Transcoder use only 1 cpu on chromecast
Hello,
I’ve plexmediaserver on raspberry pi3.
With version 1.0.0.2261 I’ve a this strange problem with transcoder.
the transcoder in optimize video and in streaming web it use all 4 cpu of raspberry pi3 , but on chromecast it use only 1 cpu.
What is the format of the video you are trying to stream?
Look here :
https://support.plex.tv/hc/en-us/articles/201998867-Investigate-Media-Information-and-Formats
to see how to find the information. Just need the info provided by using the “Open the Media Info Window” method.
It may very well be that the Pi needs to be fully transcoded (does not have the proper codecs) and the Chromecast just needs to be remuxed for audio.
With New Transcoder 0.9.14.6 it use all 4 cpu (thread), with 1.0.0.2261 it only one cpu (thread).
It’s strange because in optimize function it use all thread
This is a video:
Media
Video Resolution 1080p
Duration 1:41:13
Bitrate 8108 kbps
Width 1920
Height 804
Aspect Ratio 2.35
Container MKV
Video Frame Rate 24p
Video Profile high
Titolo Originale
Parte
Duration 1:41:13
File Wreck-It Ralph (2012) 1080p ENG-ITA x264 bluray - Ralph Spaccatutto -Shiv@.mkv
Size 5.73 GB
Container MKV
Video Profile high
Codec H264
Bitrate 6148 kbps
Bit Depth 8
CABAC true
Chroma Subsampling 4:2:0
Duration 1:41:13
Frame Rate 23.976 fps
Frame Rate Mode cfr
Height 804
Level 4.1
Pixel Format yuv420p
Profile high
Ref Frames 4
Scan Type progressive
Titolo Wreck-It Ralph - 1080p -Shiv@
Width 1920
Codec AC3
Canali 5.1
Bitrate 448 kbps
Lingua English
Audio Channel Layout 5.1(side)
Bit Depth 16
Bitrate Mode CBR
Dialog Norm -31 dB
Duration 1:41:13
Sampling Rate 48000 Hz
Titolo English Ac3 5.1 chnls 448 kbps
Codec DCA
Canali 5.1
Bitrate 1509 kbps
Lingua Italiano
Bit Depth 24
Bitrate Mode CBR
Duration 1:41:13
Profile dts
Titolo Italian DTS 5.1 chnls 1536 kbps
Codec SRT
Lingua English
Format SRT
Titolo english
Codec SRT
Lingua Italiano
Format SRT
Titolo italian
Codec SRT
Lingua English
Format SRT
Titolo English SDH
Codec SRT
Lingua Italiano
Format SRT
Titolo Italian Forced
Thank to @uglymagoo for the patch of chromecast.mxl
