Threads vs Clock speed for transcoding
So whats better for a Plex server, more threads or higher clock speed?
A Xeon E5-2650 v3 @2.1Ghz 10 core/20 threads. Average CPU benchmark of 14951, single thread 1691 or
An i7-7800X @3.5Ghz 6 core/12 threads. Average CPU benchmark of 14586 (so similar), single thread 2228
Might be worth mentioning that the Xeon is currently £140 vs £380 for the i7.
The Xeon has 25Mb cache vs 8.25 on the i7 - not sure what effect that has.
You should be OK with either one, unless you demand transcoding of 4K HEVC videos from it.
Both are above the critical single thread rating of 1350 points, which is required in the worst case of ‘BluRay rip with VC-1 video and PGS subtitles’.
How the cpu will be performing when you feed them HEVC video?
There is still not enough experience collected for that.
My advice: avoid HEVC unless you have clients which can ‘Direct Play’ that.
You can pick up alot of second hand Xeon chips that were 1000 dollar chips at one point. They are server grade so pretty hardy and the motherboards, typically 2011v3 have alot of extras.
Does anyone have any real world experience?
If you have a higher clock Speed does the movie start faster?
Look up those CPUs on https://www.cpubenchmark.net/ and avoid those with a ‘single thread rating’ below of 1350 points.
Older Xeons perform magnificently as web or database servers,
but sometimes not so magnificently as Plex transcoders.
There are quite some threads on this very forum from people who thought they bought something good, only to be told that these CPUs are not so optimal for Plex.
Do also take a look at the power draw of those old machines and their noise emissions.
In a data center, noise is not an issue - but in your home or office…
