Trailers and Extras only showing on few movies
I’ve tried a lot of guides posted in the forums but nothing is working. I’ve even deleted and created a new library, but still I can only see trailers and extras on a few movies. Not all.
Help please.
  1. Your server needs to be signed in to your plex account for which you have the Plex Pass
  2. Plex needs to actually recognise your movies to fetch trailers.
  3. The ‘Plex Movie’ agent must be active, either as the movie library’s default agent or as an additional datasource for TheMovieDatabase.
    Settings - Server - Agents - Movies - TheMovieDatabase <- ‘check’ the line ‘Plex Movie’
  4. if you are using a 3rd party agent, like the “.nfo importer”, there are no automatic trailers available
Post the XML info of one of your movies without trailers.
    Settings - Server - Agents - Movies - TheMovieDatabase ← ‘check’ the line ‘Plex Movie’
Here’s the XML
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="1" librarySectionTitle="Películas" librarySectionUUID="595e817f-7132-4e0d-9a18-11fa8b53721d" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1475584302">
<Video ratingKey="72" key="/library/metadata/72" guid="com.plexapp.agents.imdb://tt0381849?lang=en" librarySectionID="1" studio="Tree Line Films" type="movie" title="3:10 to Yuma" contentRating="R" summary="Rancher Dan Evans heads into Bisbee to clear up issues concerning the sale of his land when he witnesses the closing events of a stagecoach robbery led by famed outlaw Ben Wade. Shortly thereafter, Wade is captured by the law in Bisbee and Evans finds himself one of the escorts who will take Wade to the 3:10 to Yuma train in Contention for the reward of $200. Evans's effort to take Wade to the station is in part an effort to save his land but also part of an inner battle to determine whether he can be more than just a naive rancher in the eyes of his impetuous and gunslinging son William Evans. The transport to Contention is hazardous and filled with ambushes by Indians, pursuits by Wade's vengeful gang and Wade's own conniving and surreptitious demeanor that makes the ride all the more intense." rating="6.7" year="2007" tagline="Time waits for one man." thumb="/library/metadata/72/thumb/1477278788" art="/library/metadata/72/art/1477278788" duration="7350633" originallyAvailableAt="2007-09-07" addedAt="1473636161" updatedAt="1477278788" chapterSource="">
<Media videoResolution="1080" id="72" duration="7350633" bitrate="1989" width="1920" height="800" aspectRatio="2.35" audioChannels="2" audioCodec="aac" videoCodec="h264" container="mp4" videoFrameRate="24p" optimizedForStreaming="1" audioProfile="lc" has64bitOffsets="0" videoProfile="high">
<Part accessible="1" exists="1" id="72" key="/library/parts/72/1473636161/file.mp4" duration="7350633" file="E:\Video\Peliculas - Ver\310 to Yuma (2007)\310 to Yuma (2007).mp4" size="1827586441" audioProfile="lc" container="mp4" has64bitOffsets="0" optimizedForStreaming="1" videoProfile="high">
<Stream id="687" streamType="1" default="1" codec="h264" index="0" bitrate="1893" bitDepth="8" cabac="1" chromaSubsampling="4:2:0" codecID="avc1" duration="7350508" frameRate="23.976" frameRateMode="cfr" hasScalingMatrix="0" height="800" level="40" pixelFormat="yuv420p" profile="high" refFrames="5" scanType="progressive" streamIdentifier="1" width="1920"/>
<Stream id="688" streamType="2" selected="1" default="1" codec="aac" index="1" channels="2" bitrate="92" audioChannelLayout="stereo" bitrateMode="vbr" codecID="40" duration="7350633" profile="lc" samplingRate="48000" streamIdentifier="2"/>
<Stream id="234" key="/library/streams/234" streamType="3" codec="srt" language="English" languageCode="eng" format="srt"/>
<Stream id="235" key="/library/streams/235" streamType="3" codec="srt" language="Español" languageCode="spa" format="srt"/>
<Stream id="233" key="/library/streams/233" streamType="3" codec="srt" format="srt"/>
</Part>
</Media>
<Genre id="292" tag="Western"/>
<Director id="1087" tag="James Mangold"/>
<Writer id="14" tag=""/>
<Producer id="19" tag=""/>
<Role id="1088" tag="Russell Crowe" role=""/>
<Role id="1089" tag="Christian Bale" role=""/>
<Role id="1090" tag="Logan Lerman" role=""/>
<Role id="1091" tag="Dallas Roberts" role=""/>
<Extras size="0"></Extras>
</Video>
</MediaContainer>
@patozf said:
Here’s the XML
OK, this shows that 4) is not relevant and 1), 2) and 3) are fulfilled - so everything is as it should be.
