Trailers Unavailable Plug In Bundles
ATV 3 version 5.3
DNS Address: 192.168.0.12
PlexConnect System: Alienware M17X Windows 7 64-bit
Local IP Address PlexConnect Is On: 192.168.0.12
Plex Media Server System: Alienware M17X Windows 7 64-bit
I'm not quite sure the exact version of Plex Media Server I'm running, but the file name of the download is: Plex-Media-Server-0.9.805.165-c301c50-en-US
Local IP Address Plex Media Server Is On: 192.168.0.12
I'm terribly sorry, but I don't have a clue about github and versions/dates on it, but this I'll attach a print screen of it. ![post-167988-0-75181000-1378400134.png|690x431](upload://teJPRxDuRqi8rgDlqB9cTmaH8dC.png)
setting.cfg:
[PlexConnect]
logpath = .
enable_dnsserver = True
ip_webserver = 0.0.0.0
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
port_ssl = 443
Log:Exceeds PasteBin's 500 kv, have attached a .txt File
My I'm having troubles with channels, bbc iplayer works, however a number of custom Bundles don't work either, i thought they might be dodgy, but others are working fines, and too many of the plugins I installed don't work to just be faulty... custom channels, it just says "Trailers is unavailable. Try again later"
Please Help! + If there's any information I missed out, just tell me...
You might want to check out the Google Doc in this post More Channel Working
institute11 has been doing a fantastic job in keeping it up to date with both PMS & PlexConnect updates.
The SkyGo issue is not related to Plexconnect. For SkyGo info please head to this post in the Plex Channels forum:
https://forums.plexapp.com/index.php?/topic/75265-README-FIRST:-Broken-and/or-problematic-channels
For other channels check the links that Jerry referred to and you might as well update to PMS 9.8.5, the latest public release.
