Thanks @FordGuy61. I actually found a utility that is installed with the graphics card that shows GPU utility. I should have thought about HWMonitor becasue I used it on my laptop just a couple of month ago when my graphics card on that was going out.
I have a Gigabyte motherboard too, so I will definitely check out the BIOS settings.
Edit: I was wrong. I just checked my BIOS settings. There is an option to disable Intel Processor Graphics in the BIOS. Apologies for the goof.
GA-Z97X-Gaming 7 w/ i7-4790k.
The setting is called “Initial Display Output.” When I choose IGFX, Plex uses the HD4600 on the 4790K for hardware accelerated transcoding. When I choose the PCIe slot, Plex uses my Nvidia card.
That’s exactly what I was worried about too. My board only allows you to choose which card is enumerated first. A quick search says that some boards offer the option and some don’t. But I haven’t personally tried in a long time since I typically only have one or the other installed at a time.
Thank you for the heads up It’s been years since I’ve been into the hardware side in any serious way. In my BIOS I found both options. To set the main graphics display slot and to disable the onboard graphics. To start I just did what @FordGuy61 suggested and set the second slot to my primary display device.
BTW, I only used the second slot because I have my raid card in the first one. They both operate at 8x if both are occupied and I didn’t want to have to deal with reinstalling drivers for my raid card if for some reason windows forgot it (it did forget my teamed network card that was in the second slot).
I may, if none of this works swap the cards, but I want to keep that as a last resort.
The server is starting back up now. I’ll let you know how it goes. I think it was using the NVENC before as the transcoding logs said it was, but the performance just wasn’t what I was expecting.
its possible, if you removed the intel drivers, but the intel gpu was still enabled in the bios, that windows silently reinstalled the intel drivers.
this would take you back to your original post where you experienced the lag from what sounds like is the split workload (igpu doing one thing while p2k doing the other).
fwiw, we both have similar cpu (i have a i5-6600k) both have the intel 530 GPU, which supports some kinds of 4k DECODE, but not ENCODE.
That sounds like why you get some buffering with 4k when the intel tries to DECODE, it just isn’t quite new enough.
disabling the intel gpu should put all the work on the p2k and you should be flying then.
4k/hdr = intel 600 series GPU = intel 7000 series CPU
That could be. I’m new to hardware acceleration in Plex and I’m willing to be wrong. Either way, I disable the iGPU int the BIOS and same thing. it says it’s using hardware acceleration on both (DXVA2 for decoding NVENC for encoding) but it’s not working all that well and the GPU is staying at around 5%.
Is there some kind of test I can run outside of Plex to see if it’s Plex or maybe something else? I tried to find a stress or benchmark to run to try and see how it would go, but couldn’t find anything.
For windows 10, I just use the TASK MANAGER and it has a gpu monitor built in.
but really, if you can get the intel gpu disabled and any drivers removed, the p2k by itself should be all you need.
hopefully someone who actually has a p2k up and running can chime in and help, I am just trying to help based on what I have picked up for myself since I am interested in a p2k (or new server build with newer intel cpu).
I have not had time to reinstall plex yet or get the other machine set up yet. Tonight it was recording 2 shows off my OTA antenna (using HDHR Quatro Connect) and it wouldn’t even attempt to transcode…it just sat there spinning, nothing on the server seemed to be doing anything and it didn’t even show it was running. The CPU for the transcoder was at 20ish% which I think is probably from the OTA recording…it definitely seems fishy.
I’ll try and set up that other machine this weekend and give it a go on that one.
I have built out an i5-9600k machine with an Asus ROG Strix Z390-H Gaming mother board and G.Skill 3200 DDR ram.
I tried transcoding once with my MSI GTX 1060 Armor 6G and no go (I was just testing it while it was in there). Odd thing is that it only said it was encoding with hardware, not decoding. So, I removed the GRFX card, added in the p2000, uninstalled the drivers and reinstalled the quadro drivers.
Still no go, still only encoding with HW, not encoding and the grfx card is doing it slow.
I’m on the step where I uninstall PLEX Media Server and reinstall with the Quadro in.
Yes, I have it hooked to a monitor (though only 1080p) and in Windows that monitor is set ad my main one. I’m also going to check the bios to see if I need to set the primary card in there.
So I restarted and reinstalled PLEX. Still no go CPU is pegged, P2000 is barely working and it still says it is only using hardware acceleration on the encode. I can’t even get as far as I was on my server were it at least said it was using hardware acceleration on both.
Quick question: What does the hardware decoding? Would it be the CPU or the P2000?
I actually see above where it said they should both be on the GPU
Completely uninstalled plex (removing the registry key and the local appdata folder). use DDU to uninstall the driver and then reinstalled it. Reinstalled plex. Made sure to set Hardware acceleration on and still same thing on this machine. It says it uses for encode, but not decode. I am at a complete loss. I will try a different video to be sure, but this same video was using hwa on encode and decode.
