I’m not certain if this is a bug or if it is me but basically everything is working except playing audio files from 1 particular album have wrong track length when playing in iOS.
iOS Plaver Version 4.2
Server Version 1.0.2.2413
Source files are flac, but the tags show the correct track length from a file perspective:
Plex server shows the correct track length:
I should have said, the files play perfectly. Once played the time does not update however.
As it gets to the ‘end’ of the time duration shown the tracks just carry on playing to the end. It also cycles into the next track ok so it’s not a huge issue but does mean I can’t scrub forward or back using the orange timeline bar.
Playback itself is not affected.
I just wanted to add that I also have the same problem on Android.
Plex for Android version: 4.29.1.7
Plex Server Version: 1.0.3.2461
I also took a look at the transcoded file, named file.mp3, in the associated data/com.plexapp.android/files/sync/… subdirectory of the sdcard. The mp3 has no ID3 tag info so I presume the metadata is stored separately. The mp3 file header however has the correct length.
