DVR / Live TV not working with Hauppauge Digital TV Tuner for Xbox One
greetings folks,
i’m having serious issues getting this device to work as advertised… hoping i can have some direction on what i can try.
I will try and list some relevant details :
  1. I have purchased a http://www.hauppauge.com/site/products/data_xboxtv.html
  2. it is recognized and seems to scan available channels properly under plex. (i get some 12 networks, which is great) - although it does come up as WinTV-HVR-955Q in plex
  3. i have latest and greatest plex media server (currently 1.7.2.3878) - under Ubuntu LTS 16.04.02
  4. i have added Hauppauge repo, and followed instructions from : http://www.hauppauge.com/site/support/linux.html
Whenever i try to record, or view ‘live’ on my phone it is all full of errors.
Are there any log files or outputs of commands i could add on here to make this easier to debug?
hmmm - I just noticed DVR Beta / Live TV forum subsection - should i repost this there?
Did you ever have any luck with this issue? I am having the same problems.
That is not up to date. You need version 1.7.2.x for DVR/Live TV support.
This fixed it for me…
Despite the in browser settings saying my server version was up to date, it clearly was not. I was still in version 1.5.5.x. As soon as I manually updated, my Hauppauge stick was found immediately. Hopefully everything else is smooth sailing from here on out.
The recordings look all weird, plex bails on play attempts. Logs full of errors :confused:
here is a sample of Plex Tuner Log file :
700] INFO - * web_service_t::process_start_channel (device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:11.0/0000:02:02.0/usb1/1-1/1-1:
1.1, channel triplet://0:17201:1)
Jun 13, 2017 10:28:31.740 [0x7f821f7fe700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
Jun 13, 2017 10:28:31.740 [0x7f821f7fe700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend
0
Jun 13, 2017 10:28:31.745 [0x7f821f7fe700] INFO - * device_manager_t::add_streamer. Channel triplet://0:17201:1, device dvb#v4l#0#/s
ys/devices/pci0000:00/0000:00:11.0/0000:02:02.0/usb1/1-1/1-1:1.1, streamer id fc4cf644-df1d-42d7-bee1-3b532138e271
Jun 13, 2017 10:28:31.745 [0x7f821f7fe700] INFO - * device_reactor_t::create_device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:11.0/0
Jun 13, 2017 10:28:31.745 [0x7f821f7fe700] INFO - * device_manager_t::add_streamer. Adding new streamer container for channel triple
t://0:17201:1 on device device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:11.0/0000:02:02.0/usb1/1-1/1-1:1.1.
Jun 13, 2017 10:28:31.746 [0x7f821f7fe700] INFO - * transponder_streamer::start_idle_timer
Jun 13, 2017 10:28:31.747 [0x7f821f7fe700] INFO - * tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 17201,
sid 1
Jun 13, 2017 10:28:31.747 [0x7f821aff5700] INFO - * streamer_container_t::control_thread. Added streamer fc4cf644-df1d-42d7-bee1-3b5
32138e271
Jun 13, 2017 10:28:31.747 [0x7f821aff5700] INFO - * streamer_container_t::control_thread. First streamer was added. Start program st
reamer
Jun 13, 2017 10:28:31.747 [0x7f821aff5700] INFO - * dvb_program_streamer_t::start. Starting program streamer for channel triplet://0
:17201:1
Jun 13, 2017 10:28:31.747 [0x7f821aff5700] INFO - * transponder_streamer::start_channel. Start request for channel triplet://0:17201
:1
Jun 13, 2017 10:28:31.747 [0x7f821aff5700] INFO - * transponder_streamer::stop_idle_timer
Jun 13, 2017 10:28:31.797 [0x7f8218ff1700] INFO - * find_device_by_path. searching for matching tuner with device path /sys/devices/
