Server Version#: 1.15.6.1090
Player Version#: 3.95.2
SHIELD version#: 7.2.3(30.6.131.71) (latest test image)
I’ve been struggling with this issue for months now.
The transcoder fails after ~10-15 minutes of playback. The playback will stop, and the loading circle will appear indefinitely, playback never picks up. I have to close the player and resume the playback manually. Disabling hardware transcoding doesn’t fix the issue.
Media is located on a Synology NAS.
Plex is not usable.
Playback stopped today May 19, 2019 10:18:40. I’ve noticed errors in the log file (Plex Media Server.log) at 10:18:20.897, the transcoder crashes.
Any insight ?
May 19, 2019 10:18:20.024 [6399] DEBUG - Request: [192.168.0.10:2575 (Subnet)] GET /video/:/transcode/universal/dash/vz8m4fnsv0o1dfxk9hy0m18q/0/5216.m4s (10 live) TLS GZIP Signed-in
May 19, 2019 10:18:20.026 [6399] DEBUG - Asked for segment 5216 from session.
May 19, 2019 10:18:20.337 [21610] DEBUG - Transcoder segment range: 4561 - 5216 (5216)
May 19, 2019 10:18:20.412 [21573] DEBUG - Returning segment 5216 from session
May 19, 2019 10:18:20.413 [21573] DEBUG - Content-Length of /storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/Transcode/Sessions/plex-transcode-vz8m4fnsv0o1dfxk9hy0m18q-0a73fa10-bb6b-49c3-9186-4f75a2bc5e79/init-stream1.m4s,/storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/Transcode/Sessions/plex-transcode-vz8m4fnsv0o1dfxk9hy0m18q-0a73fa10-bb6b-49c3-9186-4f75a2bc5e79/chunk-stream1-05217.m4s is 31748.
May 19, 2019 10:18:20.421 [9100] DEBUG - Completed: [192.168.0.10:2656] 200 GET /video/:/transcode/universal/dash/vz8m4fnsv0o1dfxk9hy0m18q/1/5216.m4s (10 live) TLS GZIP 612ms 31748 bytes (pipelined: 516)
May 19, 2019 10:18:20.427 [21608] DEBUG - Request: [192.168.0.10:2656 (Subnet)] GET /video/:/transcode/universal/dash/vz8m4fnsv0o1dfxk9hy0m18q/1/5217.m4s (10 live) TLS GZIP Signed-in
May 19, 2019 10:18:20.428 [21608] DEBUG - Asked for segment 5217 from session.
May 19, 2019 10:18:20.428 [6399] DEBUG - Returning segment 5216 from session
May 19, 2019 10:18:20.428 [6399] DEBUG - Content-Length of /storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/Transcode/Sessions/plex-transcode-vz8m4fnsv0o1dfxk9hy0m18q-0a73fa10-bb6b-49c3-9186-4f75a2bc5e79/init-stream0.m4s,/storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/Transcode/Sessions/plex-transcode-vz8m4fnsv0o1dfxk9hy0m18q-0a73fa10-bb6b-49c3-9186-4f75a2bc5e79/chunk-stream0-05217.m4s is 3642296.
May 19, 2019 10:18:20.551 [9099] DEBUG - Completed: [192.168.0.10:2575] 200 GET /video/:/transcode/universal/dash/vz8m4fnsv0o1dfxk9hy0m18q/0/5216.m4s (10 live) TLS GZIP 527ms 3642296 bytes (pipelined: 671)
May 19, 2019 10:18:20.563 [19297] DEBUG - Request: [192.168.0.10:2575 (Subnet)] GET /video/:/transcode/universal/dash/vz8m4fnsv0o1dfxk9hy0m18q/0/5217.m4s (10 live) TLS GZIP Signed-in
May 19, 2019 10:18:20.564 [19297] DEBUG - Asked for segment 5217 from session.
May 19, 2019 10:18:20.897 [9093] DEBUG - Jobs: '/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Transcoder' exit code for process 22193 is -9 (signal: Killed)
May 19, 2019 10:18:20.910 [19282] DEBUG - Streaming Resource: Changing client to use software decoding
May 19, 2019 10:18:20.910 [19282] DEBUG - Found session GUID of vz8m4fnsv0o1dfxk9hy0m18q in session start.
