PMS never starts playing. Transcode times out?
Server Version#: 1.32.5.7349-8f4248874
Player Version#: 4.108.0
Plex Media Server Logs_2023-07-28_11-57-43.zip (4.5 MB)
This started happening recently where if I tried playing a video that required transcoding (ex: shows with subs that needs to be burned in), I see in the logs the server requesting the segment from the transcoder but nothing ever comes in. Eventually the LG tv player throws an error and the web player just sits there forever waiting. I’ve tried switching versions, clearing out the Cache and Codecs folder, but still same issue.
Jul 28, 2023 12:00:18.483 [7948] DEBUG - [Req#418/Transcode] Found session GUID of 0v5w1tkif5bntayhpp27zapa in session start.
Jul 28, 2023 12:00:18.485 [7948] DEBUG - [Req#418/Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: append-transcode-target-codec(type=videoProfile&context=streaming&audioCodec=aac&protocol=dash)
Jul 28, 2023 12:00:18.486 [7948] DEBUG - [Req#418/Transcode] TranscodeUniversalRequest: using augmented profile Firefox
Jul 28, 2023 12:00:18.486 [7948] DEBUG - [Req#418/Transcode] Downloading document http://127.0.0.1:32400/library/metadata/71676?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=fabtq10yphsimsftxpd6rwv4
Jul 28, 2023 12:00:18.505 [7948] DEBUG - [Req#418/Transcode/Req#99c] We're going to try to auto-select an audio stream for account 1.
Jul 28, 2023 12:00:18.505 [7948] DEBUG - [Req#418/Transcode/Req#99c] Selecting best audio stream for part ID 224396 (language: ja)
Jul 28, 2023 12:00:18.505 [7948] DEBUG - [Req#418/Transcode/Req#99c] We're going to try to auto-select a subtitle.
Jul 28, 2023 12:00:18.505 [7948] DEBUG - [Req#418/Transcode/Req#99c] Selected a foreign audio track: ja
Jul 28, 2023 12:00:18.505 [7948] DEBUG - [Req#418/Transcode/Req#99c] Subtitles: Found a candidate subtitle language [en] for a foreign film
Jul 28, 2023 12:00:18.505 [7948] DEBUG - [Req#418/Transcode/Req#99c] Audio Stream: 466886, Subtitle Stream: 466888
Jul 28, 2023 12:00:18.506 [7948] DEBUG - [Req#418/Transcode] Found session GUID of 0v5w1tkif5bntayhpp27zapa in session start.
Jul 28, 2023 12:00:18.506 [7948] DEBUG - [Req#418/Transcode] Cleaning directory for session 0v5w1tkif5bntayhpp27zapa ()
Jul 28, 2023 12:00:18.507 [7948] DEBUG - [Req#418/Transcode] Starting a transcode session 0v5w1tkif5bntayhpp27zapa at offset -1.0 (state=3)
Jul 28, 2023 12:00:18.509 [7948] DEBUG - [Req#418/Transcode] TPU: hardware transcoding: using hardware decode accelerator dxva2
Jul 28, 2023 12:00:18.509 [7948] DEBUG - [Req#418/Transcode] TPU: hardware transcoding: zero-copy support present
Jul 28, 2023 12:00:18.509 [7948] DEBUG - [Req#418/Transcode] TPU: hardware transcoding: not using zero-copy because subtitle burning is required
Jul 28, 2023 12:00:18.509 [7948] INFO - [Req#418/Transcode] CodecManager: starting EAE at "\\?\C:\tmp\Transcode\Sessions\EasyAudioEncoder"
Jul 28, 2023 12:00:18.518 [7948] DEBUG - [Req#418/Transcode/JobRunner] Job running: "E:\plex\Plex Media Server\Codecs\EasyAudioEncoder-1847-windows-x86_64\EasyAudioEncoder\EasyAudioEncoder.exe"
