Transcoding Error Message unclear
Server Version#: Linux 1.30.1.6562
Player Version#: Roku 7.0.23.8111-8c8a6a9b7
[Req#f78a4/Transcode] Streaming Resource: Reached Decision id=258658 codes=(General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=2003,File is unplayable. Color space is not supported.) media=(id=505776 part=(id=513284 decision=none container=mkv protocol=http streams=(Video=(id=1161922 decision=transcode bitrate=2147483647 encoder=libx264 width=1920 height=1080) Audio=(id=1161923 decision=transcode bitrate=640 encoder=ac3 channels=6 rate=48000))))
Error is for this file:
mediainfo report
Format : Matroska
Format version : Version 4
File size : 5.38 GiB
Duration : 2 h 16 min
Overall bit rate : 5 630 kb/s
Encoded date : UTC 2022-12-30 08:03:14
Writing application : mkvmerge v60.0.0 (‘Are We Copies?’) 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L4@Main
HDR format : Dolby Vision, Version 1.0, dvhe.05.03, BL+RPU
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 4 854 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.098
Stream size : 4.64 GiB (86%)
Default : Yes
Forced : No
Color range : Full
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 752 MiB (14%)
Title : English
Language : English
Service kind : Complete Main
Default : No
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Seems that it has a problem playing DV , Dolby Vision files – why ? Can this be fixed ?
Dolby Vision Profile 5 has no fallback HDR layer. It was created for streaming only.
Without the fallback layer, there is nothing to map color to.
The result is completely mismatched color
