You are not making them for ports you are making them for python.exe
OK i have made them now but I am still getting the same message.
Settings:
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = /users/murdoch/desktop/plex1/plexconnect-master/assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = High
enable_dnsserver = True
logpath = .
ip_pms = 192.168.178.10
enable_plexgdm = True
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
19:22:32 PlexConnect: started: 19:22:32
19:22:32 Settings: getsetting enable_plexconnect_autodetect=True
19:22:32 PlexConnect: IP_self: 192.168.2.27
19:22:32 Settings: getsetting port_webserver=80
19:22:32 Settings: getsetting hosttointercept=trailers.apple.com
19:22:32 Settings: getsetting enable_dnsserver=True
19:22:32 DNSServer: started: 19:22:32
19:22:32 Settings: getsetting port_dnsserver=53
19:22:32 Settings: getsetting ip_dnsmaster=8.8.8.8
19:22:32 Settings: getsetting prevent_atv_update=True
19:22:32 DNSServer: ***
ting enable_webserver_ssl=True
19:22:32 DNSServer: DNSServer: Serving DNS on 192.168.2.27 port 53.
19:22:32 DNSServer: intercept: ['trailers.apple.com'] => 192.168.2.27
19:22:32 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
19:22:32 DNSServer: forward other to higher level DNS: 8.8.8.8
19:22:32 WebServer: started: 19:22:32
19:22:32 WebServer: ***
19:22:32 WebServer: WebServer: Serving HTTP on 192.168.2.27 port 80.
19:22:32 ATVSettings: init class CATVSettings
19:22:32 ATVSettings: load settings
19:22:32 Settings: getsetting port_ssl=443
19:22:32 Settings: getsetting certfile=/users/murdoch/desktop/plex1/plexconnect-master/assets/certificates/trailers.pem
19:22:32 WebServer: WebServer: Serving HTTPS on 192.168.2.27 port 443.
19:22:41 DNSServer: DNS request received!
19:22:41 DNSServer: Source: ('192.168.2.11', 62008)
19:22:41 DNSServer: Domain: trailers.apple.com
19:22:41 DNSServer: ***intercept request
19:22:41 DNSServer: -> DNS response: 192.168.2.27
19:22:52 DNSServer: DNS request received!
19:22:52 DNSServer: Source: ('192.168.2.11', 55822)
19:22:52 DNSServer: Domain: a4.mzstatic.com
19:22:52 DNSServer: ***forward request
19:22:52 DNSServer: -> DNS response from higher level
19:23:01 PlexConnect: Shutting down.
19:23:01 WebServer: Shutting down.
19:23:01 ATVSettings: save settings
19:23:02 WebServer: Shutting down.
19:23:02 DNSServer: Shutting down.
19:23:02 PlexConnect: shutdown
19:11:58 PlexConnect: started: 19:11:58
19:11:58 Settings: getsetting enable_plexconnect_autodetect=True
19:11:58 PlexConnect: IP_self: 192.168.2.27
19:11:58 Settings: getsetting port_webserver=80
19:11:58 Settings: getsetting hosttointercept=trailers.apple.com
19:11:58 Settings: getsetting enable_dnsserver=True
19:11:58 DNSServer: started: 19:11:58
19:11:58 Settings: getsetting port_dnsserver=53
19:11:58 Settings: getsetting ip_dnsmaster=8.8.8.8
19:11:58 Settings: getsetting prevent_atv_update=True
19:11:58 DNSServer: ***
19:11:58 DNSServer: DNSServer: Serving DNS on 192.168.2.27 port 53.
19:11:58 DNSServer: intercept: ['trailers.apple.com'] => 192.168.2.27
19:11:58 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
19:11:58 DNSServer: forward other to higher level DNS: 8.8.8.8
19:11:58 Settings: getsetting enable_webserver_ssl=True
19:11:59 WebServer: started: 19:11:59
19:11:59 Settings: getsetting port_webserver=80
19:11:59 WebServer: ***
19:11:59 WebServer: WebServer: Serving HTTP on 192.168.2.27 port 80.
19:11:59 ATVSettings: init class CATVSettings
19:11:59 ATVSettings: load settings
19:11:59 Settings: getsetting port_ssl=443
19:11:59 Settings: getsetting certfile=/users/murdoch/desktop/plex1/plexconnect-master/assets/certificates/trailers.pem
19:11:59 WebServer: WebServer: Serving HTTPS on 192.168.2.27 port 443.
