This release improves upon the new Music mode, includes lots of adjustments that make automatic matching of episodes/subtitles even better. The GUI will now allow you to rename valid entries despite one or more conflicting entries in the batch.
Features:
New music bindings: {n} {y} {t} {d} {pi} {pn}
Allow renaming despite conflicting entries as far as possible
Improved episode matching esp. for generic patterns
Improved subtitle auto-matching
Clear cache via Ctrl+Shift+Delete
Changes / Fixed Issues:
Formatting can now access rename context, added bindings {i} index, {di} duplicate index
Better samples for the format expression testing environment
Detect IMDbID from .url files
No more DBUS warnings on headless machines
Limit cache to 2 days to avoid episode mismatches caused by outdated episode lists
Update: µTorrent Integration
enforce well-formed and nicely formatted xml in .nfo files
Hi Rednoah. I've been looking at FileBot and want to setup the automatic 'watcher' script. Wondering if you could please explain how to install this, as I'm a bit of a noobie with this stuff.
I'm on a mac, have installed FileBot, but don't know how/where to add the groovy script. Do I have to use Transmission in order to activate it? Would like to just attach as a folder action on the completed download folder
**FileBot 3.5** [Get it here!](http://www.filebot.net/#download)
This release features many improvements to movie and episode detection and lots of little UI enhancements like being able to set and unset OpenSubtitles and Sublight login credentials.
**Features:**
+ Allow setting up OpenSubtitles and Sublight username/password via the GUI
+ Lots of small GUI and deployment enhancements
+ Improved movie / series detection
+ Improved episode numbers matching
+ Allow processing of specific sets of files by dropping in .txt files with paths
+ Added .ISO and .3DSBS as video file extensions
**Changes:**
* Manage AniDB index files myself and set AniDB API cache to 2 weeks as to reduce load on AniDB servers
* [Windows] Replace filebot.cmd script with launch4j filebot.exe console application for improved JRE auto-detection
* [Linux] Fixed network issues caused by missing gnome libs
* [Embedded Linux] .ipk installs to /opt by default now
*Update: Automated Media Center*
* Fine-tuned movie / series differentiation rules
* Various adjustments to the default formats
* Improved xbmc integration
* Allow user-defined post-processing via --def exec=command
FileBot 3.6 [Get it here!](http://www.filebot.net/#download)
This release brings lots of improvements for automated processing and a few new features requested by the community.
Features:
+ GUI Rename will allow you to override files now
+ Improved movie detection and auto-selection
+ Improved series detection esp. for US/UK or 2005/2009 version of the same series
+ Improved episode matching taking into account series popularity and episode airdates
+ Cmdline options --log-file and --log-lock to streamline cmdline usage esp. with the Automated Media Center scripts
+ Cmdline option --mode rename|subtitles|sfv to launch with minimum UI
Changes:
* Press ALT+DELETE to delete items from one of the lists rather then a line from both
* More strict AniDB flood-protection limits
* Improved movie / episode differentiation
* Recursive extract archives
* Strict subtitle matching by default
FileBot 3.61 is out! [Get it here!](http://www.filebot.net/#download)
This update brings lots of little tweaks for movie and episode detection and fixes various issues that have come up since the last release.
Changes:
* Many little tweaks for movie/series/episode matching and detection
* Improved filename validation as trailing spaces or dots cause issues on Windows
* Some tweaks for -non-strict behaviour
* Removed Sublight and Subscene because currently things are broken and can't be fixed without working APIs
* GUI does not allow override behaviour anymore as to avoid users inadvertently overriding files
Don't know if this is old or what, but I'm confused as to why this costs $3 in the Ubuntu Software Center but is free for the other platforms. Also, since I'm running Ubuntu Server, is there a way to download it via apt-get?
**FileBot 3.8 is out!** [Get it here!](http://www.filebot.net/#download)
This new major release brings new support for uploading subtitles and renaming music videos as well as updates to GUI and episode/movie matching that'll make things work much more smooth.
**Changes:**
* Support for OpenSubtitles Subtitle Upload (experimental)
* Support for music videos in Audio mode (may require chromaprint-tools 1.0 or higher)
* Support for alias names in matching and naming
* Improved Episode matching and Series detection
* Improved Movie detection
* Improved User guidance
* Improved caching and cache updates
* Format Editor with full Groovy syntax highlighting (thanks to RSyntaxTextArea)
* Calling with -clear-cache or -clear-prefs will now clear & exit
* Support --filter expressions in Movie mode
* Exclude list check/update support (i.e. ignore files that have already been processed in previous runs)
* Fix TheMovieDB artwork API issues
* New little utility to help with escaping arguments
+1 vote for FileBot - it's a freaking epic little program.
