Top Gear specials
Hi, how to name the specials for top gear, i got several files with name and year in a separate folder called featers. I got al the the seasons in separated folders with files named correctly with e.x: TopGear S14E01.mkv and so on
How to get the specials in the correct season, some seasons content several spesials episodes. Any body that can help me with naming them correctly?
Best regards
Stein Idar Aasen
Norway********
Tvshow/
Top Gear/
Featers/
50yearsofbondcars(2012.mkv
Goodthebadtheugly(2006).mkv
Greatestmoviechases(2007).mkv
Heavenandhell(2005).mkv
Hotmetal(2004).mkv
Italianjob(2010).mkv
Supercarshowdown(2007)
Worstcarinthehistiryoftheworld(2012).mkv
Poweresup(2011).mkv
Thriller(2008).mkv
Apocalypse(2010).mkv
Atthemovie(2011).mkv
Season 1/
Season 22/
Specials are season 0 but can reside in a “Specials” or “Season 0” folder, you cannot insert them in the right season.
Same as the metadata agent you chose when creating the library, most likely thetvdb. Use the following season 0 episode numbers
http://thetvdb.com/?tab=season&seriesid=74608&seasonid=22070&lid=7
