Transcoder Issue with Plex DVR
Hello. Im running my Plex server via OpenMediaVault through Docker CE. I was able to get all my movies, photos, and music working on Plex. I was also able to get my HDHomeRun Connect and HDHomeRun Dual connected to Plex for Live TV. The only thing that doesnt work is the DVR service. Every time i try to record a tv show it immediately says “There was a Transcoder Error.” I checked the logs and this is what i could see.
Mar 03, 2019 19:05:42.274 [0x7eff51bfe700] ERROR - [Transcoder] Unknown decoder ‘mpeg2video’
Mar 03, 2019 19:05:42.275 [0x7eff4efff700] DEBUG - Jobs: ‘/usr/lib/plexmediaserver/Plex Transcoder’ exit code for process 516 is 1 (failure)
Mar 03, 2019 19:05:42.275 [0x7eff56bff700] DEBUG - Streaming Resource: Terminated session 0x7eff3b1287e0:59f06cf5-0afc-4dcc-8376-f8d9ae32b53c with reason Recording failed. Please check your tuner or antenna.
Mar 03, 2019 19:05:42.275 [0x7eff477fe700] DEBUG - TranscodeSession: session failed while waiting for duration
Mar 03, 2019 19:05:42.275 [0x7eff477fe700] ERROR - Failed to start session.
Mar 03, 2019 19:05:42.275 [0x7eff3c7f1700] DEBUG - Killing job.
Mar 03, 2019 19:05:42.275 [0x7eff3c7f1700] DEBUG - Signalling job ID 516 with 9
Mar 03, 2019 19:05:42.275 [0x7eff3c7f1700] DEBUG - Job was already killed, not killing again.
Mar 03, 2019 19:05:42.275 [0x7eff3c7f1700] DEBUG - Stopping transcode session 59f06cf5-0afc-4dcc-8376-f8d9ae32b53c
Mar 03, 2019 19:05:42.276 [0x7eff477fe700] ERROR - DVR:Recorder: Unable to create transcode session or session failed to start.
Mar 03, 2019 19:05:42.276 [0x7eff477fe700] DEBUG - Job was already killed, not killing again.
Mar 03, 2019 19:05:42.276 [0x7eff477fe700] ERROR - DVR:Recorder: Error 12 (There was a transcoder error) starting the record, shutting things down.
Mar 03, 2019 19:05:42.276 [0x7eff477fe700] DEBUG - MediaRecorderVirtual: setting stop time to 2019-03-03 19:05:42
My tuners do work, as i just canceled my SiliconDust DVR service after a year to switch to Plex. I just recorded a show last week with the same tuners.
Also i am on Plex version 1.14
Please disregard this. the solution of me was removing the noexec permission on the folder where the trans-coding was trying to happen. so far looks as if the show is recording.
