ok.. Im stumped !
Hi Guys..Worked fine for a bit.. did the fix with Trailers... all worked .. now I run my command line.. all looks good but stops here.. and i get the Trailers is unavailable comment ..
I entered the 192.168.1.110 in the ATV DNS area as well..
iMac:sudo .:PlexConnect.py mzn50$ sudo ./PlexConnect.py
Password:
15:53:08 PlexConnect: ***
15:53:08 PlexConnect: PlexConnect
15:53:08 PlexConnect: Press CTRL-C to shut down.
15:53:08 PlexConnect: started: 15:53:08
15:53:08 PlexConnect: IP_self: 192.168.1.110
15:53:08 DNSServer: started: 15:53:08
15:53:08 DNSServer: ***
15:53:08 DNSServer: DNSServer: Serving DNS on 192.168.1.110 port 53.
15:53:08 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.110
15:53:08 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
15:53:08 DNSServer: forward other to higher level DNS: 8.8.8.8
15:53:09 WebServer: started: 15:53:09
15:53:09 WebServer: ***
15:53:09 WebServer: WebServer: Serving HTTP on 192.168.1.110 port 80.
15:53:09 PlexAPI: ***
15:53:09 PlexAPI: looking up Plex Media Server
15:53:09 WebServer: WebServer: Serving HTTPS on 192.168.1.110 port 443.
15:53:10 PlexAPI: servers discovered: 1
15:53:10 XMLConverter: PlexGDM - PMS: 192.168.1.110:32400
and then NOTHING..
it registers and updates the script when I select trailers on the ATV2.. but.. I only get the unavailable message..
any pointers would highly be appriciated from this supporting user !
thanks..
Matt
Do an update, try again, call back if issue persists.
You should AT LEAST see some DNSServer messages. Then - after selecting trailers on aTV - some WebServer messages.
Try flushing the DNS caches of aTV, router, host... whatever is involved.
Thanks Baa ..
I did as requested.. and yes sorry .. I just did not include the DNSServer messages..
here is the the feed I get..with the DNS Server mess...
The one thing I did change was I added new DD-WRT Firmware to my Router.. I think it could be related ..
Password:
17:43:01 PlexConnect: ***
17:43:01 PlexConnect: PlexConnect
17:43:01 PlexConnect: Press CTRL-C to shut down.
17:43:01 PlexConnect: started: 17:43:01
17:43:01 PlexConnect: IP_self: 192.168.1.110
17:43:01 DNSServer: started: 17:43:01
17:43:01 DNSServer: ***
17:43:01 DNSServer: DNSServer: Serving DNS on 192.168.1.110 port 53.
17:43:01 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.110
17:43:01 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
17:43:01 DNSServer: forward other to higher level DNS: 8.8.8.8
17:43:01 WebServer: started: 17:43:01
17:43:01 WebServer: ***
17:43:01 WebServer: WebServer: Serving HTTP on 192.168.1.110 port 80.
17:43:01 PlexAPI: ***
17:43:01 PlexAPI: looking up Plex Media Server
17:43:01 WebServer: WebServer: Serving HTTPS on 192.168.1.110 port 443.
17:43:02 PlexAPI: servers discovered: 1
17:43:02 XMLConverter: PlexGDM - PMS: 192.168.1.110:32400
17:43:12 DNSServer: DNS request received!
17:43:12 DNSServer: Source: ('192.168.1.22', 49793)
17:43:12 DNSServer: Domain: pd-st.itunes.apple.com
17:43:12 DNSServer: ***forward request
17:43:12 DNSServer: -> DNS response from higher level
17:43:12 DNSServer: Source: ('192.168.1.22', 50625)
17:43:12 DNSServer: Domain: a879.phobos.apple.com
17:43:13 DNSServer: -> DNS response from higher level
17:43:59 DNSServer: DNS request received!
17:43:59 DNSServer: Source: ('192.168.1.22', 57213)
17:43:59 DNSServer: Domain: p40-buy.itunes.apple.com.akadns.net
17:43:59 DNSServer: ***forward request
17:43:59 DNSServer: -> DNS response from higher level
17:44:01 DNSServer: DNS request received!
17:44:01 DNSServer: Source: ('192.168.1.22', 52681)
17:44:01 DNSServer: Domain: trailers.apple.com
17:44:01 DNSServer: ***intercept request
17:44:01 DNSServer: -> DNS response: 192.168.1.110
17:50:47 DNSServer: DNS request received!
