Trailer Not Available
Will someone kindly help me with Plex Connect? It keep saying trailer not available. Any input will be appreciated.
Thank you,
--Al
14:36:19 PlexConnect: ***
14:36:19 PlexConnect: PlexConnect
14:36:19 PlexConnect: Press CTRL-C to shut down.
14:36:19 Settings: add setting enable_plexgdm=True
14:36:19 Settings: add setting ip_pms=192.168.178.10
14:36:19 Settings: add setting port_pms=32400
14:36:19 Settings: add setting enable_dnsserver=True
14:36:19 Settings: add setting port_dnsserver=53
14:36:19 Settings: add setting ip_dnsmaster=8.8.8.8
14:36:19 Settings: add setting prevent_atv_update=True
14:36:19 Settings: add setting enable_plexconnect_autodetect=True
14:36:19 Settings: add setting ip_plexconnect=0.0.0.0
14:36:19 Settings: add setting hosttointercept=trailers.apple.com
14:36:19 Settings: add setting port_webserver=80
14:36:19 Settings: add setting enable_webserver_ssl=True
14:36:19 Settings: add setting port_ssl=443
14:36:19 Settings: add setting certfile=./assets/certificates/trailers.pem
14:36:19 Settings: add setting loglevel=Normal
14:36:19 Settings: add setting logpath=.
14:36:19 PlexConnect: started: 14:36:19
14:36:19 PlexConnect: Version: 0.4+
14:36:19 PlexConnect: Python: 2.7.5 (default, Mar  9 2014, 22:15:05)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
14:36:19 PlexConnect: Host OS: darwin
14:36:19 PlexConnect: IP_self: 192.168.1.83
14:36:19 DNSServer: started: 14:36:19
14:36:19 DNSServer: Failed to create socket on UDP port 53: [Errno 48] Address already in use
14:36:19 PlexConnect: DNSServer not alive. Shutting down.
14:36:19 PlexConnect: Shutting down.
14:36:19 PlexConnect: shutdown
=> WIKI/Toubleshooting
I have bad eyes Thanks Baa! ....fixed!!!! :D
