Unable to get the built in Apple trailers working.... just do not seem to want to play. I am running the latest version of ATV firmware is this a known issue with PlexConnect?
Aeh... PlexConnect uses the "trailers" app to inject the Plex stuff. Not being able to visit the build-in apple trailers is by design.
Now, what is the question?
So I can’t watch trailers on ATV? I was hoping you could do both, plex and watch trailers?
No, not today... we might enable using the PMS "trailers" plugin - but this is not here yet.
Currently your only chance for apple trailers is to switch DNS setting on your aTV, between automatic and the PlexConnect one...
Or use the IMDB trailer plugin for Plex Media Server. The plugin is available in the Unsupported AppStore bundle which can be found in the Plex Channels forum.
I have tested it and it works with Plexconnect.
you just download the bundle and place it in the plug-ins directory within PMS once extracted, yeah?
Yes. Then go to the plugin in Plex Media Server, click on it and then select and install the plugins you want. Warning: There are adult plugins in the Unsupported AppStore but you do not have to install them.