Jul 28, 2023 12:00:18.519 [7948] DEBUG - [Req#418/Transcode/JobRunner] In directory: "\\?\C:\tmp\Transcode\Sessions\EasyAudioEncoder"
Jul 28, 2023 12:00:18.524 [7948] DEBUG - [Req#418/Transcode/JobRunner] Jobs: Starting child process with pid 14824
Jul 28, 2023 12:00:18.524 [7948] DEBUG - [Req#418/Transcode] [Universal] Using local file path instead of URL: F:\Anime\Haganai\Season 01\Haganai.S01E06.007.There Aren't Many Customers at the Karaoke Box.[Bluray-1080p]-[iAHD].mkv
Jul 28, 2023 12:00:18.524 [7948] DEBUG - [Req#418/Transcode] TPU: hardware transcoding: final decoder: dxva2, final encoder: qsv
Jul 28, 2023 12:00:18.525 [7948] DEBUG - [Req#418/Transcode/JobRunner] Job running: set "EAE_ROOT=\\?\C:\tmp\Transcode\Sessions\EasyAudioEncoder" & set "FFMPEG_EXTERNAL_LIBS=\\\\?\\E\:\\plex\\Plex\ Media\ Server\\Codecs\\8217c1c-4565-windows-x86_64\\" & set "X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" & "D:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe" -codec:0 hevc -hwaccel:0 dxva2 -hwaccel_fallback_threshold:0 10 -codec:2 truehd_eae -eae_prefix:2 0v5w1tkif5bntayhpp27zapa_ -analyzeduration 20000000 -probesize 20000000 -i "F:\Anime\Haganai\Season 01\Haganai.S01E06.007.There Aren't Many Customers at the Karaoke Box.[Bluray-1080p]-[iAHD].mkv" -filter_complex [0:4]scale=1920:1080[0];[0:0][0]overlay[1];[1]scale=w=1920:h=1080:force_divisible_by=4[2];[2]format=pix_fmts=nv12[3] -map [3] -metadata:s:0 language=eng -codec:0 h264_qsv -b:0 15552k -maxrate:0 20736k -bufsize:0 41472k -forced_idr:0 1 -r:0 23.975999999999999 -force_key_frames:0 expr:gte(t,n_forced*3) -filter_complex "[0:2] aresample=async=1:ochl='stereo':rematrix_maxval=0.000000dB:osr=48000[4]" -map [4] -metadata:s:1 language=jpn -codec:1 aac_mf -b:1 256k -f dash -seg_duration 3 -dash_segment_type mp4 -init_seg_name init-stream$RepresentationID$.m4s -media_seg_name chunk-stream$RepresentationID$-$Number%05d$.m4s -window_size 5 -delete_removed false -skip_to_segment 1 -time_delta 0.0625 -manifest_name http://127.0.0.1:32400/video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/manifest?X-Plex-Http-Pipeline=infinite -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 dash -start_at_zero -copyts -vsync cfr -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress
Jul 28, 2023 12:00:18.525 [7948] DEBUG - [Req#418/Transcode/JobRunner] In directory: "C:\tmp\Transcode\Sessions\plex-transcode-0v5w1tkif5bntayhpp27zapa-982b5422-97aa-412a-af93-c9520cfa3d7d"
Jul 28, 2023 12:00:19.002 [13284] DEBUG - [HttpClient/HCl#c6] HTTP/1.1 (0.5s) 200 response from GET https://73-36-78-22.7091d46c6c064d32bf6990ca42b09b98.plex.direct:25156/library/sections/4/all?excludeElements=Director%2CProducer%2CWriter%2CRole%2CGenre%2CCountry&excludeFields=summary&type=2&X-Plex-Container-Size=200&X-Plex-Container-Start=0 (reused)
Jul 28, 2023 12:00:19.004 [1140] DEBUG - External Metadata: Nothing changed, computed diff in 535 ms.