17:50:47 DNSServer: Source: ('192.168.1.22', 60270)
17:50:47 DNSServer: Domain: 17-courier.push.apple.com
17:50:47 DNSServer: ***forward request
17:50:47 DNSServer: -> DNS response from higher level
18:02:46 DNSServer: DNS request received!
18:02:46 DNSServer: Source: ('192.168.1.22', 63922)
18:02:46 DNSServer: Domain: p40-buy.itunes.apple.com.akadns.net
18:02:46 DNSServer: ***forward request
18:02:46 DNSServer: -> DNS response from higher level
18:02:48 DNSServer: DNS request received!
18:02:48 DNSServer: Source: ('192.168.1.22', 62027)
18:02:48 DNSServer: Domain: trailers.apple.com
18:02:48 DNSServer: ***intercept request
18:02:48 DNSServer: -> DNS response: 192.168.1.110
18:03:46 DNSServer: DNS request received!
18:03:46 DNSServer: Source: ('192.168.1.22', 56635)
18:03:46 DNSServer: Domain: se.itunes.apple.com
18:03:46 DNSServer: ***forward request
18:03:46 DNSServer: -> DNS response from higher level
again:
>>Do an update
To PlexConnect, that is.
I don't want to chase old issues...
Also check your firewall settings. Next thing from aTV is an https request to access "applcation.js".
Hi Baa
Ok did update to latest
Running Maverick
ATV is at 6.02
I recreated the trailers.cer..etc.. incerted them in assets
restarted everything.. not getting the applcation.js
turned firewall off.. as well..just to test
same same.. I still get Trailers is unavailable
here is the log.. ..thanks for ur help !!
Last login: Tue Nov 19 08:18:20 on console
iMac:~ mzn50$ cd /Users/mzn50\ Mac/Desktop/sudo\ .\:PlexConnect.py
Password:
08:19:21 PlexConnect: ***
08:19:21 PlexConnect: PlexConnect
08:19:21 PlexConnect: Press CTRL-C to shut down.
08:19:21 PlexConnect: started: 08:19:21
08:19:21 PlexConnect: IP_self: 192.168.1.110
08:19:21 DNSServer: started: 08:19:21
08:19:21 DNSServer: ***
08:19:21 DNSServer: DNSServer: Serving DNS on 192.168.1.110 port 53.
08:19:21 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.110
08:19:21 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
08:19:21 DNSServer: forward other to higher level DNS: 8.8.8.8
08:19:21 WebServer: started: 08:19:21
08:19:21 WebServer: ***
08:19:21 WebServer: WebServer: Serving HTTP on 192.168.1.110 port 80.
08:19:21 WebServer: WebServer: Serving HTTPS on 192.168.1.110 port 443.
08:19:24 DNSServer: DNS request received!
08:19:24 DNSServer: Source: ('192.168.1.22', 61747)
08:19:24 DNSServer: Domain: bookkeeper.itunes.apple.com
08:19:24 DNSServer: ***forward request
08:19:24 DNSServer: -> DNS response from higher level
08:19:25 DNSServer: DNS request received!
08:19:25 DNSServer: Source: ('192.168.1.22', 56033)
08:19:25 DNSServer: Domain: upp.itunes.apple.com
08:19:25 DNSServer: ***forward request
08:19:25 DNSServer: -> DNS response from higher level
08:20:09 DNSServer: DNS request received!
08:20:10 DNSServer: Source: ('192.168.1.22', 52709)
08:20:10 DNSServer: Domain: trailers.apple.com
08:20:10 DNSServer: ***intercept request
08:20:10 DNSServer: -> DNS response: 192.168.1.110
08:20:11 DNSServer: DNS request received!
08:20:11 DNSServer: Source: ('192.168.1.22', 53728)
08:20:11 DNSServer: Domain: p40-buy.itunes.apple.com.akadns.net
08:20:11 DNSServer: ***forward request
08:20:11 DNSServer: -> DNS response from higher level
1 - Try flushing the DNS caches of aTV, router, host... whatever is involved.
2 -Try - from another computer/smartphone, whatever - to browse to 192.168.1.110:80. What do you see? Do the same for *:443.
so .. still still still having same issue.. I even went out and bought a new Router - Apple extreme ..and I reserved my server on the router to 192.168.1.110
..I still get this error.. its just not kicking on .. I cleared all cache.. any pointers would be appriciated..
thanks !
Last login: Mon Nov 25 11:57:59 on ttys000
Password:
11:58:31 PlexConnect: ***
11:58:31 PlexConnect: PlexConnect
11:58:31 PlexConnect: Press CTRL-C to shut down.