May 19, 2019 10:18:20.915 [9099] DEBUG - Auth: authenticated user 1 as Sungray
May 19, 2019 10:18:20.915 [19283] DEBUG - Request: [192.168.0.10:2737 (Subnet)] GET /status/sessions (10 live) TLS GZIP Signed-in Token (Sungray)
May 19, 2019 10:18:20.916 [19283] DEBUG - [Now] Adding 1 sessions.
May 19, 2019 10:18:20.947 [19282] DEBUG - TranscodeUniversalRequest: using augmented profile Web
May 19, 2019 10:18:20.987 [19282] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/3880?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=121jhg28cgdwrs5ui58sv8qe
May 19, 2019 10:18:20.987 [19282] DEBUG - Auth: authenticated user 1 as Sungray
May 19, 2019 10:18:21.144 [19282] DEBUG - It took 10.000000 ms to retrieve 142 items.
May 19, 2019 10:18:21.160 [19282] DEBUG - We're going to try to auto-select an audio stream for account 1.
May 19, 2019 10:18:21.160 [19282] DEBUG - Selecting best audio stream for part ID 3692 (autoselect: 1 language: en)
May 19, 2019 10:18:21.160 [19282] DEBUG - We're going to try to auto-select a subtitle.
May 19, 2019 10:18:21.160 [19282] DEBUG - Subtitles: Found a candidate subtitle language [eng] for a foreign film
May 19, 2019 10:18:21.160 [19282] DEBUG - Audio Stream: 16130, Subtitle Stream: 16132
May 19, 2019 10:18:21.170 [19282] DEBUG - Streaming Resource: Applying codec restriction restrict-transcode-target-codec(audioCodec=aac&context=streaming&protocol=dash&type=videoProfile&videoCodec=h264) on 121jhg28cgdwrs5ui58sv8qe
May 19, 2019 10:18:21.171 [19282] DEBUG - Scaled up video bitrate to 31021Kbps based on 1.500000x fudge factor.
May 19, 2019 10:18:21.172 [19282] DEBUG - MDE: Selected protocol dash; container: mp4
May 19, 2019 10:18:21.172 [19282] DEBUG - MDE: analyzing media item 3680
May 19, 2019 10:18:21.172 [19282] DEBUG - MDE: The Avengers (2012): Direct Play is disabled
May 19, 2019 10:18:21.172 [19282] DEBUG - MDE: The Avengers (2012): media must be transcoded in order to use the dash protocol
May 19, 2019 10:18:21.172 [19282] DEBUG - MDE: The Avengers (2012): selected subtitle cannot be converted to a compatible format, burning into video stream
May 19, 2019 10:18:21.172 [19282] DEBUG - MDE: The Avengers (2012): avoiding video remux due to burned subtitle stream
May 19, 2019 10:18:21.172 [19282] DEBUG - MDE: The Avengers (2012): no remuxable profile found, so video stream will be transcoded
May 19, 2019 10:18:21.172 [19282] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
May 19, 2019 10:18:21.172 [19282] DEBUG - Scaled up video bitrate to 31021Kbps based on 1.500000x fudge factor.
May 19, 2019 10:18:21.172 [19282] DEBUG - The Avengers - audio.channels limitation applies: 8 > 6
May 19, 2019 10:18:21.172 [19282] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
May 19, 2019 10:18:21.172 [19282] DEBUG - MDE: The Avengers (2012): selected media 0 / 3680
May 19, 2019 10:18:21.207 [19282] DEBUG - Streaming Resource: Reached Decision id=3880 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=3680 part=(id=3692 decision=transcode container=mp4 protocol=dash streams=(Video=(id=16129 decision=transcode bitrate=31021 encoder=libx264 width=1920 height=1038) Audio=(id=16130 decision=transcode bitrate=256 encoder=aac channels=2 rate=48000) Subtitle=(id=16132 decision=burn languageCode=eng location=embedded))))
May 19, 2019 10:18:21.208 [19282] DEBUG - Transcode Session: Going to restart at offset 4561.000000 with segment number -1
May 19, 2019 10:18:21.208 [19282] DEBUG - Killing job.
May 19, 2019 10:18:21.208 [19282] DEBUG - Signalling job ID 22193 with 9
May 19, 2019 10:18:21.208 [19282] DEBUG - Job was already killed, not killing again.
May 19, 2019 10:18:21.208 [19282] DEBUG - Stopping transcode session vz8m4fnsv0o1dfxk9hy0m18q
May 19, 2019 10:18:21.208 [19282] DEBUG - Starting a transcode session vz8m4fnsv0o1dfxk9hy0m18q at offset 4561.0 (state=3)
