Transcoding needs to be frequently restarted
Server Version#: 1.32.3.7162
Player Version#: Irrelevant
Hi folks,
I’ve been using Plex for 2 months now, and until two weeks ago, it was a dream. Unfortunately, since two weeks ago, I’m unable to play multiple successive episodes without rebooting the server running Plex.
I tried just restarting the Debian service, but it never really stops, a few transcoding processes won’t stop, even when I try to kill-9 them.
I tried running it from scratch by reinstalling everything and wiping all config, but I still have the same issue.
It seems to be a server issue since the behavior is the same regardless of the client device: once the server is rebooted, the first episode or movie watched works fine, but the next one loads undefinitely creating a process that hangs forever.
My hardware is an intel nuc, without GPU
Need to see the server DEBUG logs which capture this happening.
(Settings - Server - Troubleshooting - Download Logs)
Grab the logs right after you START playing something, You don’t need to go any further.
The logs will show us what’s happening.
Sorry for the late answer.
Here you go:
Jun 19, 2023 21:42:23.101 [139623368645432] DEBUG - [Req#617b/Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: add-limitation(scope=videoCodec&scopeName=hevc&type=upperBound&name=video.bitDepth&value=10&replace=true)+append-transcode-target-codec(type=videoProfile&context=streaming&protocol=dash&videoCodec=hevc)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=dash&type=match&name=video.colorTrc&list=bt709|bt470m|bt470bg|smpte170m|smpte240m|bt2020-10|smpte2084&isRequired=false)+append-transcode-target-codec(type=videoProfile&context=streaming&audioCodec=aac&protocol=dash)
Jun 19, 2023 21:42:23.101 [139623368645432] DEBUG - [Req#617b/Transcode] TranscodeUniversalRequest: using augmented profile Web
Jun 19, 2023 21:42:23.101 [139623368645432] DEBUG - [Req#617b/Transcode] Downloading document http://127.0.0.1:32400/library/metadata/61?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=71gnzbhyi0d6sqo9055pw5zw
Jun 19, 2023 21:42:23.109 [139623368645432] DEBUG - [Req#617b/Transcode/Req#617c] We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.109 [139623368645432] DEBUG - [Req#617b/Transcode/Req#617c] Selecting best audio stream for part ID 67 (language: )
Jun 19, 2023 21:42:23.109 [139623368645432] DEBUG - [Req#617b/Transcode/Req#617c] Audio Stream: 154, Subtitle Stream: -1
Jun 19, 2023 21:42:23.111 [139623368645432] DEBUG - [Req#617b/Transcode] MDE: Selected protocol dash; container: mp4
Jun 19, 2023 21:42:23.111 [139623368645432] DEBUG - [Req#617b/Transcode] MDE: analyzing media item 67
Jun 19, 2023 21:42:23.111 [139623368645432] DEBUG - [Req#617b/Transcode] MDE: E4 - Ron et Tammy 2: Direct Play is disabled
Jun 19, 2023 21:42:23.111 [139623368645432] DEBUG - [Req#617b/Transcode] MDE: E4 - Ron et Tammy 2: media must be transcoded in order to use the dash protocol
Jun 19, 2023 21:42:23.111 [139623368645432] DEBUG - [Req#617b/Transcode] MDE: E4 - Ron et Tammy 2: no direct play video profile exists for http/mkv/hevc
Jun 19, 2023 21:42:23.111 [139623368645432] DEBUG - [Req#617b/Transcode] MDE: E4 - Ron et Tammy 2: no direct play video profile exists for http/mkv/hevc/aac
Jun 19, 2023 21:42:23.111 [139623368645432] DEBUG - [Req#617b/Transcode] MDE: Parks and Recreation - S3 E4 - Ron et Tammy 2: selected media 0 / 67
Jun 19, 2023 21:42:23.111 [139623368645432] DEBUG - [Req#617b/Transcode] Streaming Resource: Added session 0x7efc99b03168:71gnzbhyi0d6sqo9055pw5zw
