Trailers unavailable Try again later Win 7
Still having the same problems and I cant seem to fix it looking through other forums and all.
This is my settings:
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = /users/murdoch/desktop/plex1/plexconnect-master/assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = normal
enable_dnsserver = True
logpath = .
ip_pms = 192.168.178.10
enable_plexgdm = True
hosttointercept = trailers.apple.com
port_ssl =
443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
The only thing I changed was the cert and I just changed it to the direct path.
Please read the sticky before posting further.
are you refering to the 3 links under your name if so those ideas didnt work.
No... he wants you to read that: https://forums.plexapp.com/index.php/topic/69410-read-before-posting/
In short:
- more info about your setup
- no pasting screenshots, no pasting terminal output. Attaching files is great.
- loglevel=High might help as well
ohh kk
I have:
ATV 6.0
ip198.168.2.11
router 198.168.2.1
DND 198.168.2.27
I'm running python 2.7 I've have the latest update of Plexconnect
Settings
[PlexConnect]
port_pms = 32400
port_webserver = 80
loglevel = high
logpath = .
port_ssl =
443
port_dnsserver = 53
The attachment above is my PlexConnect Log.  When I go into the  text document I just get
14:24:21 PlexConnect: started: 14:24:21
14:24:21 PlexConnect: IP_self: 192.168.2.27
14:24:22 DNSServer: started: 14:24:22
14:24:22 DNSServer: ***
14:24:22 DNSServer: DNSServer: Serving DNS on 192.168.2.27 port 53.
14:24:22 WebServer: started: 14:24:22
14:24:22 WebServer: ***
14:24:22 WebServer: WebServer: Serving HTTP on 192.168.2.27 port 80.
14:24:22 WebServer: WebServer: Serving HTTPS on 192.168.2.27 port 443.
So its not showing me the whole thing.
Or I will lock the thread.
Don't understand I read the sticky
I gave you the ATV version, the topic says win 7, ip 198.168.2.11,router 198.168.2.1,DNS 198.168.2.27  I have seen other topics that say latest update I had to attach a file so people could see the whole thing.
If I have missed something please tell me what and I can fix it.
Read the link and provide ALL the requested information in the template - it is there for a reason - you cannot have read the link as you have missed out large chunks of info and put things like “latest” which are specifically called out as useless.
You got to have your aTV running...
Windows 7 64bit OS
Python 2.7.6
Plex 0.9.8.10
ATV3 6.0
ip 198.168.2.11
router 198.168.2.1
DNS 198.168.2.27
Plexconnect is the newest version which is 6.0?
My atv3 is on when I close Python. Tried it many times still opens with the same lines when I open my log
PlexConnect has no real versions. I guess we are stuck at 0.2...
Restart your aTV.
If you then get all the Apps on your home screen, but no messages in PlexConnect, your aTV DNS is not set to PlexConnect...
Now when I restart I have to resign into itunes but with the dns from my comp it doesnt work would that mean its not set to PlexConnect?
How is iTunes related to all this?
when I have my dns on auto it logs in but with the manual  it doesnt but w/e just throwing things out.   Just wondering when I go into plex/web and under settings I have a ! beside myplex saying There was a problem connecting your server retry
the trusted folder and I got the pop up asking me if I am ok with it. Other people on other forums have suggested to type in an ip address to see if the cert works properly.
am I going to have to restart this again...
I Started from fresh and same thing.  When I go to browse on my comp and type 192.168.2.27  I don't get the warning just "Internet Explorer cannot display the webpage "  this be part of the problem?
PlexConnect Log
22:58:38 Settings: getsetting enable_dnsserver=True
22:58:38 DNSServer: started: 22:58:38
22:58:38 Settings: getsetting port_dnsserver=53
22:58:38 Settings: getsetting ip_dnsmaster=8.8.8.8
22:58:38 Settings: getsetting prevent_atv_update=True
22:58:38 DNSServer: ***
22:58:38 DNSServer: DNSServer: Serving DNS on 192.168.2.27 port 53.
22:58:38 DNSServer: intercept: ['trailers.apple.com'] => 192.168.2.27
22:58:38 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
22:58:38 DNSServer: forward other to higher level DNS: 8.8.8.8
22:58:38 Settings: getsetting enable_webserver_ssl=True
22:58:38 WebServer: started: 22:58:38
22:58:38 Settings: getsetting port_webserver=80
22:58:38 WebServer: ***
22:58:38 WebServer: WebServer: Serving HTTP on 192.168.2.27 port 80.
22:58:38 ATVSettings: init class CATVSettings
22:58:38 ATVSettings: load settings
22:58:38 Settings: getsetting port_ssl=443
22:58:38 Settings: getsetting certfile=/users/murdoch/desktop/plex1/plexconnect-master/assets/certificates/trailers.pem
22:58:38 WebServer: WebServer: Serving HTTPS on 192.168.2.27 port 443.
22:58:40 DNSServer: DNS request received!
22:58:40 DNSServer: Source: ('192.168.2.11', 54603)
22:58:40 DNSServer: Domain: init.itunes.apple.com
22:58:40 DNSServer: ***forward request
22:58:40 DNSServer: -> DNS response from higher level
22:58:40 DNSServer: Source: ('192.168.2.11', 52170)
22:58:40 DNSServer: Domain: EVIntl-ocsp.verisign.com
22:58:41 DNSServer: DNS request received!
