Transcoder Error with Hauppage WinTV DualHD
Hey,
I’ve been attempting to get the DVR to record, but each time I try to record anything it simply says “There was a transcoder error”
Server version 1.7.1.3856
Here is the logs from an attempt:
Jun 02, 2017 11:14:20.646 [2296] INFO - * web_service_t::process_start_channel (device compound_device041dvb#bda#usb#vid_2040&pid_026d#0013862421#, channel triplet://0:2595:1)
Jun 02, 2017 11:14:20.646 [2296] INFO - * device_reactor_t::get_device_list (dvb#bda#usb#vid_2040&pid_026d#0013862421#)
Jun 02, 2017 11:14:20.646 [2296] INFO - * dvb_device_factory_t::get_device_list (dvb#bda#usb#vid_2040&pid_026d#0013862421#)
Jun 02, 2017 11:14:20.647 [8452] INFO - * DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD ATSC Tuner 2]
Jun 02, 2017 11:14:20.647 [8452] INFO - * DeviceGetListEx_impl: device instance path usb#vid_2040&pid_026d#0013862421#
Jun 02, 2017 11:14:20.647 [8452] INFO - * DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD ATSC Tuner]
Jun 02, 2017 11:14:20.647 [8452] DEBUG - * enum_get_name(): IPropertyBag->Read method failed -2147024894
Jun 02, 2017 11:14:20.647 [8452] DEBUG - * BDA: DeviceGetListEx_impl. Skipped nameless BDA driver
Jun 02, 2017 11:14:20.648 [8452] DEBUG - * enum_get_name(): IPropertyBag->Read method failed -2147024894
Jun 02, 2017 11:14:20.648 [8452] DEBUG - * BDA: DeviceGetListEx_impl. Skipped nameless BDA driver
Jun 02, 2017 11:14:20.648 [8452] INFO - * DeviceGetListEx_impl: pDL->Count:2
Jun 02, 2017 11:14:20.648 [2296] INFO - * dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}, Name Hauppauge WinTV-dualHD ATSC Tuner 2, Standards 24
Jun 02, 2017 11:14:20.648 [2296] INFO - * dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{7c8095ab-c110-40e5-9f4d-310858bbbf64}, Name Hauppauge WinTV-dualHD ATSC Tuner, Standards 24
Jun 02, 2017 11:14:20.648 [2296] INFO - * device_manager_t::get_device_list. Device Hauppauge WinTV-dualHD ATSC Tuner 2, id dvb#bda#0#@device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}, tuners 1, state 0, standards 24
Jun 02, 2017 11:14:20.648 [2296] INFO - * device_manager_t::get_device_list. Device Hauppauge WinTV-dualHD ATSC Tuner, id dvb#bda#0#@device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{7c8095ab-c110-40e5-9f4d-310858bbbf64}, tuners 1, state 0, standards 24
Jun 02, 2017 11:14:20.649 [2296] INFO - * device_manager_t::add_streamer. Channel triplet://0:2595:1, device dvb#bda#0#@device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}, streamer id ec8e3a40-53fa-42df-a83d-daa0a9a2fd72
Jun 02, 2017 11:14:20.649 [2296] INFO - * device_reactor_t::create_device dvb#bda#0#@device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}
Jun 02, 2017 11:14:20.650 [6672] INFO - * DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD ATSC Tuner 2]
Jun 02, 2017 11:14:20.650 [6672] INFO - * DeviceGetListEx_impl: device instance path usb#vid_2040&pid_026d#0013862421#
Jun 02, 2017 11:14:20.650 [6672] INFO - * DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD ATSC Tuner]
Jun 02, 2017 11:14:20.651 [6672] DEBUG - * enum_get_name(): IPropertyBag->Read method failed -2147024894
Jun 02, 2017 11:14:20.651 [6672] DEBUG - * BDA: DeviceGetListEx_impl. Skipped nameless BDA driver
Jun 02, 2017 11:14:20.651 [6672] INFO - * DeviceGetListEx_impl: pDL->Count:2
Jun 02, 2017 11:14:20.651 [2296] INFO - * device_manager_t::add_streamer. Adding new streamer container for channel triplet://0:2595:1 on device device dvb#bda#0#@device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}.