Jul 28, 2023 12:00:19.004 [1140] DEBUG - [HCl#c7] HTTP requesting GET https://73-36-78-22.7091d46c6c064d32bf6990ca42b09b98.plex.direct:25156/library/sections/3/all?excludeElements=Director%2CProducer%2CWriter%2CRole%2CGenre%2CCountry&excludeFields=summary&type=2&X-Plex-Container-Size=200&X-Plex-Container-Start=0
Jul 28, 2023 12:00:19.187 [7948] DEBUG - [Req#418/Transcode/JobRunner] Jobs: Starting child process with pid 6204
Jul 28, 2023 12:00:19.527 [13284] DEBUG - [HttpClient/HCl#c7] HTTP/1.1 (0.5s) 200 response from GET https://73-36-78-22.7091d46c6c064d32bf6990ca42b09b98.plex.direct:25156/library/sections/3/all?excludeElements=Director%2CProducer%2CWriter%2CRole%2CGenre%2CCountry&excludeFields=summary&type=2&X-Plex-Container-Size=200&X-Plex-Container-Start=0 (reused)
Jul 28, 2023 12:00:19.528 [1140] DEBUG - External Metadata: Nothing changed, computed diff in 524 ms.
Jul 28, 2023 12:00:19.529 [1140] DEBUG - [HCl#c8] HTTP requesting GET https://24-147-21-234.ebd39fc819db493995e0444af43cdbfc.plex.direct:29963/media/providers
Jul 28, 2023 12:00:19.794 [13284] DEBUG - [HttpClient/HCl#c8] HTTP/1.1 (0.3s) 200 response from GET https://24-147-21-234.ebd39fc819db493995e0444af43cdbfc.plex.direct:29963/media/providers
Jul 28, 2023 12:00:19.795 [1140] ERROR - Unknown metadata type:
Jul 28, 2023 12:00:19.795 [1140] DEBUG - External Metadata: Syncing from media server Bigger Compubox with 3 existing sections.
Jul 28, 2023 12:00:19.795 [1140] DEBUG - [HCl#c9] HTTP requesting GET https://24-147-21-234.ebd39fc819db493995e0444af43cdbfc.plex.direct:29963/library/sections/3/all?excludeElements=Director%2CProducer%2CWriter%2CRole%2CGenre%2CCountry&excludeFields=summary&type=1&X-Plex-Container-Size=200&X-Plex-Container-Start=0
Jul 28, 2023 12:00:19.816 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress?status=startup (18 live) #995 Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.816 [11948] DEBUG - Completed: [127.0.0.1:60283] 204 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress?status=startup (18 live) #995 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Jul 28, 2023 12:00:19.818 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress?status=startup (18 live) #9e3 Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.818 [11948] DEBUG - Completed: [127.0.0.1:60283] 204 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress?status=startup (18 live) #9e3 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Jul 28, 2023 12:00:19.818 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress?status=opening (18 live) #9e8 Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.818 [11948] DEBUG - Completed: [127.0.0.1:60283] 204 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress?status=opening (18 live) #9e8 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Jul 28, 2023 12:00:19.820 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress?status=opened (18 live) #9ed Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.820 [15076] DEBUG - Completed: [127.0.0.1:60283] 204 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress?status=opened (18 live) #9ed 0ms 203 bytes (pipelined: 4) (range: bytes=0-)
Jul 28, 2023 12:00:19.820 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/stream?index=0&id=0&codec=hevc&type=video (18 live) #9f2 Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.820 [15076] DEBUG - Completed: [127.0.0.1:60283] 200 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/stream?index=0&id=0&codec=hevc&type=video (18 live) #9f2 0ms 195 bytes (pipelined: 5) (range: bytes=0-)
Jul 28, 2023 12:00:19.821 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/stream?index=1&id=0&codec=truehd&type=audio (18 live) #9f7 Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.821 [15076] DEBUG - Completed: [127.0.0.1:60283] 200 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/stream?index=1&id=0&codec=truehd&type=audio (18 live) #9f7 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Jul 28, 2023 12:00:19.821 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/stream?index=2&id=0&codec=truehd&type=audio (18 live) #9fc Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.821 [15076] DEBUG - Completed: [127.0.0.1:60283] 200 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/stream?index=2&id=0&codec=truehd&type=audio (18 live) #9fc 0ms 195 bytes (pipelined: 7) (range: bytes=0-)
Jul 28, 2023 12:00:19.891 [13284] DEBUG - [HttpClient/HCl#c9] HTTP/1.1 (0.1s) 200 response from GET https://24-147-21-234.ebd39fc819db493995e0444af43cdbfc.plex.direct:29963/library/sections/3/all?excludeElements=Director%2CProducer%2CWriter%2CRole%2CGenre%2CCountry&excludeFields=summary&type=1&X-Plex-Container-Size=200&X-Plex-Container-Start=0 (reused)
Jul 28, 2023 12:00:19.892 [1140] DEBUG - External Metadata: Nothing changed, computed diff in 96 ms.