Jun 13, 2017 10:28:31.797 [0x7f8218ff1700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
Jun 13, 2017 10:28:31.797 [0x7f8218ff1700] INFO - * v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend
0
Jun 13, 2017 10:28:31.799 [0x7f8218ff1700] INFO - * find_device_by_path. Found device index 0 for device path /sys/devices/pci0000:0
Jun 13, 2017 10:28:31.799 [0x7f8218ff1700] INFO - * Starting tuner 0, frontend 0
Jun 13, 2017 10:28:32.463 [0x7f8218ff1700] INFO - * tuner 0, frontend 0 was opened successfully
Jun 13, 2017 10:28:32.464 [0x7f8218ff1700] INFO - * detected tuner ids: vendor (2040), product (b123)
Jun 13, 2017 10:28:32.464 [0x7f8218ff1700] INFO - * No ca0 node is present for tuner 0
Jun 13, 2017 10:28:32.464 [0x7f8218ff1700] INFO - * CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 13
, modulation 0, polarization 0, symbol rate 0, LOF 0, LNB selection signal 0, FEC 0
Jun 13, 2017 10:28:32.464 [0x7f8218ff1700] INFO - * Tuning request. 13, 0, 0, 0, 0, 0, 0
Jun 13, 2017 10:28:32.474 [0x7f8218ff1700] WARN - [W] CV4lTunersStreamSrc::Start. pthread_setschedparam failed 1
Jun 13, 2017 10:28:32.474 [0x7f821a7f4700] INFO - * Starting streaming thread for tuner 0, frontend 0
Jun 13, 2017 10:28:32.474 [0x7f821a7f4700] INFO - * tuner 0, demux 0. adding PID 20
Jun 13, 2017 10:28:34.044 [0x7f821aff5700] INFO - * transponder_streamer::tune_transponder_impl. Signal stats: 10, 100, 1
Jun 13, 2017 10:28:34.044 [0x7f81eb7fe700] INFO - * tvs_program_streamer::tuning_thread. Starting tuning thread for program triplet:
//0:17201:1
Jun 13, 2017 10:28:34.044 [0x7f81eb7fe700] INFO - * tvs_program_streamer::SetPATScanState. Waiting for PAT…
Jun 13, 2017 10:28:34.053 [0x7f82197f2700] INFO - * http_streamer_t::send_thread_func: adding http client
Jun 13, 2017 10:28:34.094 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 0, client triplet://0:17201:1
Jun 13, 2017 10:28:34.101 [0x7f821a7f4700] INFO - * tuner 0, demux 0. adding PID 0
Jun 13, 2017 10:28:34.145 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 1, client triplet://0:17201:1
Jun 13, 2017 10:28:34.151 [0x7f821a7f4700] INFO - * tuner 0, demux 0. adding PID 1
Jun 13, 2017 10:28:34.446 [0x7f81eb7fe700] INFO - * tvs_program_streamer::tuning_thread. Waiting for PMT…
Jun 13, 2017 10:28:34.447 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 48, client triplet://0:17201:1
Jun 13, 2017 10:28:34.458 [0x7f821a7f4700] INFO - * tuner 0, demux 0. adding PID 48
Jun 13, 2017 10:28:38.860 [0x7f81eb7fe700] INFO - * tvs_program_streamer::tuning_thread. PAT and PMT found. Checking CA descriptors
Jun 13, 2017 10:28:38.910 [0x7f81eb7fe700] INFO - * tvs_program_streamer::tuning_thread. Start streaming
Jun 13, 2017 10:28:38.956 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 49, client triplet://0:17201:1
Jun 13, 2017 10:28:38.956 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 51, client triplet://0:17201:1
Jun 13, 2017 10:28:38.956 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 52, client triplet://0:17201:1
Jun 13, 2017 10:28:38.957 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 53, client triplet://0:17201:1
Jun 13, 2017 10:28:38.957 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 49, client triplet://0:17201:1
Jun 13, 2017 10:28:38.957 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 0, client triplet://0:17201:1
Jun 13, 2017 10:28:38.957 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 1, client triplet://0:17201:1
Jun 13, 2017 10:28:38.957 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 16, client triplet://0:17201:1
