Best Of... does the not go earlier than 1970s
Do the following:
  1. Using plexamp select the search icon.
  2. Then select Best Of…
  3. Change search filter to decade.
  4. Scroll back to 1970s an then attempt to go back to 1960s.
Result:
You can’t.
If I’d to guess this could be a side effect of the relevantly recent epoch timestamp format changes which plexamp is having trouble with. Before 1970 would be negative numbers.
I can’t recreate the bug.
What’s your server version?
Seems to be working for me
Edit: too slow…
Version 1.28.0.5998 of the server. Plexamp is on android.
Music library was only created approx 18 days ago so it’s newish. Let me also double check a track has played from before 1970 :grin: Pretty sure a few have but let me check the metadata to be sure.
It’s about albums, not tracks. Plex doesn’t store track dates. Only album dates.
Okay, checked quickly and an album from 1967 has played.
Took a peek at the plexamp logs … here is an extract and you can see the year filter requests year>=1990&year<=1999 etc… as I switch years but then when I select 1960s it reports a warning and on the UI in plexamp it does not switch.
Jul 24, 2022 10:59:59.176 [0xc71f1cb0] DEBUG - Networking: Create request 59: (GET https://192-168-1-3.a7135761cbf2469eb3e49b82715a526d.plex.direct:32400/library/sections/3/all?type=9&year>=1990&year<=1999&group=guid&sort=viewCount:desc&viewCount>=0&limit=26&includeFields=thumbBlurHash&X-Plex-Device-Name=Android).
Jul 24, 2022 10:59:59.286 [0xcfedccb0] DEBUG - Networking: Completed request 59: (GET https://192-168-1-3.a7135761cbf2469eb3e49b82715a526d.plex.direct:32400/library/sections/3/all?type=9&year>=1990&year<=1999&group=guid&sort=viewCount:desc&viewCount>=0&limit=26&includeFields=thumbBlurHash&X-Plex-Device-Name=Android) with code 200 (have 56665 bytes) in 110 ms.
Jul 24, 2022 10:59:59.487 [0xc71f1cb0] DEBUG - Networking: Create request 60: (GET https://192-168-1-3.a7135761cbf2469eb3e49b82715a526d.plex.direct:32400/library/sections/3/all?type=9&year>=1980&year<=1989&group=guid&sort=viewCount:desc&viewCount>=0&limit=26&includeFields=thumbBlurHash&X-Plex-Device-Name=Android).
Jul 24, 2022 10:59:59.596 [0xcfedccb0] DEBUG - Networking: Completed request 60: (GET https://192-168-1-3.a7135761cbf2469eb3e49b82715a526d.plex.direct:32400/library/sections/3/all?type=9&year>=1980&year<=1989&group=guid&sort=viewCount:desc&viewCount>=0&limit=26&includeFields=thumbBlurHash&X-Plex-Device-Name=Android) with code 200 (have 17410 bytes) in 108 ms.
Jul 24, 2022 10:59:59.865 [0xc71f1cb0] DEBUG - Networking: Create request 61: (GET https://192-168-1-3.a7135761cbf2469eb3e49b82715a526d.plex.direct:32400/library/sections/3/all?type=9&year>=1970&year<=1979&group=guid&sort=viewCount:desc&viewCount>=0&limit=26&includeFields=thumbBlurHash&X-Plex-Device-Name=Android).
Jul 24, 2022 10:59:59.965 [0xcfedccb0] DEBUG - Networking: Completed request 61: (GET https://192-168-1-3.a7135761cbf2469eb3e49b82715a526d.plex.direct:32400/library/sections/3/all?type=9&year>=1970&year<=1979&group=guid&sort=viewCount:desc&viewCount>=0&limit=26&includeFields=thumbBlurHash&X-Plex-Device-Name=Android) with code 200 (have 7326 bytes) in 100 ms.
Jul 24, 2022 11:00:05.820 [Javascript] WARNING - The reactive render of an observer class component (AboutScreen)
                was overriden after MobX attached. This may result in a memory leak if the
                overriden reactive render was not properly disposed.
Jul 24, 2022 11:00:05.822 [Javascript] WARNING - The reactive render of an observer class component (AboutScreen)
Full logs attached if its helpful for dev.
329228647148.zip (112.3 KB)
@OttoKerner @tom80H are either of you on android using a mobile client ?
I’m using Plexamp on Android mobile.
I don’t think that the lines with the error have anything to do with the lines before.
Really. They are 5 seconds after the previous ones and at exactly the same time I’ve tried to select 1960s in the UI. Anyhow, I’ll just live with it being broken for me.
BTW… uninstall and reinstall of the app makes no difference in case someone might have suggested trying that.
Still getting this even with plexamp v4.5. Anyone any idea how to debug this? As a test I tried a complete rebuild of server and could still reproduce it.
What does it mean “you can’t [go back]”?
Do you mean that the decade number stays on “1970”?
Or do you mean that you simply don’t get any albums displayed?
If I go back to the 1890s, I simply get an empty page (with Plexamp-typical snark on it).
Yes, that’s what happens. When I open up Best Of… its default page is 2020s so I select the < link to go back. I can go back 2010s etc… all the way to 1970s but when I try again nothing happens. It does not go to 1960s.
Interestingly if when I’m on the 1970s page if I then try and select > to go to 1980s that also now does not work. Basically, the < and > links no longer work once I’m on the 1970s page.
I’m using plexamp v4.5 for android on a Samsung S21 mobile.