Jul 28, 2023 12:00:19.892 [1140] DEBUG - [HCl#ca] HTTP requesting GET https://24-147-21-234.ebd39fc819db493995e0444af43cdbfc.plex.direct:29963/library/sections/4/all?excludeElements=Director%2CProducer%2CWriter%2CRole%2CGenre%2CCountry&excludeFields=summary&type=1&X-Plex-Container-Size=200&X-Plex-Container-Start=0
Jul 28, 2023 12:00:19.915 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/streamDetail?index=0&id=0&codec=hevc&type=video&profile=Main%2010&language=eng&width=1920&height=1080&interlaced=0&sar=1:1&level=150&frameRate=23.976&disp_default=1 (18 live) #a01 Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.915 [15076] DEBUG - Completed: [127.0.0.1:60283] 200 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/streamDetail?index=0&id=0&codec=hevc&type=video&profile=Main%2010&language=eng&width=1920&height=1080&interlaced=0&sar=1:1&level=150&frameRate=23.976&disp_default=1 (18 live) #a01 0ms 195 bytes (pipelined: 8) (range: bytes=0-)
Jul 28, 2023 12:00:19.915 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/streamDetail?index=1&id=0&codec=truehd&type=audio&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000&bitDepth=24&disp_default=1 (18 live) #a0c Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.915 [15076] DEBUG - Completed: [127.0.0.1:60283] 200 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/streamDetail?index=1&id=0&codec=truehd&type=audio&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000&bitDepth=24&disp_default=1 (18 live) #a0c 0ms 195 bytes (pipelined: 9) (range: bytes=0-)
Jul 28, 2023 12:00:19.916 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/streamDetail?index=2&id=0&codec=truehd&type=audio&language=jpn&channels=2&layout=stereo&sampleRate=48000&bitDepth=24 (18 live) #a11 Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.916 [15076] DEBUG - Completed: [127.0.0.1:60283] 200 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/streamDetail?index=2&id=0&codec=truehd&type=audio&language=jpn&channels=2&layout=stereo&sampleRate=48000&bitDepth=24 (18 live) #a11 0ms 195 bytes (pipelined: 10) (range: bytes=0-)
Jul 28, 2023 12:00:19.916 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/streamDetail?index=3&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng&disp_default=1 (18 live) #a16 Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.916 [11948] DEBUG - Completed: [127.0.0.1:60283] 200 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/streamDetail?index=3&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng&disp_default=1 (18 live) #a16 0ms 195 bytes (pipelined: 11) (range: bytes=0-)
Jul 28, 2023 12:00:19.916 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/streamDetail?index=4&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng (18 live) #a1b Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.917 [11948] DEBUG - Completed: [127.0.0.1:60283] 200 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress/streamDetail?index=4&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng (18 live) #a1b 0ms 195 bytes (pipelined: 12) (range: bytes=0-)