Make double sure you have the following option ‘checked’:
Settings - Server - Agents - Movies - Plex Movie - options of the Plex Movie agent (click on the ‘cog wheel’ icon at the right end of the line) “Find trailers and extras automatically (Plex Pass required)”
  1. activate debug logging (not ‘verbose’!)
  2. quit Plex Server
  3. wait 1 minute
  4. empty the log folder
  5. start Plex Server
  6. wait 2 minutes
  7. either refresh one movie separetely, Make sure your internet connection is not saturated during the refresh.
  8. wait 5 minutes, then check the preplay page of the movie again for trailers
  9. repeat 7)+8) for 2 other movies
  10. shut down Plex server
  11. wait 1 minute
  12. zip up the whole log folder and attach it here
Here it is.
I found some critical errors in your logs.
I forwarded these to the developers.
Just another question: Did you ever start PMS ‘As Administrator’?
What are those critical errors about, if I may ask? And what should I expect about this issue? I’m a little reluctant to keep paying for something that is not working for me…
Regarding administrator mode, I’ve never ran the server nor the setup in any special way. Just double click.
Thanks for your help so far, Otto
It appears to be a program fault in the agent that is responsible to fetch metadata and those trailers. It just displays an error message, which hopefully will enable the developers to produce a fix and release it in one of the coming Server software versions.
Again, thanks for your help, Otto.
Plex Pass cancelled until fix arrives.
Hello, I have some issues like that.
When I add a movie sometimes takes all information complete. EX: Metadata, trailers (one at least) correct info.
Sometimes all complete, sometimes no sound media info, sometimes no extras, and no description , I need to refresh several times and 1 trailer comes with some extra metadata, but
Sometimes I can get a part only of the complete info non complete metadata (no description) under the poster don’t show the sound codec, only the resolution and channels ex: 1080p - NOTHING for the audio codec - 7.1
I try unmatched the file , delete the trash, match the file again, fix the unmatch file without success.
I try too, move the file to another directory outside of the library, refresh the library, empty the trash, restart the server and move again with to the folder. I re-check the name of the file, the mediainfo and everything is fine.
Sometimes click on refresh in the movie 3 times to get the metadata but the audio codec info still lost.
Some ideas?
Thank you!
Otto, do you think a fresh install could solve the issue? Do you have any idea of how the error could be solved?
I can’t tell. The developers need to analyse the error and then develop a fix.
You can try to re-install, but I doubt it will make a difference.
What you can try though, is to clear your local metadata caches and to reset all preferences for the movie metadata agents: https://forums.plex.tv/discussion/comment/1197259/#Comment_1197259
hey @patozf - sorry for the delay on this, but I just tried to repro your issue and couldn’t. Are you still having problems (specifically with 310 to Yuma)?
Also, your logs show a lot of permissions issues, so please make sure Plex has access to all parts of your disk - that could also be the reason for a lot of your problems.
I know this is an old issue, but I’ve had it for a long time now, and only periodically made attempts to fix it.
I finally think I found the solution. With plex pass, all trailers should be available for all movies, but they only show on some. I’ve discovered that if I make a folder with the movie name inside the library, the move the movie file into that folder, plex reparses the movie and adds the trailer. It’s weird, but I did it for each of the Avengers/Marvel movies. Before I did it, none had trailers, and after, they all do.
I am having trailer issues with random movies and I cant fix it. I played around with some agent stuff but its still not adding trailer links. here is an xml.