Jun 02, 2017 11:14:20.652 [2296] INFO - * transponder_streamer::start_idle_timer
Jun 02, 2017 11:14:20.652 [2296] INFO - * tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 2595, sid 1
Jun 02, 2017 11:14:20.652 [6628] INFO - * streamer_container_t::control_thread. Added streamer ec8e3a40-53fa-42df-a83d-daa0a9a2fd72
Jun 02, 2017 11:14:20.652 [6628] INFO - * streamer_container_t::control_thread. First streamer was added. Start program streamer
Jun 02, 2017 11:14:20.652 [6628] INFO - * dvb_program_streamer_t::start. Starting program streamer for channel triplet://0:2595:1
Jun 02, 2017 11:14:20.652 [6628] INFO - * transponder_streamer::start_channel. Start request for channel triplet://0:2595:1
Jun 02, 2017 11:14:20.652 [6628] INFO - * transponder_streamer::stop_idle_timer
Jun 02, 2017 11:14:20.703 [7336] INFO - * DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD ATSC Tuner 2]
Jun 02, 2017 11:14:20.703 [7336] INFO - * DeviceGetListEx_impl: device instance path usb#vid_2040&pid_026d#0013862421#
Jun 02, 2017 11:14:20.703 [7336] INFO - * DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD ATSC Tuner]
Jun 02, 2017 11:14:20.704 [7336] DEBUG - * enum_get_name(): IPropertyBag->Read method failed -2147024894
Jun 02, 2017 11:14:20.704 [7336] DEBUG - * BDA: DeviceGetListEx_impl. Skipped nameless BDA driver
Jun 02, 2017 11:14:20.704 [7336] INFO - * DeviceGetListEx_impl: pDL->Count:2
Jun 02, 2017 11:14:20.704 [7336] INFO - * find_device_by_path. searching for matching tuner with device path @device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}
Jun 02, 2017 11:14:20.704 [7336] INFO - * find_device_by_path. Found device index 0 for device path @device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}
Jun 02, 2017 11:14:20.704 [7336] INFO - * StartDevice() dwDeviceNo:0
Jun 02, 2017 11:14:20.707 [7336] INFO - * BDA Device Name: [Hauppauge WinTV-dualHD ATSC Tuner 2]
Jun 02, 2017 11:14:20.707 [7336] INFO - * add_filter (Hauppauge WinTV-dualHD ATSC Tuner 2)
Jun 02, 2017 11:14:20.708 [7336] INFO - * Tuner identity: vid (2040), pid (026d), subsys ()
Jun 02, 2017 11:14:20.708 [7336] INFO - * ret_val: 0
Jun 02, 2017 11:14:20.708 [7336] INFO - * add_filter (Microsoft Network Provider)
Jun 02, 2017 11:14:20.713 [7336] INFO - * TuningSpace Name: ‘Antenna’ NetworkType: {00000000-0000-0000-0000-000000000000}
Jun 02, 2017 11:14:20.713 [7336] INFO - * TuningSpace Name: ‘ATSC’ NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Jun 02, 2017 11:14:20.713 [7336] INFO - * Enumeration found 2 tuning spaces
Jun 02, 2017 11:14:20.714 [7336] INFO - * Found TuningSpace
Jun 02, 2017 11:14:20.719 [7336] INFO - * GetTunerInterfaces: Pin types (2) :
Jun 02, 2017 11:14:20.719 [7336] INFO - * GetTunerInterfaces: Pin 0 Type = Input
Jun 02, 2017 11:14:20.719 [7336] INFO - * GetTunerInterfaces: Pin 1 Type = Output
Jun 02, 2017 11:14:20.719 [7336] INFO - * GetTunerInterfaces: Node types (3):
Jun 02, 2017 11:14:20.719 [7336] INFO - * GetTunerInterfaces: Node 0 Type = 0
Jun 02, 2017 11:14:20.719 [7336] INFO - * GetTunerInterfaces: Node 1 Type = 1
