I’d really appreciate hearing from someone who can explain HDMI ARC and HDMI eARC, particularly in the context of transcoding. My goal is to have a 2.1 home theater system that can play lossless audio files from movies (that is, Dolby TrueHD and DTS-HD MA). I was considering the Yamaha R-N2000A integrated amplifier, which has an ARC port rather than an eARC port. Then, I thought I should consider buying an all-analog integrated amplifier with balanced inputs. Along those lines, I purchased a music streamer that has both balanced outputs and an eARC port. From what I have found on the website of one merchant, the streamer supports 2-channel PCM and Dolby Digital audio (up to 24-bit/192kHz), but it is not compatible with DTS and other multichannel audio formats. On another website, I read that the streamer can down mix audio files. I connected the streamer via an HDMI cable to my 2017 model Sony TV, which has an ARC port.
Most of the time, I use an NVIDIA Shield TV Pro to watch movies stored on a NAS. When I stream a movie having TrueHD 7.1 audio, neither the audio nor the video file is processed as Direct Play. Instead, the audio signal is transcoded into something called TrueHD Opus. In contrast, when I stream a movie having DTS-HD MA 7.1 audio, both audio and video files are processed as Direct Play.
Questions:
Is the transcoding of the Dolby TrueHD files occurring because of my TV’s ARC port or because of the streamer’s limited eARC port?
Put differently, if my next TV has an eARC port that can decode both Dolby TrueHD and DTS-HD MA audio files, will the eARC port on the music streamer prevent it from playing a lossless soundtrack in 2-channel PCM?
Still differently, when a TV decodes a Dolby TrueHD 7.1 audio file, will the TV output 2-channel PCM via an HDMI cable connected to another device, such as the music streamer? Thank you very much.
