Server Version#: 1.22.3.4523
Player Version#: 8.17.1.25326 (a6ce558e)
Both running on Shield TV Pro 4k (model number P2897)
Plex Media Server Logs_2021-05-23_21-01-40.zip (997.3 KB)
Video freezes, audio stops, but UI remains responsive and timer keeps going. There’s no spinner in the middle of the picture. I can go forward and back, pause and resume, etc, but there’s no audio, and the picture remains frozen. If I exit the player and resume playback then it usually starts back up, but stops again eventually.
As far as I can tell this only happens when transcoding, not with direct play.
Every time this happens I can see a network change event in the logs at around the same time. Can this be the cause?
May 23, 2021 21:00:20.754 [7721] DEBUG - NetworkInterface: received Netlink message len=1276, type=RTM_NEWLINK, flags=0x0
May 23, 2021 21:00:20.754 [7721] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=7, flags=0x11003, change=0x0
May 23, 2021 21:00:20.754 [7721] DEBUG - Network change.
May 23, 2021 21:00:20.754 [7721] DEBUG - NetworkInterface: Notified of network changed (force=0)
May 23, 2021 21:00:20.798 [7721] DEBUG - Detected primary interface: 0.0.0.0
May 23, 2021 21:00:20.798 [7721] DEBUG - Network interfaces:
May 23, 2021 21:00:20.798 [7721] DEBUG - * 1 lo (127.0.0.1) (loopback: 1)
May 23, 2021 21:00:20.798 [7721] DEBUG - * 7 wlan0 (192.168.0.249) (loopback: 0)
May 23, 2021 21:00:20.798 [7721] DEBUG - * 1 lo (::1%1) (loopback: 1)
May 23, 2021 21:00:20.809 [7721] DEBUG - NetworkService: Got notification of changed network (first change: 0)
May 23, 2021 21:00:20.809 [7721] DEBUG - NetworkService: Dispatch network change after two second delay.
May 23, 2021 21:00:20.810 [7721] DEBUG - NetworkService: Got notification of changed network (first change: 0)
May 23, 2021 21:00:20.810 [7721] DEBUG - NetworkService: Dispatch network change after two second delay.
May 23, 2021 21:00:21.492 [7304] DEBUG - EventSource: Failure in ReadData (103 - Software caused connection abort).
May 23, 2021 21:00:21.493 [7303] DEBUG - EventSource: Failure in ReadData (103 - Software caused connection abort).
May 23, 2021 21:00:21.532 [7304] DEBUG - MyPlex: We appear to have lost Internet connectivity, resetting device URL cache.
May 23, 2021 21:00:21.532 [7304] ERROR - EventSource: Retrying in 15 seconds.
May 23, 2021 21:00:21.532 [7304] DEBUG - handleStreamRead code 103: Software caused connection abort
May 23, 2021 21:00:21.611 [7303] ERROR - EventSource: Retrying in 15 seconds.
May 23, 2021 21:00:21.612 [7304] DEBUG - NotificationStream: Removing because of error
May 23, 2021 21:00:21.612 [7304] DEBUG - Completed after connection close: [192.168.0.249:33722] -3 GET /:/websockets/notifications (7 live) TLS GZIP 1844771ms 322562 bytes
May 23, 2021 21:00:21.612 [7303] DEBUG - handleStreamRead code 103: Software caused connection abort
May 23, 2021 21:00:21.612 [7303] DEBUG - NotificationStream: Removing because of error
May 23, 2021 21:00:21.612 [7303] DEBUG - Completed after connection close: [192.168.0.249:33738] -3 GET /:/websockets/notifications (7 live) TLS GZIP 1842085ms 322428 bytes
May 23, 2021 21:00:21.976 [12012] DEBUG - [Transcode] Transcoder segment range: 0 - 57 (57)
May 23, 2021 21:00:21.980 [10425] DEBUG - [Transcode] Transcoder segment range: 0 - 58 (57)
May 23, 2021 21:00:22.064 [12010] DEBUG - [Transcode/89aa6af90df4f755-com-plexapp-android] Returning segment 57 from session
May 23, 2021 21:00:22.064 [12010] DEBUG - Content-Length of /storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/Transcode/Sessions/plex-transcode-89aa6af90df4f755-com-plexapp-android-8d361a7c-7834-4abc-adc5-2869fe3d831b/media-00057.ts is 1328186 (of total: 1328186).
May 23, 2021 21:00:22.179 [12010] ERROR - Caught exception trying to stream file: /storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/Transcode/Sessions/plex-transcode-89aa6af90df4f755-com-plexapp-android-8d361a7c-7834-4abc-adc5-2869fe3d831b/media-00057.ts: write: Software caused connection abort
May 23, 2021 21:00:22.180 [7303] DEBUG - Completed after connection close: [192.168.0.249:40952] 500 GET /video/:/transcode/universal/session/89aa6af90df4f755-com-plexapp-android/base/00057.ts (3 live) TLS 1619ms 0 bytes (pipelined: 29)
May 23, 2021 21:00:22.180 [7303] DEBUG - Removed transcode data consumer, active count 1 => 0
May 23, 2021 21:00:22.815 [7722] DEBUG - Network change for advertiser.
May 23, 2021 21:00:22.816 [7722] ERROR - Error broadcasting message: send_to: Network is unreachable
