Transcoder issue with "Use hardware acceleration when available" / TS-653D
Hello,
I have new Qnap NAS (TS-653D/ J4125) and facing transcoder issue with “Use hardware acceleration when available”. When I use Plex server to transcode H.264, the Plex version is not good for view for any resolution (1080/720/480/…) but the QNAP convert function is perfect and no issue. I was wondering why older QNAP NAS (TS-453A /N3160) which is not issue to use hardware transcoder for Plex.
Server Version#: 1.20.1.3213
Player Version#: 8.2.1.18636 or about.
Media
  • Duration 49:56
  • Bitrate 4611 kbps
  • Width 1280
  • Height 720
  • Aspect Ratio 1.78
  • Video Resolution 720p
  • Container MP4
  • Video Frame Rate NTSC
  • Web Optimized No
  • Audio Profile lc
  • Video Profile main
  • Title Original
Part
  • Duration 49:56
  • File PA3U - Movie 1.mp4
  • Size 1.61 GB
  • Audio Profile lc
  • Container MP4
  • Web Optimized No
  • Codec H264
  • Bitrate 4403 kbps
  • Bit Depth 8
  • Chroma Location left
  • Chroma Subsampling 4:2:0
  • Coded Height 720
  • Coded Width 1280
  • Frame Rate 29.97 fps
  • Height 720
  • Level 3.1
  • Profile main
  • Ref Frames 2
  • Stream Identifier 1
  • Width 1280
  • Display Title 720p (H.264)
  • Extended Display Title 720p (H.264)
  • Codec AAC
  • Channels 2
  • Bitrate 201 kbps
  • Audio Channel Layout stereo
  • Profile lc
  • Sampling Rate 48000 Hz
  • Stream Identifier 2
  • Display Title Unknown (AAC Stereo)
  • Extended Display Title Unknown (AAC Stereo)
  • Codec VOBSUB
  • Bitrate 6 kbps
  • Language English
  • Stream Identifier 3
  • Display Title English (VOBSUB)
  • Extended Display Title English (VOBSUB)
Media
  • Duration 49:56
  • Bitrate 2362 kbps
  • Width 1280
  • Height 720
  • Aspect Ratio 1.78
  • Container MP4
  • Web Optimized Yes
  • Proxy Type 42
  • Audio Profile lc
  • Target Optimized for Mobile
  • Target Tag I D 1
  • Video Profile high
  • Title Optimized for Mobile
Part
  • Duration 49:56
  • File PA3U - Movie 1 (2020).mp4
  • Size 843.70 MB
  • Audio Profile lc
  • Container MP4
  • Web Optimized Yes
  • Codec H264
  • Bitrate 2160 kbps
  • Bit Depth 8
  • Coded Height 720
  • Coded Width 1280
  • Frame Rate 22.262 fps
  • Height 720
  • Level 3.1
  • Profile high
  • Ref Frames 2
  • Width 1280
  • Codec AAC
  • Channels 2
  • Bitrate 201 kbps
  • Profile lc
There is a known bug in the Intel iHD_drv_video.so interface driver (from Intel) on all J4xxx CPUs.
Temporary workaround is to add the option VaapiDriver="i965" to Preferences.xml before the closing /> marker.
If you have the “PlexData” share in use, you can use the QNAP text editor in FileStation to add this option. It looks like VaapiDriver="i965" />
This is added when PMS is stopped. After restart, the image quality will return.
Great to hear the workaround!!! Solution is work for me. Thanks ChuckPa.
