TMDB metadata agent with files not on IMDB
On TMDB but no IMDB ID
I'm on mac OS X 10.7.4, Plex server 9.6.1 and client 9.5.3
I just have problems with somes files who are on the TMDB but not on IMDB.
So there are no IMDB ID and the metadata agent don't find them.
I know it works with the last version of XBMC. No problem with them.
What can I do ?
Thx in advance
There is a TMDB standalone agent that should help you with this special case. : have a look there : http://forums.plexapp.com/index.php/topic/22094-themoviedb-standalone-agent/
Solved.
Ca marche !
Je te remercie. Beau boulot !
:slight_smile:
I will add that if you have that agent installed, you can set a section to use Freebase, and then use “Match Using” to have the other agent match a file which doesn’t match on Freebase.
