Server Version#: 1.15.4.994 running in docker and using the plexinc/pms-docker image.
Having an issue with transcoding any file for playback requiring lower network bandwidth. From the log:
May 14, 2019 08:00:39.159 [0x7f7310ff9700] DEBUG - Job running: EAE_ROOT=’/tmp/pms-1ba9404f-5498-4ffe-86de-55040a9de5f7/EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=’/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/392df4f-2183-linux-x86_64/’ XDG_CACHE_HOME=’/config/Library/Application Support/Plex Media Server/Cache’ XDG_DATA_HOME=’/usr/lib/plexmediaserver/Resources’ X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ ‘/usr/lib/plexmediaserver/Plex Transcoder’ ‘-codec:2’ ‘h264’ ‘-codec:1’ ‘dca’ ‘-analyzeduration’ ‘20000000’ ‘-probesize’ ‘20000000’ ‘-i’ ‘/media/Movies/Mary.Poppins.Returns.2018.1080p.Blu-ray.DTS-HD.MA.7.1.x264-PbK.mkv’ ‘-filter_complex’ ‘[0:2]scale=w=1920:h=804[0];[0]format=pix_fmts=yuv420p|nv12[1]’ ‘-filter_complex’ ‘[0:1] aresample=async=1:ocl=’’‘5.1’’’:osr=48000[2]’ ‘-map’ ‘[1]’ ‘-metadata:s:0’ ‘language=eng’ ‘-codec:0’ ‘libx264’ ‘-crf:0’ ‘16’ ‘-maxrate:0’ ‘8000k’ ‘-bufsize:0’ ‘16000k’ ‘-r:0’ ‘23.975999999999999’ ‘-preset:0’ ‘veryfast’ ‘-level:0’ ‘4.0’ ‘-x264opts:0’ ‘subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none’ ‘-map’ ‘[2]’ ‘-metadata:s:1’ ‘language=eng’ ‘-codec:1’ ‘aac’ ‘-strict:1’ ‘experimental’ ‘-aac_coder:1’ ‘fast’ ‘-q:1’ ‘0’ ‘-f’ ‘mp4’ ‘-map_metadata’ ‘-1’ ‘-map_chapters’ ‘-1’ ‘-movflags’ ‘+faststart’ ‘/media/Movies/Plex Versions/Optimized for TV/.inProgress/Mary Poppins Returns.mp4.165’ ‘-y’ ‘-nostats’ ‘-loglevel’ ‘quiet’ ‘-loglevel_plex’ ‘error’ ‘-progressurl’ ‘http://127.0.0.1:32400/video/:/transcode/session/206c4532-a453-4282-aa09-9c0e1a156f58/7a6713b8-8fa2-4226-99e3-f503dfac597a/progress’
this command is failing due to
root@plex:/media/Movies/Plex Versions/Optimized for TV/.inProgress# ‘/usr/lib/plexmediaserver/Plex Transcoder’ ‘-codec:2’ ‘h264’ ‘-codec:1’ ‘dca’ ‘-analyzeduration’ ‘20000000’ ‘-probesize’ ‘20000000’ ‘-i’ ‘/media/Movies/Mary.Poppins.Returns.2018.1080p.Blu-ray.DTS-HD.MA.7.1.x264-PbK.mkv’ ‘-filter_complex’ ‘[0:2]scale=w=1920:h=804[0];[0]format=pix_fmts=yuv420p|nv12[1]’ ‘-filter_complex’ ‘[0:1] aresample=async=1:ocl=’’‘5.1’’’:osr=48000[2]’ ‘-map’ ‘[1]’ ‘-metadata:s:0’ ‘language=eng’ ‘-codec:0’ ‘libx264’ ‘-crf:0’ ‘16’ ‘-maxrate:0’ ‘8000k’ ‘-bufsize:0’ ‘16000k’ ‘-r:0’ ‘23.975999999999999’ ‘-preset:0’ ‘veryfast’ ‘-level:0’ ‘4.0’ ‘-x264opts:0’ ‘subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none’ ‘-map’ ‘[2]’ ‘-metadata:s:1’ ‘language=eng’ ‘-codec:1’ ‘aac’ ‘-strict:1’ ‘experimental’ ‘-aac_coder:1’ ‘fast’ ‘-q:1’ ‘0’ ‘-f’ ‘mp4’ ‘-map_metadata’ ‘-1’ ‘-map_chapters’ ‘-1’ ‘-movflags’ ‘+faststart’ ‘/media/Movies/Plex Versions/Optimized for TV/.inProgress/Mary Poppins Returns.mp4.165’
ffmpeg version 1.4-392df4f53-4 Copyright © 2000-2018 the FFmpeg developers
built with clang version 5.0.1 (tags/RELEASE_501/final)
