On my windows 7 and I can't seem to get this working any help I will appreciate.
setting.cfg
setting.cfg
Try this instead.
The syntax in your config file is wrong, for some reason. There can only be one settings entry pr line.
[PlexConnect] logpath = . enable_dnsserver = True ip_webserver = 0.0.0.0 prevent_atv_update = True enable_plexconnect_autodetect = True port_pms = 32400 port_webserver = 80 ip_plexconnect = 0.0.0.0 ip_dnsmaster = 8.8.8.8 loglevel = Normal ip_pms = 192.168.1.127 port_ssl = 443 enable_plexgdm = False certfile = c:/PlexConnect-master/assets/certificates/trailers.pem
Still not available
settings.cfg
have you done this?
have you done this?
http://langui.sh/2013/08/27/appletv-ssl-plexconnect/
Any thoughts
Any thoughts
in the settings.cfg files try changing this line
loglevel = Normal
to
loglevel = High
this can make the PlexConnect.log file get huge so be sure to return it to the original setting later
this might give you a better idea of what is wrong...maybe
Your on windows so maybe your / in the cert path need to be .
If you browse to https://192.168.1.127:443 do you get a certificate error?
setting.cfg
This what happen when I check the web address.
That means your plexconnect is able to find your certificate. Maybe your profile on the ATV is the issue?
Does it matter what version of iOS the atv is? I’m on 5.2.1
I'm currently o n 5.2.1 as well
recheck the certificate on your aTV
it took me a few times to get it installed correctly
Hope someone can do a specific windows guide on installing the certificate, as it gets confusing when they mix the mac & windows together for me. 2 out of the 3 cmd runs at the beginning didn’t work for me ? , but I will wait till hopefully someone does a step by step windows version.
Cheers
Riche
I was a bit daunted with the instructions too, but it worked first time for me on W7....did you run the CMD as administrator? I didnt think the the 3rd command worked for me either as I got a warning about the pathway that looked like linux....however, I did get the 3 files, and I put the cert and pathway at the root of the plexconnect folder, not in a cert pathway....
I also had issues with the iphone config util not finding my device but a new MicroUSB cable sorted that....
Good luck
Oh, also on my config file
enable_plexgdm = TRUE
So followed http://langui.sh/201…sl-plexconnect/
Installed certificate, all seemed to go right
latest plexconnect - here is the settings & log:
[PlexConnect]
logpath = .
port_pms = 32400
port_webserver = 80
certfile = ./assets/certificates/trailers.pem
loglevel = Normal
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
10:59:16 PlexConnect: started: 10:59:16
10:59:16 Settings: getsetting enable_plexconnect_autodetect=True
10:59:16 PlexConnect: IP_self: 192.168.0.11
10:59:16 Settings: getsetting enable_dnsserver=True
10:59:16 DNSServer: started: 10:59:16
10:59:16 Settings: getsetting ip_dnsmaster=8.8.8.8
10:59:16 Settings: getsetting prevent_atv_update=True
10:59:16 DNSServer: ***
10:59:16 DNSServer: Starting up.
10:59:16 DNSServer: intercept: [‘trailers.apple.com’, ‘atv.plexconnect’] => 192.168.0.11
10:59:16 DNSServer: restrain: [‘mesu.apple.com’, ‘appldnld.apple.com’, ‘appldnld.apple.com.edgesuite.net’] => 127.0.0.1
10:59:16 DNSServer: forward other to higher level DNS: 8.8.8.8
10:59:16 WebServer: started: 10:59:16
10:59:16 Settings: getsetting ip_webserver=0.0.0.0
10:59:16 Settings: getsetting port_webserver=80
10:59:16 Settings: getsetting port_ssl=443
10:59:16 Settings: getsetting certfile=./assets/certificates/trailers.pem
10:59:16 WebServer: ***
10:59:16 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
10:59:16 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
10:59:16 ATVSettings: init class CATVSettings
10:59:16 ATVSettings: load settings
10:59:16 Settings: getsetting enable_plexgdm=True
10:59:16 PlexGDM: ***
10:59:16 PlexGDM: looking up Plex Media Server
10:59:16 PlexGDM: Sending discovery message: M-SEARCH * HTTP/1.0
10:59:16 PlexGDM: Received data from (‘192.168.0.11’, 32414)
10:59:16 PlexGDM: Data received:
HTTP/1.0 200 OK
Content-Type: plex/media-server
Resource-Identifier: dea330cb7542049b4c3b5dc63166ab0b351ff63a
Port: 32400
Updated-At: 1377995776
Version: 0.9.7.28-f80a4a2
**10:59:17 PlexGDM: servers discovered: 1
10:59:17 PlexGDM: Office 192.168.0.11:32400
10:59:17 XMLConverter: PlexGDM - PMS: 192.168.0.11:32400
10:59:17 ATVSettings: setOption: update pms_uuid to (‘dea330cb7542049b4c3b5dc63166ab0b351ff63a’,)
10:59:20 DNSServer: DNS request received!
10:59:20 DNSServer: Source: (‘192.168.0.8’, 54788)
10:59:20 DNSServer: Domain: ax.init-cdn.itunes.apple.com.akadns.net
10:59:20 DNSServer: ***forward request
10:59:20 DNSServer: -> DNS response from higher level
10:59:21 DNSServer: DNS request received!
