Troubles Remote access
So, i’m not sure where to put this one. (So if it is wrong, please place it right moderator!)
Anyway, I have 2 PMS’ in my home network. One on my Mac Mini (which acts as a small NAS) and my big main pc with a lot of storage which acts as a archive for media that i’ve already seen.
So, the point is that (I think) both are interfering with each other… I can’t connect them to my out side network and i’m away of how networking works in general. My Mac Mini has been setup as DMZ host so I can access all of it everywhere (yeah i know, security risk). Therefor the PMS should be accessible on domain.com:32400/web/ (which it is!). Unfortunately, PMS itself is not able to determine a local and external IP address and can’t add it to the Plex DB. (See: https://puu.sh/qoqlg/f51b66933e.png)
For my second server, I have a portforward for port 80 and it is setup on port 80 in the Remote Access tab. It has the same problems with local and external IP discovery. But it works when i go to domain.com/web/.
Since I use the ATV4, and iOS/Android app in most cases I can’t connect directly to my servers outside my home network…
And Going to Plex/web directly isn’t a viable option on mobile…
I hope somebody could help me out with this!
Thanks,
Sem
not sure i understand the reasoning for using DMZ. just make 2 port forwarding rules in your router for each server. the external port needs to be different for both. the external port that you use is what you enter in the manually specify port field which you enabled
Server1. External=32400 Internal=32400 LocalIP xxx.xxx.xxx.xxx
Server2 External=32401( or 80 if you really want to use that) Internal=32400 LocalIP xxx.xxx.xxx.xxx
So yeah, the DMZ is there because i’m using a lot more ports and I dont want to configure them every single time… Could that be an issue? Its about the servers on http://pap.xvilo.com which points to 77.164.210.36
http://pap.xvilo.com is going to a 401 it shoudl be pointing to http://77.164.210.36:32400/web/index.html
did you put http://pap.xvilo.com in the server network setting Custom server access URLs
