like with music I guess. Hardly Amoy one buys the physical copies of a release anymore, except the hardcore fans.
I was looking at NAS, but it’s a confusion arena unless you really know what you are doing, and it’s a bit out of my price range at the moment, as it’s seems like a military grade investment… but the power it can yield is substantial.
I’m going to gather thoughts from all that reply, and then get the advised research done. I don’t want to progress any further, if I’m going to need to undo it all.
I used to understand all these things when my brain was younger and more agile… now it’s feeling more and more like magic. :shushing_face::rofl::rofl::rofl:
NP. I tend not to over thing the NAS. I use my NAS purely for storage so when I got it I made sure it had good NAS specific disks (WD Red in my case) and got the most I could afford.
I will NEVER EVER install plex on the NAS. This path leads to the dark side and will over time run into problems with any large plex libraries.
As I said earlier, IMO… plex server on a pc, NAS for storage of your media (or external drives) and then a good streaming device. If you can afford that then IMO this is the best setup.
If you want something smaller than plex on shield + attached drive will most likely be okay, for smaller libraries.
The most important things to be aware of for using shield as a server are @
A shield is closer in power to a phone, than a nas or laptop or full pc.
If you expect to remain within the limits of the shield server, by all means take advantage of it.
Just be aware, if you expect to have a large or expanding media collection, you may quickly out grow the device hardware.
Amazing. Thanks again.
I think long term, NAS is the way to go, also for backups of my iMacs and MacBook, but currently broke… so it’s back to saving pennies and seeing how soon I can take that kind of leap. By then, I’ll probably be needing to upgrade from the shield Pro. I currently have shout 3tb of media. Excluding music, that I don’t think I’ll migrate over to PLEX anyway, as I’m pretty happy with my HomePod set up.
Thanks again for your guidance
Cool. Will keep that in mind. My media has stabilised of late, hovering around 3tb. The external hard drive which will be attached to the shield pro is a 10tb. So, I’ve got sone growth availability.
Just an aside question, I’m guessing when I configure the shield I say yes to the external drive being treated as if it’s internal…? Or say external, ie mountable…?
For media you normally want external.
If you start to fill up the internal storage (ie with plex metadata), you would want to use format for internal/applications data (different than media storage).
Ok. Cool.
So as the external 10tb HD will hold copies (not my originals, as all of those are within my iTunes / iMac system), then I can say ā€˜configure this external drive as if it were internal’, the Shield does the rest.
Following the ā€˜considerations’ from the group, and had looked at it previously… I have been also researching the NAS option and associated kit. I’ve had a few issues with my broadband, and I want to make sure that’s now stable and running at its optimum (Looks like I’ll need to invest in a new router, rather than my BT supplied ā€˜hub’, so will take the Wi-fi 6 route, to try and slightly and short-term ā€˜future proof’. Then, once that’s done, and the expense replenished NAS may be on the horizon. But, it’s going to be a while off.
Everyone has been very kind and shared their thought and guidance, with no hard sell ā€˜you must do this’, just knowledgeable sight of what works (or would work) best.
THANK YOU. :+1::+1::+1:
… and so, my reading, and reading, and reading continues. :thinking::relieved::+1:
honestly I would recommend a separate SSD for being formatted internal, and just leave the media drive formatted as ntfs/mac so that it can be transferred/used on your other devices if/when needed.
AFAIR formatting as internal, means the drive must be permanently attached to the shield.
it may also complicate adding/removing/managing media on the drive (assuming media can even be used on an internally formatted drive, I do not know for sure).
Blimey, another format type. I’d never heard of AFAIR. I can see how powerful PLEX is, and is a dream as long as it’s configured correctly, with planning being key, or live with a messy library.
Thanks for this advice also re the internal ā€˜ external thing. Looks like I’m owing you many pints :beers: :beers: :beers:
sorry, AFAIR is short for ā€œas far as I rememberā€
similar to AFAIK is ā€œas far as I knowā€
in any case, I would advise to thoroughly research (google), and if you have extra drives, use them to experiment to make sure you can set up how you want before you make any final commitment.