10:59:21 DNSServer: Source: (‘192.168.0.8’, 58819)
10:59:21 DNSServer: Domain: p18-buy.itunes.apple.com.akadns.net
10:59:21 DNSServer: ***forward request
10:59:21 DNSServer: -> DNS response from higher level
10:59:25 DNSServer: DNS request received!
10:59:25 DNSServer: Source: (‘192.168.0.8’, 55672)
10:59:25 DNSServer: Domain: itunes-cdn.apple.com.akadns.net
10:59:25 DNSServer: ***forward request
10:59:25 DNSServer: -> DNS response from higher level
10:59:25 DNSServer: Source: (‘192.168.0.8’, 52026)
10:59:25 DNSServer: Domain: se-cdn.itunes.apple.com.akadns.net
10:59:28 DNSServer: DNS request received!
10:59:28 DNSServer: Source: (‘192.168.0.8’, 59433)
10:59:28 DNSServer: Domain: appleglobal.102.112.2o7.net
10:59:28 DNSServer: ***forward request
10:59:29 DNSServer: -> DNS response from higher level
10:59:29 DNSServer: DNS request received!
10:59:29 DNSServer: Source: (‘192.168.0.8’, 61269)
10:59:29 DNSServer: Domain: a1.mzstatic.apple.com.akadns.net
10:59:29 DNSServer: ***forward request
10:59:29 DNSServer: Source: (‘192.168.0.8’, 56281)
10:59:29 DNSServer: Domain: a5.mzstatic.apple.com.akadns.net
10:59:29 DNSServer: Source: (‘192.168.0.8’, 62367)
10:59:29 DNSServer: Domain: a4.mzstatic.apple.com.akadns.net
10:59:30 DNSServer: DNS request received!
10:59:30 DNSServer: Source: (‘192.168.0.8’, 64953)
10:59:30 DNSServer: Domain: a3.mzstatic.apple.com.akadns.net
10:59:30 DNSServer: ***forward request
10:59:30 DNSServer: -> DNS response from higher level
10:59:30 DNSServer: Source: (‘192.168.0.8’, 53368)
10:59:30 DNSServer: Domain: a2.mzstatic.apple.com.akadns.net
10:59:35 DNSServer: DNS request received!
10:59:35 DNSServer: Source: (‘192.168.0.8’, 51982)
10:59:35 DNSServer: Domain: e673.b.akamaiedge.net
10:59:35 DNSServer: ***forward request
10:59:35 DNSServer: -> DNS response from higher level
10:59:42 DNSServer: DNS request received!
10:59:42 DNSServer: Source: (‘192.168.0.8’, 59119)
10:59:42 DNSServer: Domain: e673.g.akamaiedge.net
10:59:42 DNSServer: ***forward request
10:59:42 DNSServer: -> DNS response from higher level
10:59:42 DNSServer: Source: (‘192.168.0.8’, 61702)
10:59:42 DNSServer: Domain: bookkeeper.itunes.apple.com.akadns.net
10:59:42 DNSServer: Source: (‘192.168.0.8’, 53857)
10:59:42 DNSServer: Domain: a4.da1.akamai.net
10:59:43 DNSServer: DNS request received!
10:59:43 DNSServer: Source: (‘192.168.0.8’, 50926)
10:59:43 DNSServer: Domain: upp.itunes.apple.com.akadns.net
10:59:43 DNSServer: ***forward request
10:59:43 DNSServer: -> DNS response from higher level
10:59:48 DNSServer: DNS request received!
10:59:48 DNSServer: Source: (‘192.168.0.8’, 54494)
10:59:48 DNSServer: Domain: a953.v.phobos.apple.com
10:59:48 DNSServer: ***forward request
10:59:48 DNSServer: -> DNS response from higher level
10:59:55 DNSServer: DNS request received!
10:59:55 DNSServer: Source: (‘192.168.0.8’, 50241)
10:59:55 DNSServer: Domain: e905.b.akamaiedge.net
10:59:55 DNSServer: ***forward request
10:59:55 DNSServer: -> DNS response from higher level
11:00:05 DNSServer: DNS request received!
11:00:05 DNSServer: Source: (‘192.168.0.8’, 50296)
11:00:05 DNSServer: Domain: a771.da1.akamai.net
11:00:05 DNSServer: ***forward request
11:00:05 DNSServer: -> DNS response from higher level
11:00:11 DNSServer: DNS request received!
11:00:11 DNSServer: Source: (‘192.168.0.8’, 58112)
11:00:11 DNSServer: Domain: trailers.apple.com
11:00:11 DNSServer: *intercept request
11:00:11 DNSServer: -> DNS response: 192.168.0.11
Getting trailers is unavalible
Not sure where I went wrong
**Cheers **
Riche
Ok up and running again , thanks to SAMs post here for windows.
https://forums.plexapp.com/index.php?/topic/79540-Windows-specific-instructions-for-creating-and-installing-the-SSL-cert
Cheers
Sent from my iPhone using Tapatalk 2
Cheers
This work for me.
I hope somebody can help me.
I'm doing all the things but without luck.