Jun 13, 2017 10:28:38.957 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 17, client triplet://0:17201:1
Jun 13, 2017 10:28:38.957 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 18, client triplet://0:17201:1
Jun 13, 2017 10:28:38.957 [0x7f821a7f4700] INFO - * tuner 0, demux 0. adding PID 49
Jun 13, 2017 10:28:38.957 [0x7f8218ff1700] INFO - * CTVSStreamSource::AddPID. Requesting PID 8191, client triplet://0:17201:1
Jun 13, 2017 10:28:38.967 [0x7f821a7f4700] INFO - * tuner 0, demux 0. adding PID 51
Jun 13, 2017 10:28:38.967 [0x7f821a7f4700] INFO - * tuner 0, demux 0. adding PID 52
Jun 13, 2017 10:28:38.977 [0x7f821a7f4700] INFO - * tuner 0, demux 0. adding PID 53
Jun 13, 2017 10:28:38.985 [0x7f821a7f4700] INFO - * tuner 0, demux 0. adding PID 16
Jun 13, 2017 10:28:38.985 [0x7f821a7f4700] INFO - * tuner 0, demux 0. adding PID 17
Jun 13, 2017 10:28:38.995 [0x7f821a7f4700] INFO - * tuner 0, demux 0. adding PID 18
Jun 13, 2017 10:28:39.007 [0x7f81eb7fe700] INFO - * tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet:
//0:17201:1
Jun 13, 2017 10:28:39.918 [0x7f8218ff1700] INFO - * CTSStreamWaiter::GetPidToCheck. PID to check 49
Jun 13, 2017 10:28:39.918 [0x7f8218ff1700] INFO - * CTSStreamWaiter::GetVideoPid. Video PID 49
Jun 13, 2017 10:28:39.918 [0x7f8218ff1700] INFO - * CTSStreamWaiter::ProcessStream. Found first not encrypted packet. Start streamin
g
Jun 13, 2017 10:28:52.446 [0x7f821dffb700] WARN - [E] http_streamer_t: http write error
Jun 13, 2017 10:28:52.446 [0x7f82197f2700] INFO - * http_streamer_t::send_thread_func: removing http client
Jun 13, 2017 10:28:52.446 [0x7f82197f2700] INFO - * http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Jun 13, 2017 10:28:52.450 [0x7f821aff5700] INFO - * streamer_container_t::control_thread. Removed disconnected streamer fc4cf644-df1
Jun 13, 2017 10:28:52.450 [0x7f821aff5700] INFO - * streamer_container_t::delete_streamer. Last streamer was deleted. Stop program s
treamer
Jun 13, 2017 10:28:52.450 [0x7f821aff5700] INFO - * dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://0:1
7201:1
Jun 13, 2017 10:28:52.450 [0x7f821aff5700] INFO - * transponder_streamer::stop_channel. Stop request for channel triplet://0:17201:1
Jun 13, 2017 10:28:52.465 [0x7f8218ff1700] INFO - * CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://0:17201:1
Jun 13, 2017 10:28:52.465 [0x7f821aff5700] INFO - * transponder_streamer::start_idle_timer
Jun 13, 2017 10:28:52.475 [0x7f821a7f4700] INFO - * tuner 0, demux 0. Deleting PID 0
Jun 13, 2017 10:28:52.483 [0x7f821a7f4700] INFO - * tuner 0, demux 0. Deleting PID 1
Jun 13, 2017 10:28:52.483 [0x7f821a7f4700] INFO - * tuner 0, demux 0. Deleting PID 16
Jun 13, 2017 10:28:52.493 [0x7f821a7f4700] INFO - * tuner 0, demux 0. Deleting PID 17
Jun 13, 2017 10:28:52.501 [0x7f821a7f4700] INFO - * tuner 0, demux 0. Deleting PID 18
Jun 13, 2017 10:28:52.501 [0x7f821a7f4700] INFO - * tuner 0, demux 0. Deleting PID 48
Jun 13, 2017 10:28:52.511 [0x7f821a7f4700] INFO - * tuner 0, demux 0. Deleting PID 49
Jun 13, 2017 10:28:52.519 [0x7f821a7f4700] INFO - * tuner 0, demux 0. Deleting PID 51
Jun 13, 2017 10:28:52.529 [0x7f821a7f4700] INFO - * tuner 0, demux 0. Deleting PID 52
Jun 13, 2017 10:28:52.537 [0x7f821a7f4700] INFO - * tuner 0, demux 0. Deleting PID 53
Jun 13, 2017 10:28:52.547 [0x7f821a7f4700] INFO - * tuner 0, demux 0. Deleting PID 8191
Jun 13, 2017 10:28:54.188 [0x7f8224903700] INFO - * device_manager_t::idle_timer_func. Stream container for channel triplet://0:1720
1:1 on device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:11.0/0000:02:02.0/usb1/1-1/1-1:1.1 is idle. Deleting it.