Jun 19, 2023 21:42:23.112 [139623368645432] DEBUG - [Req#617b/Transcode] Streaming Resource: Reached Decision id=61 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=67 part=(id=67 decision=transcode container=mp4 protocol=dash streams=(Video=(id=153 decision=copy width=1920 height=1080) Audio=(id=154 decision=copy channels=6 rate=48000))))
Jun 19, 2023 21:42:23.114 [139623492553528] DEBUG - Completed: [192.168.1.24:55137] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F61&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=gzy82ibexa4nqdwdlyz2vny5&subtitles=burn&Accept-Language=fr (27 live) #617b TLS GZIP 13ms 2718 bytes (pipelined: 15)
Jun 19, 2023 21:42:23.124 [139623382707000] DEBUG - Request: [192.168.1.24:55137 (Subnet)] OPTIONS /:/timeline?ratingKey=61&key=%2Flibrary%2Fmetadata%2F61&playbackTime=0&playQueueItemID=182&state=playing&hasMDE=1&context=home%3Ahub.continueWatching&row=0&col=0&time=91000&duration=1281000&utm_referer=https%3A%2F%2Fapp.plex.tv%2Fdesktop%2F (27 live) #617e TLS GZIP Signed-in Token ()
Jun 19, 2023 21:42:23.124 [139623490444088] DEBUG - Completed: [192.168.1.24:55137] 200 OPTIONS /:/timeline?ratingKey=61&key=%2Flibrary%2Fmetadata%2F61&playbackTime=0&playQueueItemID=182&state=playing&hasMDE=1&context=home%3Ahub.continueWatching&row=0&col=0&time=91000&duration=1281000&utm_referer=https%3A%2F%2Fapp.plex.tv%2Fdesktop%2F (27 live) #617e TLS GZIP 0ms 376 bytes (pipelined: 16)
Jun 19, 2023 21:42:23.127 [139623366535992] DEBUG - Request: [192.168.1.24:55137 (Subnet)] GET /:/timeline?ratingKey=61&key=%2Flibrary%2Fmetadata%2F61&playbackTime=0&playQueueItemID=182&state=playing&hasMDE=1&context=home%3Ahub.continueWatching&row=0&col=0&time=91000&duration=1281000&utm_referer=https%3A%2F%2Fapp.plex.tv%2Fdesktop%2F (27 live) #617f TLS GZIP Signed-in Token (sofianegargouri) (Chrome)
Jun 19, 2023 21:42:23.128 [139623366535992] DEBUG - [Req#617f] Client [71gnzbhyi0d6sqo9055pw5zw] reporting timeline state playing, progress of 91000/1281000ms for guid=, playbackTime=0ms ratingKey=61 url=, key=/library/metadata/61, containerKey=, metadataId=61, source=
Jun 19, 2023 21:42:23.136 [139623366535992] DEBUG - [Req#617f] We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.136 [139623366535992] DEBUG - [Req#617f] Selecting best audio stream for part ID 67 (language: )
Jun 19, 2023 21:42:23.136 [139623366535992] DEBUG - [Req#617f] Audio Stream: 154, Subtitle Stream: -1
Jun 19, 2023 21:42:23.138 [139623366535992] DEBUG - [Req#617f] [Now] User is sofianegargouri (ID: 1)
Jun 19, 2023 21:42:23.138 [139623366535992] DEBUG - [Req#617f] [Now] Device is Chrome (Chrome).
Jun 19, 2023 21:42:23.138 [139623366535992] DEBUG - [Req#617f] [Now] Profile is Web
Jun 19, 2023 21:42:23.138 [139623366535992] DEBUG - [Req#617f] [Now] Updated play state for /library/metadata/61.
Jun 19, 2023 21:42:23.138 [139623366535992] DEBUG - [Req#617f] Statistics: (mgm1zoqelfqve7518hswpqun) Reporting active playback in state 0 of type 4 (scrobble: 0) for account 1
Jun 19, 2023 21:42:23.143 [139623490444088] DEBUG - Completed: [192.168.1.24:55137] 200 GET /:/timeline?ratingKey=61&key=%2Flibrary%2Fmetadata%2F61&playbackTime=0&playQueueItemID=182&state=playing&hasMDE=1&context=home%3Ahub.continueWatching&row=0&col=0&time=91000&duration=1281000&utm_referer=https%3A%2F%2Fapp.plex.tv%2Fdesktop%2F (27 live) #617f TLS GZIP 16ms 580 bytes (pipelined: 17)
Jun 19, 2023 21:42:23.151 [139623370754872] DEBUG - Request: [192.168.1.24:55137 (Subnet)] GET /status/sessions (27 live) #6186 TLS GZIP Signed-in Token (sofianegargouri) (Chrome)
Jun 19, 2023 21:42:23.152 [139623370754872] DEBUG - [Req#6186] [Now] Adding 1 sessions.