Jul 28, 2023 12:00:19.918 [7796] DEBUG - Request: [127.0.0.1:60283 (Loopback)] PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress?duration=1451.743000 (18 live) #a20 Signed-in Token (SloQlap) (range: bytes=0-)
Jul 28, 2023 12:00:19.918 [15076] DEBUG - Completed: [127.0.0.1:60283] 204 PUT /video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/982b5422-97aa-412a-af93-c9520cfa3d7d/progress?duration=1451.743000 (18 live) #a20 0ms 203 bytes (pipelined: 13) (range: bytes=0-)
Jul 28, 2023 12:00:19.918 [7948] DEBUG - [Req#418/Transcode] Started session successfully: 0v5w1tkif5bntayhpp27zapa
Jul 28, 2023 12:00:19.918 [15076] DEBUG - Completed: [192.168.2.170:52351] 200 GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F71676&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&mediaBufferSize=102400&session=0v5w1tkif5bntayhpp27zapa&subtitles=burn&Accept-Language=en (18 live) #418 TLS GZIP 1435ms 1079 bytes (pipelined: 1)
Jul 28, 2023 12:00:19.930 [7948] DEBUG - Request: [192.168.2.170:52351 (Subnet)] GET /status/sessions (19 live) #a30 TLS GZIP Signed-in Token (SloQlap) (Firefox)
Jul 28, 2023 12:00:19.930 [7948] DEBUG - [Req#a30] [Now] Adding 0 sessions.
Jul 28, 2023 12:00:19.931 [15076] DEBUG - Completed: [192.168.2.170:52351] 200 GET /status/sessions (19 live) #a30 TLS GZIP 0ms 474 bytes (pipelined: 2)
Jul 28, 2023 12:00:19.933 [7948] DEBUG - Request: [192.168.2.170:52352 (Subnet)] GET /status/sessions (19 live) #9e0 TLS GZIP Signed-in Token (SloQlap) (gudetama)
Jul 28, 2023 12:00:19.933 [7948] DEBUG - [Req#9e0] [Now] Adding 0 sessions.
Jul 28, 2023 12:00:22.973 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] We're in a seek: asked for 54, min/max available was 0/1
Jul 28, 2023 12:00:22.973 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] Segment #54 WON.
Jul 28, 2023 12:00:22.973 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] Killing job.
Jul 28, 2023 12:00:22.998 [12076] DEBUG - Statistics: Flushing 13 expired bandwidth entries, 0 expired media entries.
Jul 28, 2023 12:00:23.011 [13284] DEBUG - [HttpClient/HCl#d5] HTTP/1.1 (0.1s) 200 response from GET https://99-69-21-21.2362827541f34c5ca73d805a55816ccc.plex.direct:32400/library/sections/8/all?excludeElements=Director%2CProducer%2CWriter%2CRole%2CGenre%2CCountry&excludeFields=summary&type=8&X-Plex-Container-Size=200&X-Plex-Container-Start=1800 (reused)
Jul 28, 2023 12:00:23.013 [1140] DEBUG - [HCl#d5] HTTP requesting GET https://99-69-21-21.2362827541f34c5ca73d805a55816ccc.plex.direct:32400/library/sections/8/all?excludeElements=Director%2CProducer%2CWriter%2CRole%2CGenre%2CCountry&excludeFields=summary&type=8&X-Plex-Container-Size=200&X-Plex-Container-Start=2000
Jul 28, 2023 12:00:23.069 [12520] DEBUG - Jobs: 'D:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 6204 is -1059143458 (intentional termination)
Jul 28, 2023 12:00:23.069 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] Job was already killed, not killing again.