Jun 13, 2017 10:29:01.749 [0x7f81ebfff700] INFO - * Stopping graph
Jun 13, 2017 10:29:01.794 [0x7f8218ff1700] INFO - * Stop device request for tuner 0, frontend 0
Jun 13, 2017 10:29:01.920 [0x7f821a7f4700] INFO - * Exiting streaming thread for tuner 0, frontend 0
Jun 13, 2017 10:29:04.209 [0x7f8224903700] INFO - * device_manager_t::idle_timer_func. Device dvb#v4l#0#/sys/devices/pci0000:00/0000
:00:11.0/0000:02:02.0/usb1/1-1/1-1:1.1 is idle. Unloading it.
Jun 13, 2017 10:29:04.209 [0x7f8224903700] INFO - * transponder_streamer::stop_idle_timer
Jun 13, 2017 10:29:04.209 [0x7f8224903700] INFO - * CTVSStreamSource::Term. Waiting for streaming thread to stop
Jun 13, 2017 10:29:04.228 [0x7f8218ff1700] INFO - * Stop device request for tuner 65535, frontend 0
Jun 13, 2017 10:29:04.228 [0x7f8224903700] INFO - * CTVSStreamSource::Term. Streaming is stopped
Jun 13, 2017 10:29:04.228 [0x7f8224903700] INFO - * CTVSStreamSource::Term. Stream source is stopped
Jun 13, 2017 10:29:04.921 [0x7f81ebfff700] INFO - * transponder_streamer::idle_thread_func finished
and Plex Media Server.log :
Jun 13, 2017 10:28:31.695 [0x7f63f17fc700] ERROR - Unable to find title for item of type 5
Jun 13, 2017 10:28:40.310 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x3176660] Invalid frame dimensions 0x0.
Jun 13, 2017 10:28:40.430 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x3176660] Invalid frame dimensions 0x0.
Jun 13, 2017 10:28:40.528 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x3176660] Invalid frame dimensions 0x0.
Jun 13, 2017 10:28:40.562 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x3176660] Invalid frame dimensions 0x0.
Jun 13, 2017 10:28:40.660 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x3176660] Invalid frame dimensions 0x0.
Jun 13, 2017 10:28:40.764 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x3176660] Invalid frame dimensions 0x0.