Rednoah is also really active on the FileBot forums and quick to fix any issues encountered. :-)
As I fail to understand the concept of a 'Holiday', I've also written a few scripts to extend FileBot's functionality in Windows - they can be found on the FileBot forums:
Edit: @mAAdhaTTah - I think that's mostly as an option for people who want to help support the development. I think that there were/are plans to add some extra features for the paid/donation variants, but you can always download it for free (for multiple platforms) from the FileBot home page. Also, once it's installed, all you ever really need to update is FileBot.jar, which is available straight from SourceForge.
**FileBot 4.0 is finally out!** [Get it here!](http://www.filebot.net/#download)
This new major release comes with massive improvements in all the core functionalities and lots of bugfixes. It's smarter, faster, superior in every aspect and generally more streamlined to get things done fast and exactly the way you want.
**Features:**
* Massively improved subtitle lookup and auto-selection
* Improved fault-tolerance for OpenSubtitles
* Improved local index and handling of alias names
* Open Episode/Movie matches with the Format Editor (via double-click)
* Support subtitle naming preferences
* Support fetching episode list directly from Rename panel
* Series auto-completion in Episodes panel
* Meta-Attributes Tool in Analyze panel
* Performance improvements for series, movie and subtitle auto-detection
Hey Rednoah, thanks for an amazing app. I'm on Mac OS X Maverick. On version 4 the app is not starting- when I double click the app it fails to start. I get this in console:
3/14/14 11:40:33.259 PM Finder[196]: 8837325: Attempting to SIGCONT to pid #559 failed, with errno=#3, or the process failed to actually start
Any solution to this? I have had previous versions work.
Yes. But you'll need to call filebot from cmdline.
I'm running FileBot on my DS213j just fine. You just need to get Java working, then FileBot will work as well. There's some optional features like extract and mediainfo that may not work if it's an ARM or PPC device.
**FileBot 4.1 is out!** [Get it here!](http://www.filebot.net/#download)
This new major release comes with massive improvements in all the core functionalities and lots of bug fixes. It's smarter, faster, superior in every aspect and generally more streamlined to get things done fast and exactly the way you want.
**Features:**
* Fix Windows/Linux/Samba permission issues
* New Mac OS X app bundle (now requires Oracle Java 8)
* Support xattr metadata on Mac OS X
* Faster FileBot / Groovy Script Engine
* Improved series / movie detection for various special cases
* Fix various OpenSubtitles Upload/Download issues
* Improved detection of existing subtitles in -get-missing-subtitles
* Support for Java 8
* Improved steps for {vf}
* New binding {age} for age in days
* New binding {label} which is only available if --def ut_label has been set (see amc usage)
* PushBullet supported (see amc usage)
**Changes:**
* Drop support for Java 6 (i.e. Apple Java 6 is no longer supported)
* Strict OpenSubtitles search is limited to hash/tag lookup now
* Enable xattr support by default for all packages
* New xattr structure and namespace
* Update to Groovy 2.3.2
The Pushbullet notification function is really sweet, but i received three notifications with only one download (might be because filebot treated the file and also downloaded 2 subtitles from opensubtitles). Am I doing something wrong?
Also, is there a way to change the name of the notification in filebot?
I downloaded the latest version and it no longer works on OS X 10.6.8. Has support for Snow Leopard been dropped?
FileBot 4.1 is out!Get it here!This new major release comes with massive improvements in all the core functionalities and lots of bug fixes. It’s smarter, faster, superior in every aspect and generally more streamlined to get things done fast and exactly the way you want.Features:* Fix Windows/Linux/Samba permission issues* New Mac OS X app bundle (now requires Oracle Java 8)* Support xattr metadata on Mac OS X* Faster FileBot / Groovy Script Engine* Improved series / movie detection for various special cases* Fix various OpenSubtitles Upload/Download issues* Improved detection of existing subtitles in -get-missing-subtitles* Support for Java 8* Improved steps for {vf}* New binding {age} for age in days* New binding {label} which is only available if --def ut_label has been set (see amc usage)* PushBullet supported (see amc usage)Changes:* Drop support for Java 6 (i.e. Apple Java 6 is no longer supported)* Strict OpenSubtitles search is limited to hash/tag lookup now* Enable xattr support by default for all packages* New xattr structure and namespace* Update to Groovy 2.3.2
