DVR fails due to transcoder error
On a couple of occasions I’ve had DVR fail because of a transcoder error. The status page/schedule page gives no more information than that. I was watching another movie at the same time as the recording. Would that have made a difference? If someone would like to provide assistance I can provide full logs. In the meantime here’s a snipit at the time of failure.
#13335 Jul 26, 2017 23:00:31.119 [0x7f467f77d700] DEBUG - Using default transcode duration of 120 minutes
#13336 Jul 26, 2017 23:00:31.119 [0x7f467f77d700] DEBUG - Started session successfully: 021f1ce4-dd71-4924-8109-f1c18547ffb9
#13337 Jul 26, 2017 23:00:31.119 [0x7f467f77d700] DEBUG - DVR:Recorder: It took 30.0 sec to start the session for http://192.168.1.112:5004/auto/v62
#13338 Jul 26, 2017 23:00:31.120 [0x7f467f77d700] ERROR - DVR:Recorder: No part because session isn’t reporting one.
#13339 Jul 26, 2017 23:00:31.120 [0x7f467f77d700] ERROR - DVR:Recorder: Couldn’t obtain a part, something went wrong.
#13340 Jul 26, 2017 23:00:31.120 [0x7f467f77d700] ERROR - DVR:Recorder: Error 12 (There was a transcoder error) starting the record, shutting things down.
#13341 Jul 26, 2017 23:00:31.121 [0x7f467f77d700] DEBUG - DVR:Recorder: Asked to stop recording ‘The Good Mistress (2014)’.
#13342 Jul 26, 2017 23:00:31.121 [0x7f467f77d700] DEBUG - DVR:Recorder: Stopping transcode session.
#13343 Jul 26, 2017 23:00:31.121 [0x7f467f77d700] DEBUG - Killing job.
#13344 Jul 26, 2017 23:00:31.121 [0x7f467f77d700] DEBUG - Signalling job ID 2635 with 9
#13345 Jul 26, 2017 23:00:31.121 [0x7f467f77d700] DEBUG - Job was already killed, not killing again.
#13346 Jul 26, 2017 23:00:31.121 [0x7f467f77d700] DEBUG - Stopping transcode session 021f1ce4-dd71-4924-8109-f1c18547ffb9
#13347 Jul 26, 2017 23:00:31.122 [0x7f4685fff700] DEBUG - JobManager: child process killed by signal: 9 (Killed)
#13348 Jul 26, 2017 23:00:31.123 [0x7f467f77d700] DEBUG - DVR:Grabber: Freed a tuner (now 2 available)
#13349 Jul 26, 2017 23:00:31.123 [0x7f467f77d700] DEBUG - DVR:Grabber: Operation for The Good Mistress (2014) completed with status error (There was a transcoder error)
#13350 Jul 26, 2017 23:00:31.139 [0x7f467f77d700] DEBUG - Activity: Ended activity 3545463b-68d8-4c06-9c8c-a81f598ce228.
#13351 Jul 26, 2017 23:00:31.140 [0x7f467f77d700] ERROR - DVR:Grabber: Starting media grab failed.
#13352 Jul 26, 2017 23:00:31.160 [0x7f4687911700] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
#13353 Jul 26, 2017 23:00:31.160 [0x7f4687911700] DEBUG - Auth: Came in with the master token, authorization succeeded.
#13354 Jul 26, 2017 23:00:31.160 [0x7f4675c47700] DEBUG - Request: [127.0.0.1:57292 (Loopback)] PUT /video/:/transcode/session/bdcbbejvy26io/2d877efa-b397-4b68-b68f-9589299077ac/progress?
Wow! Sorry about the huge font in the log extract.
Having this same problem. I am using the latest PMS on Windows 10 x64 and an Avermedia Volar(?) USB tuner for OTA.
same here wintv-dual usb about 45 minutes into AGT. I would say that it seems to occur for two reasons for me. The first is poor quality channels (15-19 SNR). the other seems to happen if I am watching a DVR show via transcode while recording two shows. I haven’t had a lot of instances of either and not enough to correlate anything though.
This problem has been around for a long time.
Absolutely no apparent interest taken by Plex for this issue in all this time.
Has ANYONE heard of the possibility Plex is looking into this??
Transcode error message in the scheduler. Transcode error trying to view any recording in .TS format since the change back to TS.
Yup that is what is happening.
However, This error has been around a lot longer than the recent change back to TS recordings.
Since this customer support system does not have an easy way to correlate issues, has anyone seen a response from Plex to this DVR issue in all similar posts reporting this issue??
Any ideas would be appreciated…
Need to amend my complaint. Pilot error.
Got a call from a remote user telling me he was getting the “transcoder error” on his Roku trying to watch a movie. I fired up Chrome and found I was getting it too. Tried various older versions, all with the same result. Tried the Shield TV in living room and it played fine (direct play). Hmm… On a whim, I went into server Transcoder settings and found I had magically acquired a path in the “Transcoder temporary directory” pointing to a folder that does not exist. I have used this setting in the past but not for at least a year (Plex nerfed it on smaller drives by doing an arbitrary disk space check that exceeded the free space so it would fail). How that got back in there is a mystery. I had tried a custom docker w/comskip in it recently. Perhaps that had it set in it? Dunno but once I cleared that field (as is the default) it fixed remote client transcoding, DVR recording & viewing, and trying to view in any client that requires transcoding.
PS. I still get a transcoding warning in Shield TV for DVR recordings regarding MPEG in a TS container being incompatible with Android TV.