Jul 28, 2023 12:00:23.069 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] Stopping transcode session 0v5w1tkif5bntayhpp27zapa
Jul 28, 2023 12:00:23.069 [12076] DEBUG - [Req#ac3/Transcode/0v5w1tkif5bntayhpp27zapa] Streaming Resource: Resetting play progress due to seek
Jul 28, 2023 12:00:23.072 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] Starting a transcode session 0v5w1tkif5bntayhpp27zapa at offset 162.0 (state=3)
Jul 28, 2023 12:00:23.073 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] TPU: hardware transcoding: using hardware decode accelerator dxva2
Jul 28, 2023 12:00:23.073 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] TPU: hardware transcoding: zero-copy support present
Jul 28, 2023 12:00:23.073 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] TPU: hardware transcoding: not using zero-copy because subtitle burning is required
Jul 28, 2023 12:00:23.073 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] [Universal] Using local file path instead of URL: F:\Anime\Haganai\Season 01\Haganai.S01E06.007.There Aren't Many Customers at the Karaoke Box.[Bluray-1080p]-[iAHD].mkv
Jul 28, 2023 12:00:23.074 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] TPU: hardware transcoding: final decoder: dxva2, final encoder: qsv
Jul 28, 2023 12:00:23.075 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa/JobRunner] Job running: set "EAE_ROOT=\\?\C:\tmp\Transcode\Sessions\EasyAudioEncoder" & set "FFMPEG_EXTERNAL_LIBS=\\\\?\\E\:\\plex\\Plex\ Media\ Server\\Codecs\\8217c1c-4565-windows-x86_64\\" & set "X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" & "D:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe" -codec:0 hevc -hwaccel:0 dxva2 -hwaccel_fallback_threshold:0 10 -codec:2 truehd_eae -eae_prefix:2 0v5w1tkif5bntayhpp27zapa_ -ss 162 -analyzeduration 20000000 -probesize 20000000 -i "F:\Anime\Haganai\Season 01\Haganai.S01E06.007.There Aren't Many Customers at the Karaoke Box.[Bluray-1080p]-[iAHD].mkv" -filter_complex [0:4]scale=1920:1080[0];[0:0][0]overlay[1];[1]scale=w=1920:h=1080:force_divisible_by=4[2];[2]format=pix_fmts=nv12[3] -map [3] -metadata:s:0 language=eng -codec:0 h264_qsv -b:0 15552k -maxrate:0 20736k -bufsize:0 41472k -forced_idr:0 1 -r:0 23.975999999999999 -force_key_frames:0 expr:gte(t,n_forced*3) -filter_complex "[0:2] aresample=async=1:ochl='stereo':rematrix_maxval=0.000000dB:osr=48000[4]" -map [4] -metadata:s:1 language=jpn -codec:1 aac_mf -b:1 256k -f dash -seg_duration 3 -dash_segment_type mp4 -init_seg_name init-stream$RepresentationID$.m4s -media_seg_name chunk-stream$RepresentationID$-$Number%05d$.m4s -window_size 5 -delete_removed false -skip_to_segment 55 -time_delta 0.0625 -manifest_name http://127.0.0.1:32400/video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/a481377f-427a-4fdf-b1c1-13934bf922c9/manifest?X-Plex-Http-Pipeline=infinite -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 dash -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/0v5w1tkif5bntayhpp27zapa/a481377f-427a-4fdf-b1c1-13934bf922c9/progress
Jul 28, 2023 12:00:23.075 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa/JobRunner] In directory: "C:\tmp\Transcode\Sessions\plex-transcode-0v5w1tkif5bntayhpp27zapa-a481377f-427a-4fdf-b1c1-13934bf922c9"
Jul 28, 2023 12:00:23.078 [12320] DEBUG - Request: [192.168.2.170:52352 (Subnet)] GET /status/sessions (19 live) #a3f TLS GZIP Signed-in Token (SloQlap) (gudetama)
Jul 28, 2023 12:00:23.079 [12320] DEBUG - [Req#a3f] [Now] Adding 0 sessions.
