Trailers is unavailable. Try again Later
Hi, I have instaled Plex pms and pexconnect on Linux mint 16 and have problem with  plexconnect. When I try to hit Trailers I get the dreaded "Trailers is unavailable. Try again Later". On the console it just says "intercept request" and goes nowhere. Here is all the detail, I hope someone can help. Thanks.
The DNS server set on the ATV : 192.168.1.254
The local IP of Plex media server and PlexConnect is installed on: 192.168.1.254
The device and OS Plex media server and plexconnect is installed on: Computer running Linux Mint 16
The Plex media server version: 0.9.8.18
The PlexConnect version number: 0.3.1+
The contents of your 'Settings.cfg' file:
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 192.168.1.254
certfile = /home/ronny/PlexConnect-master/assets/certificates/trailers.pem
#ip_dnsmaster = 8.8.8.8
ip_dnsmaster = 192.168.1.1
normal loglevel = High loglevel = On
enable_dnsserver = True
logpath = .
enable_plexgdm = False
#ip_pms = 192.168.1.254
ip_pms = 192.168.178.10
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
loglevel = High
The contents of the 'PlexConnect.log' file:
09:11:18 PlexConnect: started: 09:11:18
09:11:18 PlexConnect: Version: 0.3.1+
09:11:18 PlexConnect: Python: 2.7.5+ (default, Sep 19 2013, 13:48:49)
[GCC 4.8.1]
09:11:18 PlexConnect: Host OS: linux2
09:11:18 Settings: getsetting enable_plexconnect_autodetect=True
09:11:18 PlexConnect: IP_self: 192.168.1.254
09:11:18 Settings: getsetting hosttointercept=trailers.apple.com
09:11:18 Settings: getsetting port_webserver=80
09:11:18 Settings: getsetting enable_dnsserver=True
09:11:18 DNSServer: started: 09:11:18
09:11:18 Settings: getsetting port_dnsserver=53
09:11:18 Settings: getsetting ip_dnsmaster=192.168.1.1
09:11:18 Settings: getsetting prevent_atv_update=True
09:11:18 DNSServer: ***
09:11:18 DNSServer: DNSServer: Serving DNS on 192.168.1.254 port 53.
09:11:18 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.254
09:11:18 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
09:11:18 DNSServer: forward other to higher level DNS: 192.168.1.1
09:11:18 WebServer: started: 09:11:18
09:11:18 Settings: getsetting enable_webserver_ssl=True
09:11:18 Settings: getsetting port_ssl=443
09:11:18 Settings: getsetting certfile=/home/ronny/PlexConnect-master/assets/certificates/trailers.pem
09:11:18 WebServer: ***
09:11:18 WebServer: WebServer: Serving HTTP on 192.168.1.254 port 80.
09:11:18 ATVSettings: init class CATVSettings
09:11:18 ATVSettings: load settings
09:11:18 WebServer: WebServer: Serving HTTPS on 192.168.1.254 port 443.
09:12:30 DNSServer: DNS request received!
09:12:30 DNSServer: Source: ('192.168.1.11', 64341)
09:12:30 DNSServer: Domain: trailers.apple.com
09:12:30 DNSServer: ***intercept request
09:12:30 DNSServer: -> DNS response: 192.168.1.254
09:24:01 DNSServer: DNS request received!
09:24:01 DNSServer: Source: ('192.168.1.11', 54170)
09:24:01 DNSServer: Domain: itunes.apple.com
09:24:01 DNSServer: ***forward request
09:24:01 DNSServer: -> DNS response from higher level
09:44:42 DNSServer: DNS request received!
09:44:42 DNSServer: Source: ('192.168.1.11', 59773)
09:44:42 DNSServer: Domain: trailers.apple.com
09:44:42 DNSServer: ***intercept request
09:44:42 DNSServer: -> DNS response: 192.168.1.254
Certificate correctly installed on aTV?
Thansk for the replay. :) Yes, as far as I know. I used the usb method with a laptop running windows 8, and I could see it under devices on aTv. I have used plexconnect when I was running windows 8 with no problem, but now I has moved to Linux. Plexconnect is the only thing I haven't get workin on Linux <_< . Hope you can help me :) .