11:58:31 PlexConnect: started: 11:58:31
11:58:31 PlexConnect: IP_self: 192.168.1.110
11:58:31 DNSServer: started: 11:58:31
11:58:31 DNSServer: ***
11:58:31 DNSServer: DNSServer: Serving DNS on 192.168.1.110 port 53.
11:58:31 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.110
11:58:31 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
11:58:31 DNSServer: forward other to higher level DNS: 8.8.8.8
11:58:31 WebServer: started: 11:58:31
11:58:31 WebServer: ***
11:58:31 WebServer: WebServer: Serving HTTP on 192.168.1.110 port 80.
11:58:31 WebServer: WebServer: Serving HTTPS on 192.168.1.110 port 443.
11:58:34 DNSServer: DNS request received!
11:58:34 DNSServer: Source: ('192.168.1.148', 53389)
11:58:34 DNSServer: Domain: bookkeeper.itunes.apple.com
11:58:34 DNSServer: ***forward request
11:58:34 DNSServer: -> DNS response from higher level
11:58:34 DNSServer: Source: ('192.168.1.148', 60331)
11:58:34 DNSServer: Domain: EVIntl-ocsp.verisign.com
11:58:35 DNSServer: DNS request received!
11:58:35 DNSServer: Source: ('192.168.1.148', 49573)
11:58:35 DNSServer: Domain: upp.itunes.apple.com
11:58:35 DNSServer: ***forward request
11:58:35 DNSServer: -> DNS response from higher level
11:58:56 DNSServer: DNS request received!
11:58:56 DNSServer: Source: ('192.168.1.148', 60187)
11:58:56 DNSServer: Domain: p40-buy.itunes.apple.com
11:58:56 DNSServer: ***forward request
11:58:56 DNSServer: -> DNS response from higher level
11:58:56 DNSServer: Source: ('192.168.1.148', 55935)
11:58:56 DNSServer: Domain: www.apple.com
11:59:48 DNSServer: DNS request received!
11:59:48 DNSServer: Source: ('192.168.1.148', 50512)
11:59:48 DNSServer: Domain: se.itunes.apple.com
11:59:48 DNSServer: ***forward request
11:59:48 DNSServer: -> DNS response from higher level
11:59:49 DNSServer: DNS request received!
11:59:49 DNSServer: Source: ('192.168.1.148', 52672)
11:59:49 DNSServer: Domain: a4.mzstatic.com
11:59:49 DNSServer: ***forward request
11:59:49 DNSServer: -> DNS response from higher level
11:59:49 DNSServer: Source: ('192.168.1.148', 63105)
11:59:49 DNSServer: Domain: a1.mzstatic.com
11:59:51 DNSServer: DNS request received!
11:59:51 DNSServer: Source: ('192.168.1.148', 51380)
11:59:51 DNSServer: Domain: trailers.apple.com
11:59:51 DNSServer: ***intercept request
11:59:51 DNSServer: -> DNS response: 192.168.1.110
Any port forwarding on you machine? Virtual Machine? Anything else out of the oridinary? Homesharing on?
Thanks for your response Baa
Port forwading is on for a smart home access - IP and MAC address are clear... no conflict
MyPlex also setup for remote access .. works well
no VMs active
Homesharing working via itunes..
I may just resolve this by playing via my iPad.. which works fine.. and pushing that to the Apple TV .. bummer as I think the resolution is lower
thanks  .. if any other idea.. Im game to try ..
Matt
The fastest solution opposed to troubleshooting is use the plexify app, It will generate everthing for you brand new, even the certs and walk you thru the entire installation automagically. If its still not working maybe you have a firewall or webserver or something else weird blocking ports. I would recommend deleting all the profiles from the atv and using the plexify generated cert on the atv. Restart router, mac, atv everything. Post results. You can use my signature or ibaa plexconnect wiki.
https://github.com/iBaa/PlexConnect/wiki/OSX-and-ATV-with-5.2-firmware-and-ethernet-internet-connection-installation-guide
https://forums.plexapp.com/index.php/topic/85156-plexify-os-x-application/
I flashed ddrwrt on my router as well and everything works fine.
I would strongly suggest you refrain from posting this in every troubleshooting thread.
ok, will do in the future. Just thought since they were osx only threads it would help them automate the install.
thanks guys.. issue is fixed..
This may sound silly but I had renamed my Plexconnect file folder to another name.. to "TV".. Renamed it to PlexConnect .. Refreshed the trailers profile again.. and POP.. Viola.. all good..
Im not saying that was the fix.. have no idea.. But Sheesh.. coincidence.. ?
I now know more about networking then ever cared for   :) !
thanks guys