Version:1.0 StartHTML:000000339 EndHTML:000058102 StartFragment:000000624 EndFragment:000058067 StartSelection:000000624 EndSelection:000058067 SourceURL:https://192-168-1-2.43592acd1e46461ea4a56142fd4e15a6.plex.direct:32400/library/metadata/45656?checkFiles=1&includeExtras=1&includeBandwidths=1&X-Plex-Token=zXqa9yzJkxWhTwpkEoYq <MediaContainer mediaTagVersion=“1544808062” mediaTagPrefix="/system/bundle/media/flags/" librarySectionUUID=“47a75fd3-5974-4af9-9641-0c53d9ba89b4” librarySectionTitle=“Thriller” librarySectionID=“22” identifier=“com.plexapp.plugins.library” allowSync=“1” size=“1”><Video title=“Backstabbing for Beginners” librarySectionTitle=“Thriller” librarySectionID=“22” updatedAt=“1549076288” addedAt=“1549047038” originallyAvailableAt=“2018-01-18” duration=“6499584” art="/library/metadata/45656/art/1549076288" thumb="/library/metadata/45656/thumb/1549076288" tagline=“If you dig too deep, you may not like what comes up” year=“2018” rating=“6.4” summary=“An idealistic young employee at the U.N. investigates the grizzly murder of his predecessor – and uncovers a vast global conspiracy that may involve his own boss.” type=“movie” studio=“Fortitude International” librarySectionKey="/library/sections/22" guid=“com.plexapp.agents.imdb://tt5153288?lang=en” key="/library/metadata/45656" ratingKey=“45656”><Media id=“78708” duration=“6499584” videoProfile=“high” has64bitOffsets=“0” audioProfile=“lc” optimizedForStreaming=“1” videoFrameRate=“24p” container=“mp4” videoCodec=“h264” audioCodec=“aac” audioChannels=“2” aspectRatio=“2.35” height=“534” width=“1280” bitrate=“1198” videoResolution=“720”><Part id=“83439” size=“973513935” duration=“6499584” key="/library/parts/83439/1549011441/file.mp4" videoProfile=“high” has64bitOffsets=“0” audioProfile=“lc” optimizedForStreaming=“1” container=“mp4” file=“F:\Movies\Thriller\Backstabbing For Beginners (2018) [BluRay] [720p] [YTS.AM]\Backstabbing.For.Beginners.2018.720p.BluRay.x264-[YTS.AM].mp4” exists=“1” accessible=“1”><Stream id=“158131” height=“534” width=“1280” bitrate=“1050” displayTitle=“720p (H.264)” streamIdentifier=“1” refFrames=“4” profile=“high” pixelAspectRatio=“801:800” level=“41” hasScalingMatrix=“0” frameRate=“23.976” chromaSubsampling=“4:2:0” chromaLocation=“left” bitDepth=“8” anamorphic=“0” index=“0” codec=“h264” default=“1” streamType=“1”/><Stream id=“158132” bitrate=“149” displayTitle=“Unknown (AAC Stereo)” streamIdentifier=“2” profile=“lc” index=“1” codec=“aac” default=“1” streamType=“2” samplingRate=“48000” audioChannelLayout=“stereo” channels=“2” selected=“1”/></Part></Media><Genre id=“134” tag=“Thriller” filter=“genre=134”/><Genre id=“197” tag=“Drama” filter=“genre=197”/><Genre id=“198” tag=“History” filter=“genre=198”/><Director id=“93093” tag=“Per Fly” filter=“director=93093”/><Writer id=“93094” tag=“Per Fly” filter=“writer=93094”/><Writer id=“33973” tag=“Daniel Pyne” filter=“writer=33973”/><Country id=“75” tag=“USA” filter=“country=75”/><Country id=“33530” tag=“Denmark” filter=“country=33530”/><Country id=“399” tag=“Canada” filter=“country=399”/><Role id=“66874” role=“Michael” thumb=“http://image.tmdb.org/t/p/original/hLNSoQ3gc52X5VVb172yO3CuUEq.jpg” tag=“Theo James” filter=“actor=66874”/><Role id=“89129” role=“Christina Dupre” thumb=“http://image.tmdb.org/t/p/original/zbFbkz2JVg9sXFBmi6Yv6FB7Rl.jpg” tag=“Jacqueline Bisset” filter=“actor=89129”/><Role