Jun 02, 2017 11:14:20.719 [7336] INFO - * GetTunerInterfaces: Node 2 Type = 2
Jun 02, 2017 11:14:20.719 [7336] INFO - * GetTunerInterfaces: Node interfaces:
Jun 02, 2017 11:14:20.719 [7336] INFO - * GetTunerInterfaces: Interfaces on NodeType 0 (2 interfaces):
Jun 02, 2017 11:14:20.720 [7336] INFO - * GetTunerInterfaces: {71985F47-1CA1-11D3-9CC8-00C04F7971E0} IID_IBDA_FrequencyFilter
Jun 02, 2017 11:14:20.720 [7336] INFO - * GetTunerInterfaces: {1347D106-CF3A-428A-A5CB-AC0D9A2A4338} IID_IBDA_SignalStatistics
Jun 02, 2017 11:14:20.720 [7336] INFO - * GetTunerInterfaces: Interfaces on NodeType 1 (3 interfaces):
Jun 02, 2017 11:14:20.720 [7336] INFO - * GetTunerInterfaces: {DDF15B12-BD25-11D2-9CA0-00C04F7971E0} IID_IBDA_AutoDemodulate - QueryInterface FAILED ! - hr = 0x80004002
Jun 02, 2017 11:14:20.720 [7336] INFO - * GetTunerInterfaces: {EF30F379-985B-4D10-B640-A79D5E04E1E0} IID_IBDA_DigitalDemodulator
Jun 02, 2017 11:14:20.720 [7336] INFO - * GetTunerInterfaces: Interfaces on NodeType 2 (3 interfaces):
Jun 02, 2017 11:14:20.720 [7336] INFO - * Looking for preferred capture for tuner @device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}
Jun 02, 2017 11:14:20.721 [7336] INFO - * Found preferred capture: @device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}{bc102acb-6095-451d-8ed6-16cf3c832ebc}
Jun 02, 2017 11:14:20.721 [7336] INFO - * add_filter (Hauppauge WinTV-dualHD TS Capture)
Jun 02, 2017 11:14:20.722 [7336] INFO - * add_filter (Sample grabber)
Jun 02, 2017 11:14:20.724 [7336] INFO - * add_filter (MPEG-2 Demultiplexer)
Jun 02, 2017 11:14:20.725 [7336] INFO - * add_filter (BDA MPEG2 Transport Information Filter)
Jun 02, 2017 11:14:23.870 [7336] INFO - * start_graph: hr=0, state=2
Jun 02, 2017 11:14:23.870 [7336] INFO - * StartDevice() OK
Jun 02, 2017 11:14:23.870 [7336] INFO - * ----------------------------------------------------------------------------
Jun 02, 2017 11:14:23.870 [7336] INFO - * CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 15, modulation 0, polarization 0, symbol rate 0, LOF 0, LNB selection signal 0, FEC 0
Jun 02, 2017 11:14:23.870 [7336] INFO - * SetTuner() 15, H, 0 Mod:0 LOF:0 22Khz:0
Jun 02, 2017 11:14:26.189 [6628] INFO - * transponder_streamer::tune_transponder_impl. Signal stats: 0, 0, 0
Jun 02, 2017 11:14:26.189 [8328] INFO - * tvs_program_streamer::tuning_thread. Starting tuning thread for program triplet://0:2595:1
Jun 02, 2017 11:14:26.189 [8328] INFO - * tvs_program_streamer::SetPATScanState. Waiting for PAT…
Jun 02, 2017 11:14:26.193 [10864] INFO - * http_streamer_t::send_thread_func: adding http client
Jun 02, 2017 11:14:26.238 [7336] INFO - * CTVSStreamSource::AddPID. Requesting PID 0, client triplet://0:2595:1
Jun 02, 2017 11:14:26.289 [7336] INFO - * CTVSStreamSource::AddPID. Requesting PID 1, client triplet://0:2595:1
Jun 02, 2017 11:14:51.666 [11096] WARN - [E] http_streamer_t: http write error
Jun 02, 2017 11:14:51.666 [10864] INFO - * http_streamer_t::send_thread_func: removing http client
Jun 02, 2017 11:14:51.666 [10864] INFO - * http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Jun 02, 2017 11:14:51.679 [6628] INFO - * streamer_container_t::control_thread. Removed disconnected streamer ec8e3a40-53fa-42df-a83d-daa0a9a2fd72
