QNAP TS-464 - HDR Tone Mapping ON - HW transcoding not working
Server Version#: Version 1.31.3.6819
Plex Media Server Logs_2023-03-23_13-13-11.zip (2.8 MB)
Player Version#: PlexWeb Player via Windows 11 Version 1.31.3.6819
Hello, I have a QNAP TS-464 NAS with QTS 5.0.1.2277 I`m using Plex Version 1.31.3.6819, also tried the latest stable version before too.
My problem ist that HW transcoding is working but not with “Tone Mapping ON”, please advise on how to resolve this problem. Logs with the problem reproduced are attached.
Joe
Thank you.
I’ve been trying, for quite some time, to see a clear and definitive failure of the transcoder to detect the QSV ASIC after PMS has. This is a bug with the 51xx CPUs.
Your logs show.
  1. PMS
Mar 23, 2023 13:11:36.035 [0x7ffa0ae60b38] DEBUG - [GPU] Got device: JasperLake [UHD Graphics], intel@builtin, default true, best true, ID /dev/dri/renderD128, DevID [8086:4e61:8086:2212], flags 0x6f
Mar 23, 2023 13:11:36.035 [0x7ffa0ae60b38] INFO - Preemptively preparing driver icr for GPU JasperLake [UHD Graphics]
  1. Transcoder
Mar 23, 2023 13:11:57.983 [0x7ffa066eab38] DEBUG - [Req#1a0/Transcode] TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Mar 23, 2023 13:11:57.983 [0x7ffa066eab38] INFO - [Req#1a0/Transcode] CodecManager: starting EAE at “/share/CACHEDEV2_DATA/.qpkg/PlexMediaServer/Library/tmp/pms-b28d7334-684a-4e35-ad4c-560a761095b5/EasyAudioEncoder”
Mar 23, 2023 13:11:57.983 [0x7ffa066eab38] DEBUG - [Req#1a0/Transcode/JobRunner] Job running: “/share/CACHEDEV2_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Codecs/EasyAudioEncoder-1847-linux-x86_64/EasyAudioEncoder/EasyAudioEncoder”
Mar 23, 2023 13:11:57.983 [0x7ffa066eab38] DEBUG - [Req#1a0/Transcode/JobRunner] In directory: “/share/CACHEDEV2_DATA/.qpkg/PlexMediaServer/Library/tmp/pms-b28d7334-684a-4e35-ad4c-560a761095b5/EasyAudioEncoder”
Mar 23, 2023 13:11:57.983 [0x7ffa066eab38] DEBUG - [Req#1a0/Transcode/JobRunner] Jobs: Starting child process with pid 29042
Mar 23, 2023 13:11:57.983 [0x7ffa066eab38] DEBUG - [Req#1a0/Transcode] [Universal] Using local file path instead of URL: /share/CACHEDEV1_DATA/Plex/Mediathek/TV Shows/Severance/Season 01/Severance - S01E01 - Fünf Fragen.mkv
Mar 23, 2023 13:11:57.983 [0x7ffa066eab38] DEBUG - [Req#1a0/Transcode] TPU: hardware transcoding: final decoder: , final encoder:
I am submitting this now as a priority problem. I will follow up in our team meeting on Monday and see if I can get it fixed ASAP.