configuration: --disable-static --enable-shared --disable-libx264 --disable-hwaccels --disable-protocol=concat --external-decoder=h264 --enable-debug --enable-muxers --disable-gmp --disable-avdevice --disable-bzlib --disable-sdl2 --disable-decoders --disable-devices --disable-encoders --disable-ffprobe --disable-ffplay --disable-doc --disable-iconv --disable-lzma --disable-schannel --disable-linux-perf --disable-mediacodec --enable-eae --arch=x86_64 --target-os=linux --strip=x86_64-plex-linux-gnu-strip --cc=/data/jenkins/conan_build/290920295/conan/.conan/data/clang/5.0.1-5/plex/stable/package/c4d120c52637f6809b107f8aaab43ce9d8e0e1ec/bin/clang --pkg-config=/data/jenkins/conan_build/290920295/conan/.conan/data/plexconantool/5-62/plex/stable/package/99cb7beab0cdb1bc79a044e3bd42148f6f45fb31/plex-pkg-config --pkg-config-flags=–static --cross-prefix=x86_64-plex-linux-gnu- --enable-cross-compile --extra-ldflags=’-static-libgcc -z noexecstack -Wl,-rpath=’’‘XORIGIN:XORIGIN/…/lib’’’ --sysroot=/data/jenkins/conan_build/290920295/conan/.conan/data/toolchain-linux-x86_64/1.0-10/plex/stable/package/c4d120c52637f6809b107f8aaab43ce9d8e0e1ec/x86_64-plex-linux-gnu/sysroot --target=x86_64-plex-linux-gnu --gcc-toolchain=/data/jenkins/conan_build/290920295/conan/.conan/data/toolchain-linux-x86_64/1.0-10/plex/stable/package/c4d120c52637f6809b107f8aaab43ce9d8e0e1ec -Wl,-rpath,’’‘XORIGIN/…/lib’’’ -Wl,-rpath,’’‘XORIGIN/lib’’’ -Wl,-rpath,/data/jenkins/conan_build/290920295/conan/.conan/data/libpciaccess/0.14-13/plex/stable/package/977e43f7772b089f07181eca1f6519c20d2f66f3/lib -Wl,-rpath,/data/jenkins/conan_build/290920295/conan/.conan/data/libdrm/2.4.96-36/plex/stable/package/0c46b1a4077bda38ad8020d657bae0006dd85001/lib -Wl,-rpath,/data/jenkins/conan_build/290920295/conan/.conan/data/libva/2.1.0-37/plex/stable/package/81a2df5e16044d97d1b088b0e6c9598b5b17f233/lib -Wl,-rpath,/data/jenkins/conan_build/290920295/conan/.conan/data/libpciaccess/0.14-13/plex/stable/package/977e43f7772b089f07181eca1f6519c20d2f66f3/lib -Wl,-rpath,/data/jenkins/conan_build/290920295/conan/.conan/data/libdrm/2.4.96-36/plex/stable/package/0c46b1a4077bda38ad8020d657bae0006dd85001/lib -Wl,-rpath,/data/jenkins/conan_build/290920295/conan/.conan/data/libva/2.1.0-37/plex/stable/package/81a2df5e16044d97d1b088b0e6c9598b5b17f233/lib -m64 -L/data/jenkins/conan_build/290920295/conan/.conan/data/opus/1.2.1-11/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/libvorbis/1.3.5-14/plex/stable/package/aec4eb6f5cb9d20333df2504d3219be2d90eaaa5/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/libogg/1.3.2-12/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/x264/155-7d0ff22-11/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/zvbi/0.2.35-17/plex/stable/package/d6bc988a77694788705acbe9ec172c7be03ce7aa/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/rtmpdump/2.4-41/plex/stable/package/bc2a67e11e85f907c24b42bb3a236cccf72d0194/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/gnutls/3.5.19-6/plex/stable/package/3566f2f8e7d5ccb51a299a4b668ccb9d6c8a3092/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/nettle/3.3-16/plex/stable/package/38eb9d56990fc541fe0d29a0e1c176a71db8f4b8/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/libidn/2.0.5-17/plex/stable/package/d6bc988a77694788705acbe9ec172c7be03ce7aa/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/iconv/1.15-16/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/gmp/6.1.1-14/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/libass/0.14.0-19/plex/stable/package/70d2424cf96128c665ee68b578c62eb41565c8da/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/fribidi/0.19.7-14/plex/stable/package/a2069270db732b89d402b71d74949d09f29d3535/