Jul 28, 2023 12:00:23.079 [11948] DEBUG - Completed: [192.168.2.170:52352] 200 GET /status/sessions (20 live) #a3f TLS GZIP 0ms 350 bytes (pipelined: 2)
Jul 28, 2023 12:00:23.080 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa/JobRunner] Jobs: Starting child process with pid 13300
Jul 28, 2023 12:00:23.080 [7796] DEBUG - [Req#abc/Transcode/0v5w1tkif5bntayhpp27zapa] Started session successfully: 0v5w1tkif5bntayhpp27zapa
Jul 28, 2023 12:00:23.085 [12320] DEBUG - Request: [192.168.2.170:52381 (Subnet)] GET /status/sessions (20 live) #b02 TLS GZIP Signed-in Token (SloQlap) (Firefox)
Jul 28, 2023 12:00:23.085 [12320] DEBUG - [Req#b02] [Now] Adding 0 sessions.
Anyone?
Aug 01, 2023 19:49:34.902 [19216] DEBUG - We're going to try to auto-select an audio stream for account 1.
Aug 01, 2023 19:49:34.902 [19216] DEBUG - Selecting best audio stream for part ID 339045 (language: ja)
Aug 01, 2023 19:49:34.902 [19216] DEBUG - We're going to try to auto-select a subtitle.
Aug 01, 2023 19:49:34.903 [19216] DEBUG - Subtitles: Found a candidate subtitle language [en] for a foreign film
Aug 01, 2023 19:49:34.903 [19216] DEBUG - Audio Stream: 835891, Subtitle Stream: 835892
Aug 01, 2023 19:49:34.905 [2672] WARN - [Req#317/Transcode/4fk9cctjh4qg90l3i8yi8ouz] Timed out waiting for segment.
Aug 01, 2023 19:49:34.905 [20564] WARN - [Req#370/Transcode/4fk9cctjh4qg90l3i8yi8ouz] Timed out waiting for segment.
Aug 01, 2023 19:49:34.905 [15280] WARN - [Req#319/Transcode/4fk9cctjh4qg90l3i8yi8ouz] Timed out waiting for segment.
Aug 01, 2023 19:49:34.905 [19468] WARN - [Req#d1a/Transcode/4fk9cctjh4qg90l3i8yi8ouz] Timed out waiting for segment.
Aug 01, 2023 19:49:34.905 [20464] WARN - [Req#36b/Transcode/4fk9cctjh4qg90l3i8yi8ouz] Timed out waiting for segment.
Aug 01, 2023 19:49:34.905 [4840] DEBUG - Completed: [192.168.2.170:50799] 404 GET /video/:/transcode/universal/session/4fk9cctjh4qg90l3i8yi8ouz/1/54.m4s (22 live) #317 TLS GZIP 122536ms 496 bytes (pipelined: 1)
Aug 01, 2023 19:49:34.905 [5216] DEBUG - Completed: [192.168.2.170:50808] 404 GET /video/:/transcode/universal/session/4fk9cctjh4qg90l3i8yi8ouz/0/54.m4s (22 live) #370 TLS GZIP 106301ms 496 bytes (pipelined: 3)
Aug 01, 2023 19:49:34.905 [4840] DEBUG - Completed: [192.168.2.170:50784] 404 GET /video/:/transcode/universal/session/4fk9cctjh4qg90l3i8yi8ouz/0/54.m4s (22 live) #319 TLS GZIP 123293ms 496 bytes (pipelined: 2)
Aug 01, 2023 19:49:34.905 [5216] DEBUG - Completed: [192.168.2.170:51054] 404 GET /video/:/transcode/universal/session/4fk9cctjh4qg90l3i8yi8ouz/0/54.m4s (22 live) #d1a TLS GZIP 25187ms 496 bytes (pipelined: 1)
Aug 01, 2023 19:49:34.905 [11600] WARN - [Req#96a/Transcode/4fk9cctjh4qg90l3i8yi8ouz] Timed out waiting for segment.