19:12:18 DNSServer: DNS request received!
19:12:18 DNSServer: Source: ('192.168.2.11', 59511)
19:12:18 DNSServer: Domain: trailers.apple.com
19:12:18 DNSServer: ***intercept request
19:12:18 DNSServer: -> DNS response: 192.168.2.27
19:12:34 PlexConnect: Shutting down.
19:12:34 WebServer: Shutting down.
19:12:35 WebServer: Shutting down.
19:12:35 ATVSettings: save settings
19:12:38 DNSServer: Shutting down.
19:12:38 PlexConnect: shutdown
Tried again samething. I did notice that in my log I am missing the 32400. Any thoughts on why?
22:10:29 PlexConnect: started: 22:10:29
22:10:29 Settings: getsetting enable_plexconnect_autodetect=True
22:10:29 PlexConnect: IP_self: 192.168.2.27
22:10:29 Settings: getsetting port_webserver=80
22:10:29 Settings: getsetting hosttointercept=trailers.apple.com
22:10:29 Settings: getsetting enable_dnsserver=True
22:10:29 DNSServer: started: 22:10:29
22:10:30 Settings: getsetting enable_webserver_ssl=True
22:10:30 Settings: getsetting port_dnsserver=53
22:10:30 Settings: getsetting ip_dnsmaster=8.8.8.8
22:10:30 WebServer: started: 22:10:30
22:10:30 Settings: getsetting prevent_atv_update=True
22:10:30 DNSServer: ***
22:10:30 DNSServer: DNSServer: Serving DNS on 192.168.2.27 port 53.
22:10:30 Settings: getsetting port_webserver=80
22:10:30 DNSServer: intercept: ['trailers.apple.com'] => 192.168.2.27
22:10:30 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
22:10:30 DNSServer: forward other to higher level DNS: 8.8.8.8
22:10:30 WebServer: ***
22:10:30 WebServer: WebServer: Serving HTTP on 192.168.2.27 port 80.
22:10:30 ATVSettings: init class CATVSettings
22:10:30 ATVSettings: load settings
22:10:30 Settings: getsetting port_ssl=443
22:10:30 Settings: getsetting certfile=/users/murdoch/desktop/plex1/plexconnect-master/assets/certificates/trailers.pem
22:10:30 WebServer: WebServer: Serving HTTPS on 192.168.2.27 port 443.
22:10:49 DNSServer: DNS request received!
22:10:49 DNSServer: Source: ('192.168.2.11', 55563)
22:10:49 DNSServer: Domain: init.itunes.apple.com
22:10:49 DNSServer: ***forward request
22:10:49 DNSServer: -> DNS response from higher level
22:10:50 DNSServer: DNS request received!
22:10:50 DNSServer: Source: ('192.168.2.11', 59247)
22:10:50 DNSServer: Domain: se.itunes.apple.com
22:10:50 DNSServer: ***forward request
22:10:50 DNSServer: -> DNS response from higher level
22:10:50 DNSServer: Source: ('192.168.2.11', 57253)
22:10:50 DNSServer: Domain: p51-buy.itunes.apple.com
22:10:50 DNSServer: Source: ('192.168.2.11', 62237)
22:10:50 DNSServer: Domain: xp.apple.com
22:10:50 DNSServer: Source: ('192.168.2.11', 64332)
22:10:50 DNSServer: Domain: a1.mzstatic.com
22:10:50 DNSServer: Source: ('192.168.2.11', 60456)
22:10:50 DNSServer: Domain: EVIntl-ocsp.verisign.com
22:10:50 DNSServer: Source: ('192.168.2.11', 57506)
22:10:50 DNSServer: Domain: a3.mzstatic.com
22:10:51 DNSServer: -> DNS response from higher level
22:10:54 DNSServer: DNS request received!
22:10:54 DNSServer: Source: ('192.168.2.11', 61138)
22:10:54 DNSServer: Domain: trailers.apple.com
22:10:54 DNSServer: ***intercept request
22:10:54 DNSServer: -> DNS response: 192.168.2.27
22:11:12 PlexConnect: Shutting down.
22:11:13 WebServer: Shutting down.
22:11:13 ATVSettings: save settings
22:11:14 DNSServer: Shutting down.
22:11:14 PlexConnect: shutdown
Settings
[PlexConnect]
port_pms = 32400
port_webserver = 80
loglevel = High
logpath = .
port_ssl = 443
port_dnsserver = 53