Jun 19, 2023 21:42:23.153 [139623492553528] DEBUG - Completed: [192.168.1.24:55137] 200 GET /status/sessions (27 live) #6186 TLS GZIP 1ms 2750 bytes (pipelined: 18)
Jun 19, 2023 21:42:23.156 [139623380597560] DEBUG - Request: [192.168.1.24:55136 (Subnet)] GET /status/sessions (27 live) #616a TLS GZIP Signed-in Token (sofianegargouri) (Chrome)
Jun 19, 2023 21:42:23.156 [139623380597560] DEBUG - [Req#616a] [Now] Adding 1 sessions.
Jun 19, 2023 21:42:23.158 [139623490444088] DEBUG - Completed: [192.168.1.24:55136] 200 GET /status/sessions (27 live) #616a TLS GZIP 1ms 2750 bytes (pipelined: 17)
Jun 19, 2023 21:42:23.162 [139623355890488] DEBUG - Request: [192.168.1.24:55136 (Subnet)] OPTIONS /playQueues/4?repeat=0&own=1&includeChapters=1&includeMarkers=1&includeGeolocation=1&includeExternalMedia=1 (27 live) #6188 TLS GZIP Signed-in Token ()
Jun 19, 2023 21:42:23.163 [139623492553528] DEBUG - Completed: [192.168.1.24:55136] 200 OPTIONS /playQueues/4?repeat=0&own=1&includeChapters=1&includeMarkers=1&includeGeolocation=1&includeExternalMedia=1 (27 live) #6188 TLS GZIP 0ms 376 bytes (pipelined: 18)
Jun 19, 2023 21:42:23.165 [139623372864312] DEBUG - Request: [192.168.1.24:55136 (Subnet)] GET /playQueues/4?repeat=0&own=1&includeChapters=1&includeMarkers=1&includeGeolocation=1&includeExternalMedia=1 (27 live) #6189 TLS GZIP Signed-in Token (sofianegargouri) (Chrome)
Jun 19, 2023 21:42:23.165 [139623372864312] DEBUG - [Req#6189] PlayQueue: total generated: 89, before cursor: 0, after cursor: 88
Jun 19, 2023 21:42:23.166 [139623372864312] DEBUG - [Req#6189] PlayQueue: No need to refresh, active window is operational.
Jun 19, 2023 21:42:23.200 [139623372864312] DEBUG - [Req#6189] PlayQueue: Client mgm1zoqelfqve7518hswpqun requested ownership of play queue 4, but already had it.
