Hey... at least one step further. Any other software running that might have an effect on HTTP/port80?
Just wondering if you restarted the computer after shutting down POW?
After installing "powder" to manage pow, i was able to stop POW completely including changing the firewall rule. Killing the process was not enough. So it works now. Thanks a lot for the help!
Hello,
i still get the "Trailers is unavailable. Try again later." message on Apple TV (3) although the log looks fine to me. See here: http://pastebin.com/YEm5nGZW
My Apple TV 3 Firmware is 5.2.1
PMS runs on my Mac Mini. IP Address: 192.168.1.2
PlexConnect also runs on the Mac Mini.
Mac Mini has OSX Mountain Lion.
Media is stored on external harddrive.
PlexConnect Version (most recent one: 13.06.2013 23:44)
DNS is set to 192.168.1.1
Settings.cfg looks like this: http://pastebin.com/GmVKrmAU
So all the other channels (Youtube, etc.) work fine over the DNS, but when i launch the Trailers app, it just shows "Trailers is unavailable. Try again later.". I never saw the plex menu, although the log correctly says "***intercept request". Any ideas?
I have the same problem. trailers is unavailable try again later - I am not very tec
I am running PMS on my mac which has an operating system 10.7.5
I am not very technical.
Thanks for your help in advance.
You will need to provide the information asked for in the above READ BEFORE POSTING sticky in order to be helped effectively.
@ no9fletch please start another thread with the info institute11 mentioned.
Trailers unavailable is a pretty generic error, so unless you have the exact same setup, including the Ruby on Rails dev environment you have a different issue.
