Server Version#: 1.19.4.2902
Player Version#: 1.12.0.1232-aacabe78
Running on Server 2019 1809
For the last few weeks I’ve been experiencing repeated crashes of the transcoder, found a few similar topics but figured I would open a new topic with logs in case the cause isn’t the same. Crash is being experience on all clients (Xbox, PS4, IOS, Roku, Windows, Web) local and remote when transcoding is used.
So far I’ve done a few things to troubleshoot:
- Disabled Windows Defender
- Disabled Windows Firewall
- Manually check files with ffmpeg
- Move transcode temp files to a faster disk (ssd)
I saw the post about port exhaustion so I checked the Windows event log and did EventID 4227 but the last occurrence was on May 31, as a quick attempt at a fix I’ve increased the TCP port count to 30k to see if it makes any difference. While watching a transcoded video I just kicked off all my library updates and got a crash not long after, did a TCP port count and saw this:
PS C:\Windows\system32> netstat -anobp TCP | measure-object -line
Lines Words Characters Property
29623
Grabbed the most recent crash with transcoder debug logs on and this seems to be the relevant lines:
Line 29986: Jun 05, 2020 14:04:06.321 [6728] INFO - [Transcoder] [segment @ 02d05140] Opening 'http://127.0.0.1:32400/video/:/transcode/session/l6x4jk9jhqjig4qgose81s7g/adca07ae-3bb7-41c1-b2db-9fd8d40e7084/seglist?X-Plex-Http-Pipeline=infinite' for writing
Line 29987: Jun 05, 2020 14:04:06.323 [6728] DEBUG - [Transcoder] [tcp @ 00f10b80] Starting connection attempt to 127.0.0.1 port 32400
Line 30468: Jun 05, 2020 14:04:11.354 [7148] DEBUG - [Transcoder] [tcp @ 00f10b80] Connection attempt to 127.0.0.1 port 32400 failed: Error number -138 occurred
Line 30469: Jun 05, 2020 14:04:11.354 [7148] ERROR - [Transcoder] [tcp @ 00f10b80] Connection to tcp://127.0.0.1:32400 failed: Error number -138 occurred
Line 30470: Jun 05, 2020 14:04:11.354 [7148] ERROR - [Transcoder] [segment @ 02d05140] Failed to open segment list 'http://127.0.0.1:32400/video/:/transcode/session/l6x4jk9jhqjig4qgose81s7g/adca07ae-3bb7-41c1-b2db-9fd8d40e7084/seglist?X-Plex-Http-Pipeline=infinite'
Line 30471: Jun 05, 2020 14:04:11.355 [7148] DEBUG - [Transcoder] [AVIOContext @ 07dfb940] Statistics: 0 seeks, 12 writeouts
Line 30472: Jun 05, 2020 14:04:11.355 [7148] ERROR - [Transcoder] av_interleaved_write_frame(): Unknown error
Line 30473: Jun 05, 2020 14:04:11.355 [7148] DEBUG - [Transcoder] No more output streams to write to, finishing.
Plex Media Server Logs_2020-06-05_14-09-20.zip (4.7 MB)