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/harfbuzz/1.2.7-30/plex/stable/package/5d4b25218c25e16049d16a1ad9fb53a82c55548d/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/fontconfig/2.13.0-8/plex/stable/package/dc02fea18a36a2cfc0e1c12e07ac9c77e3306a93/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/freetype2/2.9.1-5/plex/stable/package/adeaec4245627b6d7091407aafa72c27bc8322aa/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/expat/2.2.5-12/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/libuuid/1.0.3-5/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/libxml2/2.9.8-11/plex/stable/package/50a15f012cd94a5a5d864a63ede9b375efe62fc1/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/libpng/1.6.32-17/plex/stable/package/50a15f012cd94a5a5d864a63ede9b375efe62fc1/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/bzip2/1.0.6-13/plex/stable/package/0bb6f9a537a76b4aa6af7fb4dbef0aa6dddcabf4/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/zlib/1.2.8-16/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/mp3lame/3.98.4-11/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/intel-vaapi-driver/2.1.0-18/plex/stable/package/66977dae92313cf12c63fbdfe4eae6be30dbded2/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/libva/2.1.0-37/plex/stable/package/81a2df5e16044d97d1b088b0e6c9598b5b17f233/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/libdrm/2.4.96-36/plex/stable/package/0c46b1a4077bda38ad8020d657bae0006dd85001/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/libpciaccess/0.14-13/plex/stable/package/977e43f7772b089f07181eca1f6519c20d2f66f3/lib -L/data/jenkins/conan_build/290920295/conan/.conan/data/libpthread-stubs/0.4-12/plex/stable/package/5ab84d6acfe1f23c4fae0ab88f26e3a396351ac9/lib -static-libgcc -z noexecstack -Wl,-rpath=’’‘XORIGIN:XORIGIN/…/lib’’’ --sysroot=/data/jenkins/conan_build/290920295/conan/.conan/data/toolchain-linux-x86_64/1.0-10/plex/stable/package/c4d120c52637f6809b107f8aaab43ce9d8e0e1ec/x86_64-plex-linux-gnu/sysroot --target=x86_64-plex-linux-gnu --gcc-toolchain=/data/jenkins/conan_build/290920295/conan/.conan/data/toolchain-linux-x86_64/1.0-10/plex/stable/package/c4d120c52637f6809b107f8aaab43ce9d8e0e1ec’ --extra-libs=’-lopus -lvorbis -logg -lx264 -lzvbi -lpthread -lrtmp -lgnutls -lnettle -lhogweed -lidn2 -liconv -lcharset -lgmp -lass -lfribidi -lharfbuzz -lfontconfig -lfreetype -lexpat -luuid -lxml2 -ldl -lpng16 -lm -lbz2 -lz -lmp3lame -lva -lva-drm -ldrm -lpciaccess’ --extra-cflags=’-m64 -O3 -fPIC -DPIC -Os --sysroot=/data/jenkins/conan_build/290920295/conan/.conan/data/toolchain-linux-x86_64/1.0-10/plex/stable/package/c4d120c52637f6809b107f8aaab43ce9d8e0e1ec/x86_64-plex-linux-gnu/sysroot --target=x86_64-plex-linux-gnu --gcc-toolchain=/data/jenkins/conan_build/290920295/conan/.conan/data/toolchain-linux-x86_64/1.0-10/plex/stable/package/c4d120c52637f6809b107f8aaab43ce9d8e0e1ec -I/data/jenkins/conan_build/290920295/conan/.conan/data/opus/1.2.1-11/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/libvorbis/1.3.5-14/plex/stable/package/aec4eb6f5cb9d20333df2504d3219be2d90eaaa5/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/libogg/1.3.2-12/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/x264/155-7d0ff22-11/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/zvbi/0.2.35-17/plex/stable/package/d6bc988a77694788705acbe9ec172c7be03ce7aa/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/rtmpdump/2.4-41/plex/stable/package/bc2a67e11e85f907c24b42bb3a236cccf72d0194/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/gnutls/3.5.19-6/plex/stable/package/3566f2f8e7d5ccb51a299a4b668ccb9d6c8a3092/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/nettle/3.3-16/plex/stable/package/38eb9d56990fc541fe0d29a0e1c176a71db8f4b8/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/libidn/2.0.5-17/plex/stable/package/d6bc988a77694788705acbe9ec172c7be03ce7aa/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/iconv/1.15-16/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/gmp/6.1.1-14/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/libass/0.14.0-19/plex/stable/package/70d2424cf96128c665ee68b578c62eb41565c8da/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/fribidi/0.19.7-14/plex/stable/package/a2069270db732b89d402b71d74949d09f29d3535/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/harfbuzz/1.2.7-30/plex/stable/package/5d4b25218c25e16049d16a1ad9fb53a82c55548d/include/harfbuzz -I/data/jenkins/conan_build/290920295/conan/.conan/data/fontconfig/2.13.0-8/plex/stable/package/dc02fea18a36a2cfc0e1c12e07ac9c77e3306a93/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/freetype2/2.9.1-5/plex/stable/package/adeaec4245627b6d7091407aafa72c27bc8322aa/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/expat/2.2.5-12/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/libuuid/1.0.3-5/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/libxml2/2.9.8-11/plex/stable/package/50a15f012cd94a5a5d864a63ede9b375efe62fc1/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/libpng/1.6.32-17/plex/stable/package/50a15f012cd94a5a5d864a63ede9b375efe62fc1/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/bzip2/1.0.6-13/plex/stable/package/0bb6f9a537a76b4aa6af7fb4dbef0aa6dddcabf4/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/zlib/1.2.8-16/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/mp3lame/3.98.4-11/plex/stable/package/8094f5147bc9378351237bfd795472578065861f/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/intel-vaapi-driver/2.1.0-18/plex/stable/package/66977dae92313cf12c63fbdfe4eae6be30dbded2/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/libva/2.1.0-37/plex/stable/package/81a2df5e16044d97d1b088b0e6c9598b5b17f233/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/libdrm/2.4.96-36/plex/stable/package/0c46b1a4077bda38ad8020d657bae0006dd85001/include -I/data/jenkins/conan_build/290920295/conan/.conan/data/libpciaccess/0.14-13/plex/stable/package/977e43f7772b089f07181eca1f6519c20d2f66f3/include -DNDEBUG -fno-integrated-as’ --enable-decoder=png --enable-decoder=apng --enable-decoder=bmp --enable-decoder=mjpeg --enable-decoder=thp --enable-decoder=gif --enable-decoder=dirac --enable-decoder=ffv1 --enable-decoder=ffvhuff --enable-decoder=huffyuv --enable-decoder=rawvideo --enable-decoder=zero12v --enable-decoder=ayuv --enable-decoder=r210 --enable-decoder=v210 --enable-decoder=v210x --enable-decoder=v308 --enable-decoder=v408 --enable-decoder=v410 --enable-decoder=y41p --enable-decoder=yuv4 --enable-decoder=ansi --enable-decoder=alac --enable-decoder=flac --enable-decoder=vorbis --enable-decoder=opus --enable-decoder=pcm_f32be --enable-decoder=pcm_f32le --enable-decoder=pcm_f64be --enable-decoder=pcm_f64le --enable-decoder=pcm_lxf --enable-decoder=pcm_s16be --enable-decoder=pcm_s16be_planar --enable-decoder=pcm_s16le --enable-decoder=pcm_s16le_planar --enable-decoder=pcm_s24be --enable-decoder=pcm_s24le --enable-decoder=pcm_s24le_planar --enable-decoder=pcm_s32be --enable-decoder=pcm_s32le --enable-decoder=pcm_s32le_planar --enable-decoder=pcm_s8 --enable-decoder=pcm_s8_planar --enable-decoder=pcm_u16be --enable-decoder=pcm_u16le --enable-decoder=pcm_u24be --enable-decoder=pcm_u24le --enable-decoder=pcm_u32be --enable-decoder=pcm_u32le --enable-decoder=pcm_u8 --enable-decoder=pcm_alaw --enable-decoder=pcm_mulaw --enable-decoder=ass --enable-decoder=dvbsub --enable-decoder=dvdsub --enable-decoder=ccaption --enable-decoder=pgssub --enable-decoder=jacosub --enable-decoder=microdvd --enable-decoder=movtext --enable-decoder=mpl2 --enable-decoder=pjs --enable-decoder=realtext --enable-decoder=sami --enable-decoder=ssa --enable-decoder=stl --enable-decoder=subrip --enable-decoder=subviewer --enable-decoder=text --enable-decoder=vplayer --enable-decoder=webvtt --enable-decoder=xsub --enable-decoder=h264_cuvid --enable-decoder=hevc_cuvid --enable-decoder=mjpeg_cuvid --enable-decoder=mpeg1_cuvid --enable-decoder=mpeg2_cuvid --enable-decoder=mpeg4_cuvid --enable-decoder=vc1_cuvid --enable-decoder=vp8_cuvid --enable-decoder=vp9_cuvid --enable-decoder=eac3_eae --enable-decoder=truehd_eae --enable-decoder=mlp_eae --enable-encoder=flac --enable-encoder=alac --enable-encoder=libvorbis --enable-encoder=libopus --enable-encoder=mjpeg --enable-encoder=wrapped_avframe --enable-encoder=ass --enable-encoder=dvbsub --enable-encoder=dvdsub --enable-encoder=movtext --enable-encoder=ssa --enable-encoder=subrip --enable-encoder=text --enable-encoder=webvtt --enable-encoder=xsub --enable-encoder=pcm_f32be --enable-encoder=pcm_f32le --enable-encoder=pcm_f64be --enable-encoder=pcm_f64le --enable-encoder=pcm_s8 --enable-encoder=pcm_s8_planar --enable-encoder=pcm_s16be --enable-encoder=pcm_s16be_planar --enable-encoder=pcm_s16le --enable-encoder=pcm_s16le_planar --enable-encoder=pcm_s24be --enable-encoder=pcm_s24le --enable-encoder=pcm_s24le_planar --enable-encoder=pcm_s32be --enable-encoder=pcm_s32le --enable-encoder=pcm_s32le_planar --enable-encoder=pcm_u8 --enable-encoder=pcm_u16be --enable-encoder=pcm_u16le --enable-encoder=pcm_u24be --enable-encoder=pcm_u24le --enable-encoder=pcm_u32be --enable-encoder=pcm_u32le --enable-encoder=h264_qsv --enable-encoder=mpeg2_qsv --enable-encoder=hevc_qsv --enable-encoder=h264_vaapi --enable-encoder=hevc_vaapi --enable-encoder=h264_nvenc --enable-encoder=eac3_eae --prefix=/data/jenkins/conan_build/290920295/conan/.conan/data/ffmpeg/1.4-392df4f53-4/plex/stable/build/1b0687fcd934d79d8283f84c22c8ab4d016c0fea/transcoder-install --enable-libzvbi --enable-gnutls --enable-libass --enable-librtmp --enable-libopus
libavutil 56. 7.101 / 56. 7.101
libavcodec 58. 12.102 / 58. 12.102
libavformat 58. 9.100 / 58. 9.100
libavfilter 7. 12.100 / 7. 12.100
libswscale 5. 0.101 / 5. 0.101
libswresample 3. 0.101 / 3. 0.101
Unrecognized option ‘crf:0’.
Error splitting the argument list: Option not found
In checking the compile options of ffmpeg, libx264 is disabled which is why it can’t transcode the file.