Jun 02, 2017 11:14:51.679 [6628] INFO - * streamer_container_t::delete_streamer. Last streamer was deleted. Stop program streamer
Jun 02, 2017 11:14:51.679 [6628] INFO - * dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://0:2595:1
Jun 02, 2017 11:14:51.679 [6628] INFO - * transponder_streamer::stop_channel. Stop request for channel triplet://0:2595:1
Jun 02, 2017 11:14:51.700 [8328] INFO - * tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet://0:2595:1
Jun 02, 2017 11:14:51.710 [7336] INFO - * CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://0:2595:1
Jun 02, 2017 11:14:51.710 [6628] INFO - * transponder_streamer::start_idle_timer
Jun 02, 2017 11:14:56.312 [2676] INFO - * device_manager_t::idle_timer_func. Stream container for channel triplet://0:2595:1 on device dvb#bda#0#@device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{510162d9-2f7e-49e7-907b-dbd3a5a15eb9} is idle. Deleting it.
Jun 02, 2017 11:15:01.676 [4164] INFO - * Stopping graph
Jun 02, 2017 11:15:01.677 [7336] INFO - * StopDevice()
Jun 02, 2017 11:15:02.217 [7336] INFO - * stop_graph: hr=0, state=0
Jun 02, 2017 11:15:06.333 [2676] INFO - * device_manager_t::idle_timer_func. Device dvb#bda#0#@device:pnp:\?\usb#vid_2040&pid_026d#0013862421#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{510162d9-2f7e-49e7-907b-dbd3a5a15eb9} is idle. Unloading it.
Jun 02, 2017 11:15:06.333 [2676] INFO - * transponder_streamer::stop_idle_timer
Jun 02, 2017 11:15:06.333 [2676] INFO - * CTVSStreamSource::Term. Waiting for streaming thread to stop
Jun 02, 2017 11:15:06.348 [2676] INFO - * CTVSStreamSource::Term. Streaming is stopped
Jun 02, 2017 11:15:06.349 [2676] INFO - * CTVSStreamSource::Term. Stream source is stopped
Jun 02, 2017 11:15:07.221 [4164] INFO - * transponder_streamer::idle_thread_func finished
Thanks,
-Alex
Please attach Plex Media Server and Plex Tuner Service log files in order for us to help troubleshoot this issue.
Hey Keith,
Let me know if these help.
-Alex
Unfortunately… we don’t know. Maybe try reinstalling the drivers? I asked one of our folks and it has us scratching our heads.
If you have another computer you could try, maybe just install the driver (no wintv) and see if it works there? Super strange.
@edibleegg did you had any issues detecting channels? I’ve got the DualHD too on a windows server 2012R2 and he can’t find any channels
@Fridleif try installing:
https://knowledge.zomers.eu/dvblogic/Pages/How-to-add-BDA-support-to-Windows-Server-2012.aspx
For 2012R2.
@keithah
I did - and now I can’t even search for channels anymore :frowning:
I can click on the button to search but nothing happens
Hmm, I think the issue might have either been a poor signal or the small antenna that comes with the WinTV isn’t very good. I hooked it up to an Amazon Ultra Thin Indoor 35 Mile antenna and it worked fine.
Correct, don’t use the antenna that comes w/ the tuner!
Also, try this for 2012R2 folks: https://forums.plex.tv/discussion/comment/1452918/#Comment_1452918