Jun 19, 2023 21:42:23.202 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.202 [139623372864312] DEBUG - Selecting best audio stream for part ID 67 (language: )
Jun 19, 2023 21:42:23.202 [139623372864312] DEBUG - Audio Stream: 154, Subtitle Stream: -1
Jun 19, 2023 21:42:23.203 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.203 [139623372864312] DEBUG - Selecting best audio stream for part ID 68 (language: )
Jun 19, 2023 21:42:23.203 [139623372864312] DEBUG - Audio Stream: 157, Subtitle Stream: -1
Jun 19, 2023 21:42:23.204 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.204 [139623372864312] DEBUG - Selecting best audio stream for part ID 69 (language: )
Jun 19, 2023 21:42:23.204 [139623372864312] DEBUG - Audio Stream: 160, Subtitle Stream: -1
Jun 19, 2023 21:42:23.205 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.205 [139623372864312] DEBUG - Selecting best audio stream for part ID 70 (language: )
Jun 19, 2023 21:42:23.205 [139623372864312] DEBUG - Audio Stream: 163, Subtitle Stream: -1
Jun 19, 2023 21:42:23.207 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.207 [139623372864312] DEBUG - Selecting best audio stream for part ID 71 (language: )
Jun 19, 2023 21:42:23.207 [139623372864312] DEBUG - Audio Stream: 166, Subtitle Stream: -1
Jun 19, 2023 21:42:23.208 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.208 [139623372864312] DEBUG - Selecting best audio stream for part ID 72 (language: )
Jun 19, 2023 21:42:23.208 [139623372864312] DEBUG - Audio Stream: 169, Subtitle Stream: -1
Jun 19, 2023 21:42:23.210 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.210 [139623372864312] DEBUG - Selecting best audio stream for part ID 73 (language: )
Jun 19, 2023 21:42:23.210 [139623372864312] DEBUG - Audio Stream: 172, Subtitle Stream: -1
Jun 19, 2023 21:42:23.211 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.211 [139623372864312] DEBUG - Selecting best audio stream for part ID 74 (language: )
Jun 19, 2023 21:42:23.211 [139623372864312] DEBUG - Audio Stream: 175, Subtitle Stream: -1
Jun 19, 2023 21:42:23.212 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.212 [139623372864312] DEBUG - Selecting best audio stream for part ID 75 (language: )
Jun 19, 2023 21:42:23.212 [139623372864312] DEBUG - Audio Stream: 178, Subtitle Stream: -1
Jun 19, 2023 21:42:23.214 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.214 [139623372864312] DEBUG - Selecting best audio stream for part ID 76 (language: )
Jun 19, 2023 21:42:23.214 [139623372864312] DEBUG - Audio Stream: 181, Subtitle Stream: -1
Jun 19, 2023 21:42:23.215 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.215 [139623372864312] DEBUG - Selecting best audio stream for part ID 77 (language: )
Jun 19, 2023 21:42:23.215 [139623372864312] DEBUG - Audio Stream: 184, Subtitle Stream: -1
Jun 19, 2023 21:42:23.216 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.216 [139623372864312] DEBUG - Selecting best audio stream for part ID 78 (language: )
Jun 19, 2023 21:42:23.216 [139623372864312] DEBUG - Audio Stream: 187, Subtitle Stream: -1
Jun 19, 2023 21:42:23.217 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.217 [139623372864312] DEBUG - Selecting best audio stream for part ID 79 (language: )
Jun 19, 2023 21:42:23.217 [139623372864312] DEBUG - Audio Stream: 190, Subtitle Stream: -1
Jun 19, 2023 21:42:23.218 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.218 [139623372864312] DEBUG - Selecting best audio stream for part ID 80 (language: )
Jun 19, 2023 21:42:23.218 [139623372864312] DEBUG - Audio Stream: 197, Subtitle Stream: -1
Jun 19, 2023 21:42:23.220 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.220 [139623372864312] DEBUG - Selecting best audio stream for part ID 81 (language: )
Jun 19, 2023 21:42:23.220 [139623372864312] DEBUG - Audio Stream: 201, Subtitle Stream: -1
Jun 19, 2023 21:42:23.221 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.221 [139623372864312] DEBUG - Selecting best audio stream for part ID 82 (language: )
Jun 19, 2023 21:42:23.221 [139623372864312] DEBUG - Audio Stream: 205, Subtitle Stream: -1