Jun 13, 2017 10:28:42.103 [0x7f63fe7ff700] ERROR - ClientProfileExtra: missing protocol parameter
Jun 13, 2017 10:28:42.103 [0x7f63fe7ff700] WARN - ClientProfileExtra: ignoring directive: add-transcode-target(type=videoProfile&context=static&container=mp4&videoCodec=h264&audioCodec=aac,ac3&subtitleCodec=mov_text)
Jun 13, 2017 10:28:42.103 [0x7f63fe7ff700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Jun 13, 2017 10:28:42.103 [0x7f63fe7ff700] ERROR - ClientProfileExtra: video transcode target already exists for streaming hls
Jun 13, 2017 10:28:42.387 [0x7f63f1ffd700] ERROR - ClientProfileExtra: missing protocol parameter
Jun 13, 2017 10:28:42.387 [0x7f63f1ffd700] WARN - ClientProfileExtra: ignoring directive: add-transcode-target(type=videoProfile&context=static&container=mp4&videoCodec=h264&audioCodec=aac,ac3&subtitleCodec=mov_text)
Jun 13, 2017 10:28:42.387 [0x7f63f1ffd700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Jun 13, 2017 10:28:42.387 [0x7f63f1ffd700] ERROR - ClientProfileExtra: video transcode target already exists for streaming hls
Jun 13, 2017 10:28:46.144 [0x7f63f2fff700] ERROR - [Transcoder] [ac3 @ 0x350e800] exponent -1 is out-of-range
Jun 13, 2017 10:28:46.145 [0x7f63e3bff700] ERROR - [Transcoder] [ac3 @ 0x350e800] error decoding the audio block
Jun 13, 2017 10:28:46.147 [0x7f63f1ffd700] ERROR - [Transcoder] [ac3 @ 0x350e800] frame sync error
Jun 13, 2017 10:28:46.148 [0x7f63f2fff700] ERROR - [Transcoder] Error while decoding stream #0:1: Invalid data found when processing input
Jun 13, 2017 10:28:46.149 [0x7f63f1ffd700] ERROR - [Transcoder] [ac3 @ 0x350e800] exponent -1 is out-of-range
Jun 13, 2017 10:28:46.150 [0x7f63f2fff700] ERROR - [Transcoder] [ac3 @ 0x350e800] error decoding the audio block
Jun 13, 2017 10:28:46.160 [0x7f63e3bff700] ERROR - [Transcoder] [ac3 @ 0x350e800] frame sync error
Jun 13, 2017 10:28:46.161 [0x7f63f1ffd700] ERROR - [Transcoder] Error while decoding stream #0:1: Invalid data found when processing input
Jun 13, 2017 10:28:46.162 [0x7f63e3bff700] ERROR - [Transcoder] [ac3 @ 0x350e800] invalid coupling range (10 >= 5)
Jun 13, 2017 10:28:46.162 [0x7f63f2fff700] ERROR - [Transcoder] [ac3 @ 0x350e800] error decoding the audio block
Jun 13, 2017 10:28:46.171 [0x7f63f1ffd700] ERROR - [Transcoder] [ac3 @ 0x350e800] frame sync error
Jun 13, 2017 10:28:46.172 [0x7f63e3bff700] ERROR - [Transcoder] Error while decoding stream #0:1: Invalid data found when processing input
Jun 13, 2017 10:28:46.173 [0x7f63f2fff700] ERROR - [Transcoder] [ac3 @ 0x350e800] exponent -2 is out-of-range
Jun 13, 2017 10:28:46.173 [0x7f63e3bff700] ERROR - [Transcoder] [ac3 @ 0x350e800] error decoding the audio block
Jun 13, 2017 10:28:46.185 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 28 17
Jun 13, 2017 10:28:46.186 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] Invalid mb type in I-frame at 113 3
Jun 13, 2017 10:28:46.186 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] skipped MB in I-frame at 94 27
Jun 13, 2017 10:28:46.187 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 23 62
Jun 13, 2017 10:28:46.188 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 0 12
Jun 13, 2017 10:28:46.188 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 31 38
Jun 13, 2017 10:28:46.189 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 0 13
Jun 13, 2017 10:28:46.189 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 0 14
Jun 13, 2017 10:28:46.190 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 0 15
Jun 13, 2017 10:28:46.191 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] Invalid mb type in I-frame at 0 16
Jun 13, 2017 10:28:46.192 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] Invalid mb type in I-frame at 0 17
Jun 13, 2017 10:28:46.193 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 0 18
Jun 13, 2017 10:28:46.193 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 0 19
Jun 13, 2017 10:28:46.194 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 0 20
Jun 13, 2017 10:28:46.195 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 0 21
Jun 13, 2017 10:28:46.196 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 0 22
Jun 13, 2017 10:28:46.197 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 0 23
Jun 13, 2017 10:28:46.278 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 5 33
Jun 13, 2017 10:28:46.279 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] slice mismatch
Jun 13, 2017 10:28:46.280 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 0 35
