Hi, everytime i use the transcoding option, i get only a stereo sound track, but my movies have a dts track.
Is it possible to tell the transcoder to dont change the sound track?
Greetings from Germany
what client are you using?
if it is 5.1 compatible, and configured to use it, Plex will send 5.1.
it can convert to 5.1 dolby digital, if your client isn't DTS compatible.
Hi, Im using PleXBMC and choosed Dolby Digital ind the Addon Settings.
But when i play a movie, there is only one track in stereo. (Attachement)
Without transcoding it works.
sorry this took so long to reply
check your main settings in XBMC, make sure your surround is set up properly there.
i also use PleXBMC, and am able to get DTS-HD and Dolby TrueHD.
if that doesn't work, can you provide a bit more info, like what are you running XBMC on? what kind of connection do you have for the audio (optical, HDMI, etc) what are you using for your amp? how do you know it's only stereo?