id=“2258” role=“Pasha” thumb=“http://image.tmdb.org/t/p/original/n0cVP5K2VxlohkAf7LoRwPt4xhu.jpg” tag=“Ben Kingsley” filter=“actor=2258”/><Role id=“93103” role=“Trevor” thumb=“http://image.tmdb.org/t/p/original/sddMpH2pZhPooyU5busCYgUivKk.jpg” tag=“Rossif Sutherland” filter=“actor=93103”/><Role id=“31129” role=“Rasnetsov” thumb=“http://image.tmdb.org/t/p/original/CL63sueT7SSBZQwoPH23FQEIR8.jpg” tag=“Brian Markinson” filter=“actor=31129”/><Role id=“93102” role=“Lily” thumb=“http://image.tmdb.org/t/p/original/6eA8X9vSgjo3AdEOn534shCc6xg.jpg” tag=“Rachel Wilson” filter=“actor=93102”/><Role id=“93096” role=“Nashim” thumb=“http://image.tmdb.org/t/p/original/hmx56xTnT0f9yeLqkFmP8bIaG01.jpg” tag=“Belcim Bilgin” filter=“actor=93096”/><Role id=“47510” role=“Reporter” thumb=“http://image.tmdb.org/t/p/original/hugd6xCGb5V6xYqN1hcIsLa8xu0.jpg” tag=“Shauna MacDonald” filter=“actor=47510”/><Role id=“93098” role=“Ruth” tag=“Daniela Lavender” filter=“actor=93098”/><Role id=“32019” role=“Justin Cutter” thumb=“http://image.tmdb.org/t/p/original/aq6ZhaqQnhQnvHOtdyeeNSVuPNR.jpg” tag=“Aidan Devine” filter=“actor=32019”/><Role id=“93101” role=“Hassan” thumb=“http://image.tmdb.org/t/p/original/a1Q7t8YP5apL2IHTNTvtkfLY7pH.jpg” tag=“Peshang Rad” filter=“actor=93101”/><Role id=“5153” role=“Award Presenter” thumb=“http://image.tmdb.org/t/p/original/7fp4Jhr9mkLunxTjxdAFKA3QR1A.jpg” tag=“Mishu Vellani” filter=“actor=5153”/><Role id=“62772” role=“U.S. Customs Agent” thumb=“http://image.tmdb.org/t/p/original/fHRe3ooYlW8hdcaUKxblcnj07WL.jpg” tag=“Dwight Ireland” filter=“actor=62772”/><Role id=“93099” role=“Prisoner” tag=“Elena Khan” filter=“actor=93099”/><Role id=“93100” role=“Kate” tag=“Hattie Kragten” filter=“actor=93100”/><Role id=“17909” role=“WSJ Editor” tag=“Alex Hatz” filter=“actor=17909”/><Role id=“93097” role=“Cabbie” tag=“Carlos Pinder” filter=“actor=93097”/><Role id=“93104” role=“Bearded Man” tag=“Zahir Gilani” filter=“actor=93104”/><Role id=“93095” role=“Kurdish Imam” tag=“Abbas Abdulghani” filter=“actor=93095”/><Role id=“21556” role=“United Nations Staff” tag=“Fabio Lusvarghi” filter=“actor=21556”/><Similar id=“16131” tag=“Rosy” filter=“similar=16131”/><Similar id=“15593” tag=“The Catcher Was a Spy” filter=“similar=15593”/><Similar id=“16121” tag=“Butterfly Caught” filter=“similar=16121”/><Similar id=“3683” tag=“The Assassin’s Code” filter=“similar=3683”/><Similar id=“93105” tag=“Cocaine Godmother” filter=“similar=93105”/><Similar id=“3675” tag=“Bel Canto” filter=“similar=3675”/><Similar id=“25674” tag=“Bad Frank” filter=“similar=25674”/><Similar id=“16132” tag=“The Incantation” filter=“similar=16132”/><Similar id=“15584” tag=“Edge of Fear” filter=“similar=15584”/><Similar id=“48480” tag=“22 Chaser” filter=“similar=48480”/><Similar id=“30214” tag=“Beirut” filter=“similar=30214”/><Similar id=“11990” tag=“At First Light” filter=“similar=11990”/><Similar id=“3090” tag=“I am Vengeance” filter=“similar=3090”/><Similar id=“11991” tag=“Burning Shadow” filter=“similar=11991”/><Similar id=“25850” tag=“Romans” filter=“similar=25850”/><Similar id=“3002” tag=“The Escape of Prisoner 614” filter=“similar=3002”/><Similar id=“410” tag=“Blackmark” filter=“similar=410”/><Similar id=“16130” tag=“Negative” filter=“similar=16130”/><Similar id=“405” tag=“211” filter=“similar=405”/><Similar id=“16123” tag=“Cold November” filter=“similar=16123”/><Extras size=“0”> </Extras></Video></MediaContainer>
