Top lists bug?
I love that I can check within the app my most played artists and albums. However I found that when I filter by “monthly” I can see my top plays for May and June (I installed plexamp in May so I can’t go further back in time). When I go to “June” I can see that the list is changing, but in the heading it’s still showing “May”.
Also when I filter “Seasonal”, I can check “Spring 2020”, and the next is “Winter 2020”. What happened to Summer? :smiley:
Version 3.1 / macOS and iOS.
(This is based on server, not the app per se.)
Will fix the buglets, thanks for the report!
Should be fixed now.
It is :+1: Thank you!