Jun 19, 2023 21:42:23.223 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.223 [139623372864312] DEBUG - Selecting best audio stream for part ID 83 (language: )
Jun 19, 2023 21:42:23.223 [139623372864312] DEBUG - Audio Stream: 209, Subtitle Stream: -1
Jun 19, 2023 21:42:23.224 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.224 [139623372864312] DEBUG - Selecting best audio stream for part ID 84 (language: )
Jun 19, 2023 21:42:23.224 [139623372864312] DEBUG - Audio Stream: 213, Subtitle Stream: -1
Jun 19, 2023 21:42:23.225 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.225 [139623372864312] DEBUG - Selecting best audio stream for part ID 85 (language: )
Jun 19, 2023 21:42:23.225 [139623372864312] DEBUG - Audio Stream: 217, Subtitle Stream: -1
Jun 19, 2023 21:42:23.227 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.227 [139623372864312] DEBUG - Selecting best audio stream for part ID 86 (language: )
Jun 19, 2023 21:42:23.227 [139623372864312] DEBUG - Audio Stream: 222, Subtitle Stream: -1
Jun 19, 2023 21:42:23.228 [139623372864312] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.228 [139623372864312] DEBUG - Selecting best audio stream for part ID 87 (language: )
Jun 19, 2023 21:42:23.229 [139623372864312] DEBUG - Audio Stream: 226, Subtitle Stream: -1
Jun 19, 2023 21:42:23.232 [139623490444088] DEBUG - Completed: [192.168.1.24:55136] 200 GET /playQueues/4?repeat=0&own=1&includeChapters=1&includeMarkers=1&includeGeolocation=1&includeExternalMedia=1 (27 live) #6189 TLS GZIP 67ms 18103 bytes (pipelined: 19)
Jun 19, 2023 21:42:23.308 [139623368645432] DEBUG - Request: [192.168.1.24:55136 (Subnet)] OPTIONS /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F61&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=gzy82ibexa4nqdwdlyz2vny5&subtitles=burn&Accept-Language=fr (27 live) #618a TLS GZIP Signed-in Token ()
Jun 19, 2023 21:42:23.308 [139623492553528] DEBUG - Completed: [192.168.1.24:55136] 200 OPTIONS /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F61&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=gzy82ibexa4nqdwdlyz2vny5&subtitles=burn&Accept-Language=fr (27 live) #618a TLS GZIP 0ms 376 bytes (pipelined: 20)
Jun 19, 2023 21:42:23.311 [139623382707000] DEBUG - Request: [192.168.1.24:55136 (Subnet)] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F61&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=gzy82ibexa4nqdwdlyz2vny5&subtitles=burn&Accept-Language=fr (27 live) #618b TLS GZIP Signed-in Token (sofianegargouri) (Chrome)
Jun 19, 2023 21:42:23.311 [139623382707000] DEBUG - [Req#618b/Transcode] Found session GUID of gzy82ibexa4nqdwdlyz2vny5 in session start.
Jun 19, 2023 21:42:23.311 [139623382707000] DEBUG - [Req#618b/Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: add-limitation(scope=videoCodec&scopeName=hevc&type=upperBound&name=video.bitDepth&value=10&replace=true)+append-transcode-target-codec(type=videoProfile&context=streaming&protocol=dash&videoCodec=hevc)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=streaming&protocol=dash&type=match&name=video.colorTrc&list=bt709|bt470m|bt470bg|smpte170m|smpte240m|bt2020-10|smpte2084&isRequired=false)+append-transcode-target-codec(type=videoProfile&context=streaming&audioCodec=aac&protocol=dash)
Jun 19, 2023 21:42:23.311 [139623382707000] DEBUG - [Req#618b/Transcode] TranscodeUniversalRequest: using augmented profile Web
Jun 19, 2023 21:42:23.311 [139623382707000] DEBUG - [Req#618b/Transcode] Downloading document http://127.0.0.1:32400/library/metadata/61?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=71gnzbhyi0d6sqo9055pw5zw
Jun 19, 2023 21:42:23.320 [139623382707000] DEBUG - [Req#618b/Transcode/Req#618c] We're going to try to auto-select an audio stream for account 1.
Jun 19, 2023 21:42:23.320 [139623382707000] DEBUG - [Req#618b/Transcode/Req#618c] Selecting best audio stream for part ID 67 (language: )
Jun 19, 2023 21:42:23.320 [139623382707000] DEBUG - [Req#618b/Transcode/Req#618c] Audio Stream: 154, Subtitle Stream: -1
Jun 19, 2023 21:42:23.321 [139623382707000] DEBUG - [Req#618b/Transcode] Found session GUID of gzy82ibexa4nqdwdlyz2vny5 in session start.