22:58:41 DNSServer: Source: ('192.168.2.11', 60674)
22:58:41 DNSServer: Domain: itunes.apple.com
22:58:41 DNSServer: ***forward request
22:58:41 DNSServer: -> DNS response from higher level
22:58:41 DNSServer: Source: ('192.168.2.11', 61591)
22:58:41 DNSServer: Domain: xp.apple.com
22:58:49 DNSServer: DNS request received!
22:58:49 DNSServer: Source: ('192.168.2.11', 60730)
22:58:49 DNSServer: Domain: trailers.apple.com
22:58:49 DNSServer: ***intercept request
22:58:49 DNSServer: -> DNS response: 192.168.2.27
23:00:01 PlexConnect: Shutting down.
23:00:01 WebServer: Shutting down.
23:00:01 ATVSettings: save settings
23:00:04 DNSServer: Shutting down.
23:00:04 PlexConnect: shutdown
Settings
[PlexConnect]
port_pms = 32400
port_webserver = 80
loglevel = High
logpath = .
port_ssl = 443
port_dnsserver = 53
I don't know how IE would react... you should at least see a note of Error 403 occurred.
What are the firewall rules you have set up for Python (inbound/outbound/tcp/udp)?
um idk. When I'm in advanced firewall I see inbound 4 python rules 2 blocked do they all need to be enabled? both tcp and udp are set to any  as for outbound they aren't there how many rules should I make seeing how my inbound has 4?  whem I am making the new rules am I making a new program or port?
Delete the Python rules and make inbound rules for both UDP and TCP for Python.exe
now when I am making the new rule do port 443 and port 80 go with a certian tcp or udp?  I left both as any.
new log:
18:57:01 PlexConnect: started: 18:57:01
18:57:01 Settings: getsetting enable_plexconnect_autodetect=True
18:57:01 PlexConnect: IP_self: 192.168.2.27
18:57:01 Settings: getsetting port_webserver=80
18:57:01 Settings: getsetting hosttointercept=trailers.apple.com
18:57:01 Settings: getsetting enable_dnsserver=True
18:57:01 DNSServer: started: 18:57:01
18:57:01 Settings: getsetting port_dnsserver=53
18:57:01 Settings: getsetting ip_dnsmaster=8.8.8.8
18:57:01 Settings: getsetting enable_webserver_ssl=True
18:57:01 Settings: getsetting prevent_atv_update=True
18:57:01 DNSServer: ***
18:57:01 DNSServer: DNSServer: Serving DNS on 192.168.2.27 port 53.
18:57:01 DNSServer: intercept: ['trailers.apple.com'] => 192.168.2.27
18:57:01 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
18:57:01 DNSServer: forward other to higher level DNS: 8.8.8.8
18:57:01 WebServer: started: 18:57:01
18:57:01 WebServer: ***
18:57:01 WebServer: WebServer: Serving HTTP on 192.168.2.27 port 80.
18:57:01 ATVSettings: init class CATVSettings
18:57:01 ATVSettings: load settings
18:57:01 Settings: getsetting port_ssl=443
18:57:01 Settings: getsetting certfile=/users/murdoch/desktop/plex1/plexconnect-master/assets/certificates/trailers.pem
18:57:01 WebServer: WebServer: Serving HTTPS on 192.168.2.27 port 443.
18:57:21 DNSServer: DNS request received!
18:57:21 DNSServer: Source: ('192.168.2.11', 62397)
18:57:21 DNSServer: Domain: init.itunes.apple.com
18:57:21 DNSServer: ***forward request
18:57:21 DNSServer: -> DNS response from higher level
18:57:22 DNSServer: DNS request received!
18:57:22 DNSServer: Source: ('192.168.2.11', 61447)
18:57:22 DNSServer: Domain: itunes.apple.com
18:57:22 DNSServer: ***forward request
18:57:23 DNSServer: -> DNS response from higher level
18:57:23 DNSServer: DNS request received!
18:57:23 DNSServer: Source: ('192.168.2.11', 50309)
18:57:23 DNSServer: Domain: e673.g.akamaiedge.net
18:57:23 DNSServer: ***forward request
18:57:36 DNSServer: DNS request received!
18:57:36 DNSServer: Source: ('192.168.2.11', 62078)
18:57:36 DNSServer: Domain: trailers.apple.com
18:57:36 DNSServer: ***intercept request
18:57:36 DNSServer: -> DNS response: 192.168.2.27
18:57:48 DNSServer: DNS request received!
18:57:48 DNSServer: Source: ('192.168.2.11', 55242)
18:57:48 DNSServer: Domain: xp.apple.com
18:57:48 DNSServer: ***forward request
18:57:48 DNSServer: -> DNS response from higher level
18:57:48 DNSServer: Source: ('192.168.2.11', 58001)
18:57:48 DNSServer: Domain: EVIntl-ocsp.verisign.com
18:58:00 PlexConnect: Shutting down.
18:58:00 WebServer: Shutting down.
18:58:00 ATVSettings: save settings
18:58:03 DNSServer: Shutting down.
18:58:03 PlexConnect: shutdown