Jun 13, 2017 10:28:46.281 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 13 36
Jun 13, 2017 10:28:46.281 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 23 37
Jun 13, 2017 10:28:46.282 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 87 64
Jun 13, 2017 10:28:46.283 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 8 65
Jun 13, 2017 10:28:46.284 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] Invalid mb type in P-frame at 25 66
Jun 13, 2017 10:28:46.285 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 31 67
Jun 13, 2017 10:28:46.286 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] Warning MVs not available
Jun 13, 2017 10:28:46.311 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] slice mismatch
Jun 13, 2017 10:28:46.312 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 4 45
Jun 13, 2017 10:28:46.312 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] Warning MVs not available
Jun 13, 2017 10:28:46.370 [0x7f63f2fff700] ERROR - [Transcoder] [ac3 @ 0x350e800] frame sync error
Jun 13, 2017 10:28:46.370 [0x7f63e3bff700] ERROR - [Transcoder] Error while decoding stream #0:1: Invalid data found when processing input
Jun 13, 2017 10:28:46.371 [0x7f63f1ffd700] ERROR - [Transcoder] [ac3 @ 0x350e800] delta bit allocation strategy reserved
Jun 13, 2017 10:28:46.372 [0x7f63f2fff700] ERROR - [Transcoder] [ac3 @ 0x350e800] error decoding the audio block
Jun 13, 2017 10:28:46.378 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] Invalid mb type in B-frame at 104 20
Jun 13, 2017 10:28:46.379 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] Warning MVs not available
Jun 13, 2017 10:28:46.396 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 61 57
Jun 13, 2017 10:28:46.397 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 7 14
Jun 13, 2017 10:28:46.397 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] mb incr damaged
Jun 13, 2017 10:28:46.398 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] Invalid mb type in B-frame at 27 15
Jun 13, 2017 10:28:46.399 [0x7f63e3bff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 21 16
Jun 13, 2017 10:28:46.399 [0x7f63f1ffd700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] ac-tex damaged at 16 17
Jun 13, 2017 10:28:46.400 [0x7f63f2fff700] ERROR - [Transcoder] [mpeg2video @ 0x34909a0] invalid cbp 0 at 0 18
:neutral:
this is what it looked like on my phone :
Updated Plex just in case there were some fixes for DVR stuff related to this.
But alas, sad to report Version 1.7.3.3937 still works same way.
I’m having the same problem on my windows 10 pc. The “setup dvr” option only finds my network (hd homerun) but not the Hauppauge usb stick.
i know this is old but im using WinTV-HVR-955Q with the drivers installed and my plex cant see it. did anyone find a solution??? it does work with nextpvr though
I’m getting http_streamer_t: http write errors a lot as well. Half of recording fail. Using the latest plex via plex pass and hauppauge wintv dualhd…
Getting similar " http write " here on Win Ten too. Anyone make any progress on this? It seems to be a permissions type issue
sorry guys, i am unable to help here as i’ve changed how i installed my 955Q. for what it’s worth, it does work for me now, but… it’s running on a raspberry 3 with tvheadend, and connected on plex via tvhproxy.
Also tried this with NVIDIA SHILED TV and WinTV dualHD and it seems the error cause is the same http write error (did not check logs, but the UI pop-up error is the same). 1.9.4…
I used “Transcoder temporary directory” in Settings - Transcoder to save trancoding outside of my SSD. After removing this setting Plex DVR seems to be able to play DVR again.
Of course, I cannot use plex to cache stuff on my SSD.
I deleted Transcode folder and then re-created empty Transcode folder with plex:plex rights. Then edited:
/etc/fstab
I added:
Mount plex transcode to backup hdd
/var/lib/plexmediaserver/Library/Application\040Support/Plex\040Media\040Server/Cache/Transcode /media/hdd/plex/temp none _netdev,bind 0 0
sudo mount -a
Now Live DVR is working and it saves trancodes to HDD instead of SDD.
Used this as reference: https://support.plex.tv/hc/en-us/articles/200250347-Transcoder
Update: Live DVR works but Scheduled Recording fails to http write error… (using HDD or SSD it still fails)
Update: Live DVR stopped working as well on certain channels. Also, playing .ts recordings from Library fails too.