Aug 01, 2023 19:49:34.905 [892] DEBUG - [Req#96a/Transcode/4fk9cctjh4qg90l3i8yi8ouz] Cleaning directory for session 4fk9cctjh4qg90l3i8yi8ouz (C:\tmp\Transcode\Sessions\plex-transcode-4fk9cctjh4qg90l3i8yi8ouz-9339c347-c2c3-4b35-b3c2-1b593d9979ac)
Aug 01, 2023 19:49:34.905 [5216] DEBUG - Completed: [192.168.2.170:50840] 404 GET /video/:/transcode/universal/session/4fk9cctjh4qg90l3i8yi8ouz/1/54.m4s (22 live) #36b TLS GZIP 105298ms 496 bytes (pipelined: 1)
Aug 01, 2023 19:49:34.906 [4840] DEBUG - Completed: [192.168.2.170:50912] 404 GET /video/:/transcode/universal/session/4fk9cctjh4qg90l3i8yi8ouz/0/54.m4s (20 live) #96a TLS GZIP 74469ms 496 bytes (pipelined: 2)
Aug 01, 2023 19:49:34.907 [892] DEBUG - [Req#96a/Transcode/4fk9cctjh4qg90l3i8yi8ouz] Deleting stale file "\\?\C:\tmp\Transcode\Sessions\EasyAudioEncoder\Convert to WAV (to 8ch or less)\4fk9cctjh4qg90l3i8yi8ouz_13528-0-0.mlp"
Aug 01, 2023 19:49:34.907 [892] DEBUG - [Req#96a/Transcode/4fk9cctjh4qg90l3i8yi8ouz] Deleting stale file "\\?\C:\tmp\Transcode\Sessions\EasyAudioEncoder\Convert to WAV (to 8ch or less)\4fk9cctjh4qg90l3i8yi8ouz_13528-0-0.wav"
Aug 01, 2023 19:49:34.908 [892] DEBUG - [Req#96a/Transcode/4fk9cctjh4qg90l3i8yi8ouz] Deleting stale file "\\?\C:\tmp\Transcode\Sessions\EasyAudioEncoder\Convert to WAV (to 8ch or less)\4fk9cctjh4qg90l3i8yi8ouz_14140-0-15.mlp"
Aug 01, 2023 19:49:34.908 [892] DEBUG - [Req#96a/Transcode/4fk9cctjh4qg90l3i8yi8ouz] Deleting stale file "\\?\C:\tmp\Transcode\Sessions\EasyAudioEncoder\Convert to WAV (to 8ch or less)\4fk9cctjh4qg90l3i8yi8ouz_14140-0-15.wav"
Aug 01, 2023 19:49:34.909 [892] DEBUG - Cleaning directory for session 4fk9cctjh4qg90l3i8yi8ouz (C:\tmp\Transcode\Sessions\plex-transcode-4fk9cctjh4qg90l3i8yi8ouz-df2faa57-6193-402b-a32d-6d0bc912d6ec)
Aug 01, 2023 19:49:34.909 [892] DEBUG - Cleaning directory for session 4fk9cctjh4qg90l3i8yi8ouz (C:\tmp\Transcode\Sessions\plex-transcode-4fk9cctjh4qg90l3i8yi8ouz-9339c347-c2c3-4b35-b3c2-1b593d9979ac)
I guess no one has any clue?
A mi me pasa este error
I have been having this problem for 3–4 weeks now. It was playing fine (I still managed to get it to work by randomly changing the Advanced Settings) but suddenly it stopped working no matter what random permutation I tried.
I even tried to Show Console Log, but couldn’t make any sense of it. It just doesn’t seem to be getting any response from the remote server.
Strange thing is I can see all the files listed but it will not play any (no theme music for different videos too). The same Unexpected Error message pops up. I tried playing from the iOS app and it worked so the problem has to do with LG TV.
Did some search and apparently it was because LG updated the SSL certificates, but so far I didn’t see any Plex update to resolve this. The app was last released on WebOS store mid 2022 … :sleepy:
I’m not sure this is on the TV’s side of things because this issue also replicates for me in Firefox on Windows.
