Tiny Bug Found on Edge Broswer
In the plex web portal under account, when you click “choose photo” then hit cancel on the file browser that appears, the file browser re opens again in an infinite loop. I had to force close the running browser process to get the file browser window to go away.
This error appears in Microsoft Edge Browser, latest stable version 38.14393.0.0, no addons/extensions installed, in windows 10 on localhost.
I have tested it in chrome (latest stable) and the file browser closes properly.
Just wanted to submit this little bug I found. :slight_smile:
_ EDIT _
Forgot to mention the plex server is running version 1.3.3.3148
Bug confirmed. Thanks for the report!
Was the bug really in Plex, or was it yet another Edge bug that you’re having to code around?
At my work, Edge is so problematic as to be virtually useless. As an IT department, we tell people to not use it. In my separate personal and consulting experience, I also find I cannot advise its use due to all its issues and Microsoft’s horrible track record with browsers.
