I’m still struggling with this. I just set up an entirely fresh jail on 15.0-RELEASE upgraded to the latest pkg versions with basically no customizations (e.g. using the plex user and no separate tmp disk for transcoding) and I’m still running into the same issues, albeit with different errors.
Here’s the beginning of the log file
Jun 07, 2026 08:25:21.263 [0x31b953cde810] INFO - Plex Media Server v1.43.2.10687-563d026ea - FreeBSD PC amd64 - build: freebsd-x86_64 freebsd - GMT -07:00
Jun 07, 2026 08:25:21.264 [0x31b953cde810] INFO - FreeBSD version: 15.0-RELEASE-p8, language: en-US
Jun 07, 2026 08:25:21.264 [0x31b953cde810] INFO - Processor: 8-core Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz
Jun 07, 2026 08:25:21.264 [0x31b953cde810] INFO - Compiler is - Clang 11.0.1 (https://plex.tv -----)
Jun 07, 2026 08:25:21.264 [0x31b953cde810] INFO - /usr/local/share/plexmediaserver/Plex_Media_Server
Jun 07, 2026 08:25:21.263 [0x31b953cde010] DEBUG - BPQ: [Idle] -> [Starting]
Jun 07, 2026 08:25:21.263 [0x31b953cde010] DEBUG - FeatureManager: Using cached data for features list
Jun 07, 2026 08:25:21.265 [0x31b953cde010] DEBUG - MyPlex: mapping state set to 'Unknown'.
Jun 07, 2026 08:25:21.265 [0x31b953cde010] DEBUG - Relay: read 0 cached entries from hosts file
Jun 07, 2026 08:25:21.265 [0x31b953cde010] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.39.4, threadsafe=1
Jun 07, 2026 08:25:21.267 [0x31b953cde010] INFO - SQLITE3:(nil), 283, recovered 624 frames from WAL file /usr/local/plexdata/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Jun 07, 2026 08:25:21.290 [0x31b953cde010] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/users/features?filterFeatures[]=b83c8dc9-5a01-4b7a-a7c9-5870c8a6e21b&filterFeatures[]=926bc176-58ca-47da-b8e3-080ed14ea6ba&filterFeatures[]=ea791163-c28d-4b7c-af88-bcc9553b206d&filterFeatures[]=6ab6677b-ad9b-444f-9ca1-b8027d05b3e1&filterFeatures[]=56cd352b-0d47-436d-aced-f20db3508de5
Jun 07, 2026 08:25:21.307 [0x31b953cde010] DEBUG - [CERT] Subject name is /CN=*.----.plex.direct
Jun 07, 2026 08:25:21.307 [0x31b953cde010] DEBUG - [CERT] Installed certificate with fingerprint ----.
Jun 07, 2026 08:25:21.307 [0x31b953cde010] DEBUG - [CERT/OCSP] no URL available
Jun 07, 2026 08:25:21.307 [0x31b953cde010] WARN - [CERT/OCSP] getCertInfo failed; skipping stapling
Jun 07, 2026 08:25:21.307 [0x31b953cde010] DEBUG - HttpServer: Listening on port 32400.
Jun 07, 2026 08:25:21.307 [0x31b953cde010] DEBUG - HttpServer: Listening on port 32401.
and when I try to watch something remotely the logs blow up with
Jun 07, 2026 08:29:16.950 [0x31b953d0b010] ERROR - [Req#771f/Transcode/18d7e6c4-7426-4432-b2b1-41b5cd2e3f1b/2100d4fe-42f7-4c2c-9894-533fb878c1b1] [vost#0:0/copy @ 0x14033942b780] Too many packets buffered for output stream 0:0.
Jun 07, 2026 08:29:16.950 [0x31b953d0b010] ERROR - [Req#7720/Transcode/18d7e6c4-7426-4432-b2b1-41b5cd2e3f1b/2100d4fe-42f7-4c2c-9894-533fb878c1b1] [vost#0:0/copy @ 0x14033942b780] Error submitting a packet to the muxer
with messages like this interspersed
Jun 07, 2026 08:29:17.223 [0x31b953d1d010] ERROR - [Req#7ecb/Transcode/18d7e6c4-7426-4432-b2b1-41b5cd2e3f1b/2100d4fe-42f7-4c2c-9894-533fb878c1b1] [eac3_eae @ 0x14033943b400] Cannot group in blocks of 6!
Jun 07, 2026 08:29:17.223 [0x31b953d1d010] ERROR - [Req#7ecc/Transcode/18d7e6c4-7426-4432-b2b1-41b5cd2e3f1b/2100d4fe-42f7-4c2c-9894-533fb878c1b1] [aist#0:1/eac3 @ 0x140339426900] Error submitting packet to decoder: Invalid data found when
processing input
until I kill the attempt to play the video.
What can I do to debug this?
