Read that... http://forums.plexapp.com/index.php/topic/79086-when-apple-updates-apple-tv/
Thank you Baa! Was going mad over this. Will try the fix referenced in the 1st post ( http://langui.sh/2013/08/27/appletv-ssl-plexconnect/ ) and edit this post if it works.
I am having the same issue, ATV2(5.2) says "Trailers is unavailable. Try again later." I am using mac mini mountain lion as the PMS, pleax connect is also running from the same server. Using a Fritzbox 7270 router. Create a port forwarding for the default port 32400 on the router for the macmini aka pms. ATV2 dns server address is the macmini's(pms) ip address(192.168.178.26). Default gateway and dns is routers IP 192.168.178.1 . IP's for macmini(pms), atv etc are reserved from the router so it wont change.
Tried insert all the values manually and vanilla plexconnect-master, same result. What am I missing? pls help. logs from both are below
anyone?
Did you inject the certification file into the ATV? This is now a requirement of Plexconnect working. Please read the “Read Before Posting” stickied thread above for full details.
try updating the ATV to 5.3. that fixed my issue.
5.2 should be fine - still running that myself (I guess).
But... don't COPY/PASTE the terminal output. Create a nice logfile (see link by institute) and attach that.
And yes, I am going to repeat that more often now - if I have to. :-D
i have the trailer unavailble problem. i have atv 5.3 python 2.75 and updated my plex/connect... ive followed the fix off this post - http://www.macrumors.com/2013/08/28/developer-posts-fix-for-plexconnect-client-for-apple-tv/ yesterday i managed to view my media server on my atv but when i clicked something it said trailers unavailable, any ideas... ps-->my log.
nilay913,
Can you follow the Read Before Posting thread http://forums.plexapp.com/index.php/topic/69410-read-before-posting/
Also since the https change, alot of people are having issues with plexconnect locating the trailers.pem file, so can you go to https://192.168.0.12:443 and tell us the results. (I expect you should get a certificate warning, as the warning shows it can find the trailers.pem file)
in the Read Before Posting under "How to report an issue (do not private message asking for support or features!):" it provides instructions for turning logging to high and to then post the logfile not just the terminal screen output.
Hi, i have two days the same problem after upgrading to the new plex media server version.
ATV 3, 5.2.1, 192.168.1.17 - DNS changed to 192.168.1.7
- macbook mountain lion 10.8.4, 192.168.1.7, plex media server installed and upgraded to 0.9.8.50.9.8.5
- macbook mountain lion 10.8.4, 192.168.1.7, plex connect installed as well. used the latest version from git hp - PlexConnect-0.1-iOS-pre5.1
- python ver 2.71
- certifications generated and installed with this tut http://langui.sh/2013/08/27/appletv-ssl-plexconnect/ as well trough apple configurator
- plexconnect folder for trailers.pem in assets, certifications created. Trailer.pem copied
- added the two lines in settings.cfg - port ssl and certfile
tested ip_pms and ip_webserver values with default 0.0.0.0 and the shown values upper.
https://192.168.1.7:443
Safari can't find or open page
Log File:
Have you tried to pull plexconnect-master? In you log I can’t see it starting the Webserver in port 443 only 80 and I am wondering if that branch had not been updated with the changes
And the version of Plexconnect you provide is ancient. Go to Baa’s github and download the latest version of Plexconnect.
thank you guys but the plex connect which i used is from ba's signature link https://github.com/iBaa/PlexConnect/releases. there is no newer once to find
do anybody have a link for a newer version for mac osx? Thank you
There is no release link in my signature, is there?
Anyway, release 0.1 is old - very outdated since Apple did the change. I guess, I should create a new release soon-ish...
Take the "latest". Might not be thoroughly tested... on the other hand here are a LOT of people crying out loud as soon as it fails. :-)
He is referring to the Wiki link in your sig which leads you to:
Wiki > Releases > Plexconnect 0.1 (The release can be downloaded here. )
Which is somewhat misleading as Plexconnect 0.1 is indeed ancient.
Sorry for that...
ATV 3 version 5.3
DNS Address: 192.168.0.12
PlexConnect System: Alienware M17X Windows 7 64-bit
Local IP Address PlexConnect Is On: 192.168.0.12
Plex Media Server System: Alienware M17X Windows 7 64-bit
Local IP Address Plex Media Server Is On: 192.168.0.12
I'm terribly sorry, but I don't have a clue about github and versions/dates on it, but this I'll attach a print screen of it.
setting.cfg:
[PlexConnect]
Error response
Error code 403.
Message: Not Serving Client 192.168.0.12.
Error code explanation: 403 = Request forbidden -- authorization will not help."
You should have started a new thread as your issue has nothing to do with what is being discussed here.
As for SkyGo please head to this post in the Plex Channels forum:
https://forums.plexapp.com/index.php?/topic/75265-README-FIRST:-Broken-and/or-problematic-channels
Thanks, I have made a new thread... http://forums.plexapp.com/index.php/topic/79956-trailers-unavailable-plug-in-bundles/
for sure there is a link https://github.com/iBaa/PlexConnect. but on the first view my intuition told me to click on the release section on that page. and here is the old one. Meanwhile, i found the master version but below in the prosa with a link