Jun 19, 2023 21:42:23.321 [139623382707000] DEBUG - [Req#618b/Transcode] Cleaning directory for session gzy82ibexa4nqdwdlyz2vny5 ()
Jun 19, 2023 21:42:23.321 [139623382707000] DEBUG - [Req#618b/Transcode] Starting a transcode session gzy82ibexa4nqdwdlyz2vny5 at offset -1.0 (state=3)
Jun 19, 2023 21:42:23.324 [139623382707000] DEBUG - [Req#618b/Transcode] [Universal] Using local file path instead of URL: /mnt/media/TV Shows/Parks and Recreation/Season 3/Parks and Recreation - S03E04 - Ron and Tammy II WEBDL-1080p.mkv
Jun 19, 2023 21:42:23.324 [139623382707000] DEBUG - [Req#618b/Transcode/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/8217c1c-4565-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx "/usr/lib/plexmediaserver/Plex Transcoder" -codec:0 hevc -ss 0 -noaccurate_seek -analyzeduration 20000000 -probesize 20000000 -i "/mnt/media/TV Shows/Parks and Recreation/Season 3/Parks and Recreation - S03E04 - Ron and Tammy II WEBDL-1080p.mkv" -map 0:0 -codec:0 copy -map 0:1 -metadata:s:1 language=eng -codec:1 copy -f dash -seg_duration 5 -dash_segment_type mp4 -init_seg_name 'init-stream$RepresentationID$.m4s' -media_seg_name 'chunk-stream$RepresentationID$-$Number%05d$.m4s' -window_size 5 -delete_removed false -skip_to_segment 1 -time_delta 0.0625 -manifest_name "http://127.0.0.1:32400/video/:/transcode/session/gzy82ibexa4nqdwdlyz2vny5/22720875-1723-4a3c-bf03-4ac886c0ffd9/manifest?X-Plex-Http-Pipeline=infinite" -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 dash -start_at_zero -copyts -vsync cfr -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/gzy82ibexa4nqdwdlyz2vny5/22720875-1723-4a3c-bf03-4ac886c0ffd9/progress
Jun 19, 2023 21:42:23.324 [139623382707000] DEBUG - [Req#618b/Transcode/JobRunner] In directory: "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-gzy82ibexa4nqdwdlyz2vny5-22720875-1723-4a3c-bf03-4ac886c0ffd9"
Jun 19, 2023 21:42:23.324 [139623382707000] DEBUG - [Req#618b/Transcode/JobRunner] Jobs: Starting child process with pid 830021
Jun 19, 2023 21:42:23.330 [139623366535992] DEBUG - Request: [127.0.0.1:37174 (Loopback)] PUT /video/:/transcode/session/gzy82ibexa4nqdwdlyz2vny5/22720875-1723-4a3c-bf03-4ac886c0ffd9/progress?status=startup (28 live) #615b Signed-in Token (sofianegargouri) (range: bytes=0-)
Jun 19, 2023 21:42:23.330 [139623490444088] DEBUG - Completed: [127.0.0.1:37174] 204 PUT /video/:/transcode/session/gzy82ibexa4nqdwdlyz2vny5/22720875-1723-4a3c-bf03-4ac886c0ffd9/progress?status=startup (28 live) #615b 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Jun 19, 2023 21:42:23.335 [139623370754872] DEBUG - Request: [127.0.0.1:37174 (Loopback)] PUT /video/:/transcode/session/gzy82ibexa4nqdwdlyz2vny5/22720875-1723-4a3c-bf03-4ac886c0ffd9/progress?status=startup (28 live) #618f Signed-in Token (sofianegargouri) (range: bytes=0-)
Jun 19, 2023 21:42:23.335 [139623490444088] DEBUG - Completed: [127.0.0.1:37174] 204 PUT /video/:/transcode/session/gzy82ibexa4nqdwdlyz2vny5/22720875-1723-4a3c-bf03-4ac886c0ffd9/progress?status=startup (28 live) #618f 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Jun 19, 2023 21:42:23.335 [139623380597560] DEBUG - Request: [127.0.0.1:37174 (Loopback)] PUT /video/:/transcode/session/gzy82ibexa4nqdwdlyz2vny5/22720875-1723-4a3c-bf03-4ac886c0ffd9/progress?status=opening (28 live) #6190 Signed-in Token (sofianegargouri) (range: bytes=0-)
Jun 19, 2023 21:42:23.335 [139623492553528] DEBUG - Completed: [127.0.0.1:37174] 204 PUT /video/:/transcode/session/gzy82ibexa4nqdwdlyz2vny5/22720875-1723-4a3c-bf03-4ac886c0ffd9/progress?status=opening (28 live) #6190 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Jun 19, 2023 21:42:26.299 [139623368645432] DEBUG - Request: [192.168.1.24:55137 (Subnet)] GET /:/prefs (15 live) #6187 TLS GZIP Signed-in Token (sofianegargouri) (Chrome)
Jun 19, 2023 21:42:26.301 [139623366535992] DEBUG - Request: [192.168.1.24:55117 (Subnet)] OPTIONS /accounts/1 (15 live) #6169 TLS GZIP Signed-in Token ()
Jun 19, 2023 21:42:26.301 [139623370754872] DEBUG - Request: [192.168.1.24:55138 (Subnet)] OPTIONS /myplex/account (15 live) #616b TLS GZIP Signed-in Token ()
Jun 19, 2023 21:42:26.301 [139623490444088] DEBUG - Completed: [192.168.1.24:55138] 200 OPTIONS /myplex/account (15 live) #616b TLS GZIP 0ms 376 bytes (pipelined: 3)
Jun 19, 2023 21:42:26.301 [139623492553528] DEBUG - Completed: [192.168.1.24:55117] 200 OPTIONS /accounts/1 (15 live) #6169 TLS GZIP 0ms 376 bytes (pipelined: 18)
Jun 19, 2023 21:42:26.303 [139623355890488] DEBUG - Request: [192.168.1.24:55117 (Subnet)] GET /myplex/account (15 live) #61a0 TLS GZIP Signed-in Token (sofianegargouri) (Chrome)
Jun 19, 2023 21:42:26.303 [139623372864312] DEBUG - Request: [192.168.1.24:55138 (Subnet)] GET /accounts/1 (15 live) #619f TLS GZIP Signed-in Token (sofianegargouri) (Chrome)
Jun 19, 2023 21:42:26.304 [139623490444088] DEBUG - Completed: [192.168.1.24:55138] 200 GET /accounts/1 (15 live) #619f TLS GZIP 1ms 647 bytes (pipelined: 4)
Jun 19, 2023 21:42:26.305 [139623490444088] DEBUG - Completed: [192.168.1.24:55117] 200 GET /myplex/account (15 live) #61a0 TLS GZIP 1ms 3843 bytes (pipelined: 19)
Jun 19, 2023 21:42:26.310 [139623490444088] DEBUG - Completed: [192.168.1.24:55137] 200 GET /:/prefs (15 live) #6187 TLS GZIP 10ms 10273 bytes (pipelined: 19)
Jun 19, 2023 21:42:26.331 [139623366535992] DEBUG - Request: [192.168.1.24:55163 (Subnet)] GET /:/websockets/notifications?filters=log (16 live) #618e TLS GZIP Signed-in Token (sofianegargouri) (Chrome)
Jun 19, 2023 21:42:26.331 [139623366535992] DEBUG - WebSocket: Performing handshake from origin https://app.plex.tv
Jun 19, 2023 21:42:26.331 [139623366535992] DEBUG - Beginning read from WebSocket
Jun 19, 2023 21:42:26.387 [139623370754872] DEBUG - Request: [192.168.1.24:55137 (Subnet)] GET /activities (16 live) #61a3 TLS GZIP Signed-in Token (sofianegargouri) (Chrome)
Jun 19, 2023 21:42:26.388 [139623492553528] DEBUG - Completed: [192.168.1.24:55137] 200 GET /activities (16 live) #61a3 TLS GZIP 0ms 720 bytes (pipelined: 20)
Jun 19, 2023 21:42:27.007 [139623492553528] DEBUG - WebSocket: client initiated close
Jun 19, 2023 21:42:27.008 [139623492553528] DEBUG - NotificationStream: Removing because of close
The whole ZIP please.
I need to see the decision process (from 'Click" until it starts)
THIS is the definitive part.
The player closed the connection, not the server.
Here is the whole Zip. I started playing something at 09:10
Plex Media Server Logs_2023-06-20_09-12-11.zip (917.1 KB)
The weird thing is that the bug is happening on every device I tried a few days before (Google TV, iOS, Web and Mac)
Hi @ChuckPa,
Anything new ?
